A View Through The Mirror
backgroundbackground Posts: 944
edited May 16 in Art Studio
Here is an image that might be the start of an adventure called 'The View Through The Mirror'.
Not much to say... some random guy is in the middle of nowhere getting into a sports car. Why he's there, and what happens next, we'll have to wait and see.
Post edited by background on
«1345
    Watching...
  • backgroundbackground Posts: 944
    edited May 16
    Wait,  he's gone already??
    < not sure if this narrative stye is working > ... and has anyone ever tried to add tyre tracks to a hdri , this was quite a head scratcher. This is why I usually take the easy way out and just comment on somone else's thread, then I don't have to worry about how to turn an idea into a picture, or how to add meaningful dialogue.
    Let's see if we can catch up to him
    1754 x 1045 - 129K
    edited May 16
    We're getting closer, but he seems to be in a hurry.
    No more clues for today. Be seeing you.
    1754 x 1045 - 114K
    Those tire tracks look very good. I don't remember whether I ever tried to put something like that on an HDRI. I'm sure you can't apply it directly to an HDRI image. Did you use a decal on a transparent plane or something?
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,777
    edited May 17
     I edit HDR images all the time in Gimp, not tried tyre tracks though, looks good Background yes
    edited May 17
    I totally cheated, in a way. I tried drawing them onto the hdri, a few times but it looked terrible. The tyre tracks are actually two large diameter thin ring objects that I created and then cut in half and put in the image like the car, and set the opacity very low. The full ring had 512 segments to get a smooth curve. I did mess up though because I think the tyre marks appear to be from the front wheels, but the Toyota 2000GT is a rear wheel drive car. I never owned one, but I liked the open topped one in 'You Only Live Twice', and it makes a change from an Aston Martin.DB5.
    edited May 17
    well that is how I edit HDR
    I render spherical camera 2:1 images to match in size, dome only in Environment but uncheck the HDR being visible in DAZ Studio or Carrara Octane (EXR there) then add the Tiff or EXR image as a layer to the HDR in Gimp keeping the metadata etc
    edited May 17
    That's clever, I will have to try that. I'm sure there will be other places in the story where a hdri is needed and often they don't contain everything I would like. On these ones. I was happy to get the car on the left side of the road, or at least appear not obviously in the middle.
    edited May 17
    Okay, this is getting dangerous. This guy is doing 112 Km/h into a blind corner. I think we better drop back a bit and catch up with him later, but it's ok because I know exactly where he lives.
    Not happy that I used the term 'catch up' twice within four renders. Also not happy because the dashboard was low-res and applying subd made cracks appear.in it, and it's still not smooth. Also all the gauges were set at zero and not pivoted, and it just looked wrong, so I took had to fix it. It also has a speedometer calibrated in km/h rather than mph,
    Does the sudden switch from outside visual to inside work?
    1754 x 1045 - 196K
    edited May 17
    Not sure if the narrator repeatedly 'breaking the fourth wall' is making the story confusing to read. Might be better to put comments in a separate post like this.  I think once we get properly into the story I will let the characters speak for themselves, and the narrator will only chime in to explain if something is not clear, or to indicate that time has passed.
    Some people may have already guessed where this story is heading, and I really wish I could create that, but without spending months building the environment I'm going to have to compromise, I hope it will 'pay homage' to the original concept without being a copy, and that there are still some interesting twists, and maybe even a laugh or two ( but it's not a comedy )..
    Like barbult I welcome any ideas/thoughts/criticism from the audience, and all are very welcome to comment. I have  pretty vague idea where I'm going, and it's quite possible I will 'paint myself into a corner' at some point, especially if I am left unsupervised. laugh
    edited May 19
    I have no idea where this is going, so I need more render clues. Of course, I have no idea where my own stories are going most of the time, so...
    in my stories, I mix narrator and dialog in the same forum message. I like to keep a single episode in a single message. I think it makes it easier to follow and easier to follow people's comments when it is all  together. Otherwise, which message should I comment on? But your narrator speech might not be related to a single render, like mine usually is. Just do what feels right to you.
