How do you deal with overexposed elements close to the main subject in the frame?
Hello,
Say, for example, this scene I've been playing with.
Initially, I loaded this old set. Just with some global illumination it looks like you can see in the first screenshot.
Then, if I make the character visible, one can see that she needs more light directed to her. (You can safely ignore the pokethrough, I know. This is just for discussing lighting and overexposed elements close to the main subject).
All right, let's make the main light visible. Now she looks better, but at the cost of the overexposed architectural elements close to her.
This is a very common scenario. How do you deal with this type of challenges?
  • My first suggestion, study real world photography and lighting techniques.
    While we can do many things in 3d that we can't do in reality, it's a good starting point
    In the case of your image, you can do a few different things, but will be dependent on what type of light( point, spot, distant,) you use.
    It appears you're using a spot light with defalut spread angle(60 degrees), and it's relatively close to your subject.
    If that's the case, the first thing is to determine where exactly the light is pointing. You can do this by switching your view to that particular light via the drop down in Viewport.
    Depending on what look you're going for, you'll probably want the center point to be aligned with the person.
    With that out of the way, you'll then want to reduce the spread angle so that it doesn't shine on the walls.
    This will necessitate a reduction in luminance, as  the light will be more intense the narrower the focus gets.
    Another option would be to switch the spot light from "Point" to "rectangle", with settings of 100hx50w, and align the light with the center mass of the figure.
    This functions much like a "Light box" in the real world by softening the light, and reducing the area it lights up.
    Another option, use "barn doors" to reduce the coverage area of the light.
    A simple plane, or 4, positioned on the sides of the light, will give you more control over what is and isn't lit.
    You could also just put a plane inbetween the light and the figure(s) you don't want lit, though this may produce unwanted shadows, or sharp shadows, and you need to make sure it won't appear in the render by keeping it off camera.
  • felisfelis Posts: 6,566
    In Render Setting > Tone Mapping what is the Burn Highlight value?
    If 1 try to lower it to 0.25.
  • JumbotronJumbotron Posts: 279
    DrunkMonkeyProductions
    Hi. Back when I first got interested in Daz I read and watched many, many basic and not so basic tutorials and courses. I also read about complementary subjects like photography and cinematography. I am not very knowledgeable now by any means (I started knowing nothing), but I think I know decently enough about the most crucial elements of photography applied to the use of Daz Studio. Of course, if you have specific suggestions for me to read/watch, don't hesitate to mention them.
    This is the main light view and its parameters (first screenshot). As you can see, the light is pointed directly to her head. I already tried reducing the spread angle and playing with different options, but nothing seems to get a good compromise between her light level and that of the surrounding elements (that these are white definitely does not help).
    In the second screenshot, you can see what happens if I reduce the light spread from the default 60 to 28 and reduce the lumen by half. It's probably better now, but that the light has geometry added to soften the shadows makes reducing the light spread angle less effective.
    I'll try the idea of the "barn doors" and see what I can do with that. Thank you. :)
    felis
    Hi. I am using 0.4 for the burn highlights as I've found that this valor together with 2.00 for the gamma tends to produce renders with highlights that match closely those of the beauty canvas. But thanks for mentioning it all the same. Often times I forget about things that I always add to my renders. So I can always reduce the burn highlights to help with the issue. :)
    3354 x 1912 - 919K
    1477 x 1920 - 4M
  • alan bard newcomeralan bard newcomer Posts: 2,431
    create new camera . . . lock it
    render scene without the character with lighting you want
    turn off the set
    render character with lighting you want
    save the renders in tif or ping
    stack in photoshop
    you can even play with each layer separately
    then save master file as tif and save a jpg of you mixture.
    image below
    sky layer
    trees and land
    a real bright dragon to geneate the light with girl
    a normal dragon to layer over the bright one
    4000 x 2000 - 1M
  • eeyuneeyun Posts: 54
    It could be that you're also fighting the materials/shaders here - maybe in the iray simulation the set material/shader just ends up bouncinbg more light back than the ones used by the character. It would be hard to make up for that using real-world photographic techniques ("hey, my fluorescent mylar set is blowing out my portrait photo"). It looks like the set may use a single set of surface parameters, so you could just try tweaking some of those to dull it down.
    edited May 20
    Thank you all for the ideas and suggestions.
    alan bard newcomer
    Lighting separately and then making the composition in Photoshop of the separate pieces is something I had heard of. I've never tried it yet, though. I can imagine it must make the whole process of creating a 3D still render longer, though? An option to keep in mind in any case.
    eeyun
    Tweaking material properties can prove helpful sometimes, yes. In this specific case, I haven't got any success in that regard, though. Also, this being an old set, the materials were not Iray. I tried converting the materials of the overexposed blocks to Iray and then tweaking their properties. But I couldn't really get them to look any less bright.
    Another issue that I've found in this particular scene is that, for some reason, I can't get the camera Depth of Field function to work fine. I can't separate the character focus from the background. Either everything looks blurry or everything looks on focus. And I don't honestly think it's me forgetting how to set the camera depth of field. I've done it many times and it's not really difficult to configure it to one's preference. But for some reason it gets messy in this particular scene. I think I'll just forget about it and start something new (and use something newer as the environment).
    Post edited by Jumbotron on