    Post edited by barbult on
  • richardandtracyrichardandtracy Posts: 8,236
    barbult said:
    I have no idea where this is going, ...
    Probably straight rather than round the bend that's approaching at 70mph.
    Regards,
    Richard
    edited May 19
    There has been  a temporary lull because I have things in mind for the story, that I don't have models of, and things I do have models of, but no idea which archive drive they are on. Still I made some progress yesterdaay so I've not given up, and i hope to have at least one more render posted today
    3DIO: Thanks for your flattering comments. I've never considered myself photogenic. I should point out that he may resemble past me, but I haven't done the things he will be doing ( such a driving like a lunatic ). Since he looks a bit like me from about 35 years ago, and I was never one to keep up with the fashions, then an 80s vibe sort of fits. BUT one of the props I want to use for a little joke is post 2000 and the car is 1967-1970 so we have a mixture of timescales already. It bothered me and then I decided not to worry about it.
    Barbult: I hope things are ok with you and yours. I saw your comment about Richard being on-hold mid flight and was a bit worried, but it would be a sad day when anyone feels an obligation to post pictures here every day. It should be a fun experience, not a duty.. You have the awesome responsibility of being the inspiration for this thread and I highly value your input.always. In the next few images it will become clear to anyone who saw the original, in where the inspiration comes from. Anyone not familiar with the original I will be happy to direct them to it, BUT I think it will be more enjoyable to just see where it goes without the 'spoiler' of seeing the original.  While It might be fun to copy the original closely it would also restrict what I can do, and it would at best be a pale shadow and plagarism. So I'm taking the concept and making a new story based on it, and really only put my approximate  likenes in there for fun, not for any delusions that I was ever, or could ever have lived this story.
    Other Richard: Yes I didn't think that through very well. I wasn't until I arranged the car on the HDRI that I realised that it was so close to the corner, and then forgot to turn the speedometer down to a more realistic number. I really just wanted some way to do a scene cut. I only mentioned the the kmh becasue if I left people to think it was mph then the car would have a speedo that implies it can reach 230 mph or so.
    edited May 19
    He's getting close to home.
    I apologise for the state of the City. There's no excuse apart from it was the only available model at a reasonable price. This is about as close as we can get before it starts looking like playdough.
    1754 x 1045 - 317K
    edited May 19
    Ah he's arrived home at last, and without any accidents ( but a couple of close shaves).
    The post box tells us which country we are in ( and it adds a nice bright element for the picture. ). I should probably call it a pillar box, especially since it's painted pillar box red.
    1754 x 1045 - 406K
    edited May 19
    Hmm, seems like we're not the only people following him...
    Now I want you all to concentrate hard and convince yourselves that, the stretched Austin FX4 taxi is actually an Austin Princess Hearse ( that's why I took the TAXI sign off the roof ).
    If it's a bit slow we haven't really started yet, and if it's too much like the original, things will soon start to go in unexpected ways. If you spot the mistake don't tell anybody, I din't notice it until I had uploaded it.
    1754 x 1045 - 408K
  • csaacsaa Posts: 1,082
    edited May 19
    background,
    Just wanted to say I'm enjoying this story and hope to see more.
    Cheers!
    Post edited by csaa on
    csaa said:
    background,
    Cheers!
    Thanks csaa, you're very welcome, and if you have any suggestions please feel free to chime in.
    There was me thinking the Palace of Westminster was a fairly unsubtle hint of the country. But a post box seems to be more recognized. Oh well. Regards, Richard.
    edited May 19
     You are quite right, I was just referencing the original a bit. We'll be in another country soon enough though, which one? Now that would be telling.
    edited May 19
    I'll edit this with the next render, hopefully tomorrow.
    I still have no clue what the original is that you are inspired by. Perhaps a UK reference that I don't pay attention to in my USA life. Perhaps it will become clear as the story progresses. Richard Haseltine knows every cultural reference, it seems. I bet he knows exactly what is going on here. Frank (forum admin) called Richard a human sponge.
  • Richard HaseltineRichard Haseltine Posts: 111,945
    I think we are off to an extensive foly next, after a little nap.
    edited May 20
    Richard you have correctly identified the original, but we can't go to the extensive foly in question because I don't have one to render. Instead we are going to go to a place run by the same organisation, which now covers a larger area. I think we'll see another vehicle built by Austin Motors though and a helicopter, and  Rover is likely to appear. I have a nice little Lotus but that's very specific to the original character, and my character is not him ( hence the Toyota ), and he won't have the same number. Does the 'human sponge' epithet also apply to beer? laugh.
    edited May 20
    I'm tempted to put in a Youtube link to at least the first few minutes of the original, that would fill in some gaps I have left in between renders ( quite siginificant gaps with major plot points ). I won't do it just yet, but once I've had a little nap ( as Richard put it ) it might be fun. Rest assured knowing the original wouldn't answer most of the questions that might spring to mind.
    It's got nothing to do with the show 'Lost' ( afaik I didn't watch the whole thing ) But if someone made something similar, would seeing the first few episodes of Lost help you understand what was going on in a similar show?
    if it's what I think it is
    you could use an inflatable pool or a bouncy castle as the monster cheeky
    edited May 20
    laugh That would certainly be a surreal take on it, being chased by a bouncy castle. I guess it could happen though, if one broke loose on a really windy day. I think my Rover will have to stay spherical, but I will try to put the bouncy castle and  an inflatable pool into the story, because it's funny, and I want to include things that viewers suggest, as a 'thank you' for taking an interest. One thing about the original is that parts of it are already so surreal that you could put almost anything into it without it feeling out of place. As an aside, I read that the spherical rover was in the original as an emergency solution after the mini-hovercraft rover they built failed miserably, in fact I think it sank and it's remains may still be somewhere in the bay. Here is a picture of it, not very intimidating and looks like a giant blancmange to me. The spherical 'weather balloon' rover became iconic though. Show anyone in the UK, over a certain age a photo of a weather balloon and they will likely say "Oh that's like the one from The......" but of course I'm biased being a fan
    250 x 176 - 24K
    edited May 20
    Progress a bit slow today. The reason is that the next scene will be a room that will be seen regularly, and it has to have features, such as a telephone that can be picked up. It's going to look strange ( or at least I won't be satisfied ) if things have to be added mid story, that should have been there all along. If a telephone suddenly appears because someone has to answer a call, then I think it breaks the immersion. A limited amount is probably ok because real rooms are not immutable, but neither do their layouts change every day. So I'm trying to think what I might need in there. For a TV show or a film I guess this would be decided after reviewing the scripts, before production starts. It's surprising though what can be done without being glaringly obvious. The original 'Lost in Space' springs to mind. The Jupiter 2 spacecraft interior has more than two levels ( or at least characters are shown ascending and descending from various levels ) but the exterior windows on one level take up more than half the height of the ship. I really liked LIS when it started but it soon decended into weak comedy, mainly thanks to the Dr Smith character. It's pity because the Robot, Chariot, and Spaceship all seemed to have been designed with high production values ( despite my earlier comments on the ship).
    Mobile phones can appear from a pocket... Regards, Richard
    edited May 20
    Yes that's true, and I did think about mobile and wireless phones ( in fact a non working mobile phone will be in the story briefly ). The problem is that there is supposed to be no communication with the outside world ( or at least it is heavily restricted ) so letting the characters use mobile phones would sort of require some explanation of why they don't just ring anyone they please. I suppose it could be a limited range service, or some kind of encryption which makes it incompatible with regular mobile phones. A huge advantage to mobile and wireless phones would be that I wouldn't have to worry about the handset wires, which are a major nuisance.
    The original used wireless handsets, which I don't think existed at the time, but of course an actor can speak into and listen to a handset without it actually working.
