Saphirewild's Randomness Renders
1646566676870»
  • Richard HaseltineRichard Haseltine Posts: 109,994
    Either script is run in DS, just download the file (using the link above the code) and drag it into the Viewport.
  • SaphirewildSaphirewild Posts: 6,716
    How do I point the content to my external hard drive?
    It keeps going to my intern hd.
    I did what you said and draged the script into the viewport
    You need to chnage the path, in DIM or in DS, then the script can be used to make the othe appliication match that. In DIM it is in the instalaltion tab of Advanced Settings, from the gear icon at top-right; in DS it is Edit>Preferences>Content tab, click Content Directory Manager.
    edited April 8
    Ok now what do I click on?
     I am going through DS
    I tried the DIM but very confusing as to which on to click on as well
    Post edited by Saphirewild on
    In Content Directory manager you expand the entries for the Current Directories, Daz Studio Content Directories (and Poser Content assuming you have any of that), highlight the path you want to change, and click the Edit... button under the Directory heading on the left. Select the folder you want to use.
    Well I went and messed up the DM. Now it won't even load damn it all t hell!!!
    I do not know what the hell I did wrong but now where it will not load I can't even undo what went wrong!!
    Are you getting any kind of error message? Does anything at all happen? If you post
    %appdata%/daz 3d/InstallManager
    into a file browser address bar then you should see a log file in the window that opens, does that gie any information? Is it updated with the timestamp of your last attempt to run DIM?
    It will not even load at all keeps freezing out then I have to reboot in order for it to stop freezing out, just says when I try to X it out that it has incountered a fatel error and needs to close.
    So this is a Windows crash report?
    I think so not really sure!
    Should try and factory restore my laptop?
    Also I can not take out the stuff from the external hd until I can get the stuff uninstalled from the DM, I am in such a pickle right now.
    Please post a screen shot of whatever is appearing when you try to run DIM. Don't do a factory reset or anything, you'd then have to redo everything else.
    Well I ended up redoing the laptop anyway because somehow or another the 4T Ex HD started giving me fits.
    When I did redo the laptop I was able to get into the 4T Ex HD and delete everything and now I have to redo everything anyway!
    I know I have to redo everything now but I think it was worth it I am going back now and reading everything and hopefully I will do better this time!!
    Ok now what do I click on in the DIM Advanced setting under the gear to send the content to the EX HD?
    Go to the Installation tab of Advanced Settings, click the + button to add a new destination in the bottom section and set the path you want, then make it the default (or just select it in the Ready to Install tab in the main window)
    Ok I clicked on the + button and it says at the top "Label" What do I put in that part?
    Anyhting you like, it is just a description to help you see which path it is.
    Thanks so much for all your help with this working out how to get the content into my EX HD Richard!!!
    ok running into another problem I have over 5K in content that is not installing not giving an error message just not installing and I have retried 5 times now and still not installing any ideas?
    Can you give a few examples, and any pop-up or leg messages associated with the failures?
    707 x 665 - 97K
    Oh, I see. Do you mean you have restarted DIM five times, or just clicked the retry button five times? Sometimes it seems to get stuck and a fresh start may help - either rght-click and choose the otpion to delete partial packages or just plain restart DIM.
    Ok to answer your question I tried restarting the Installs 2 times and then 3 times restarting DIM!
    Maybe I am still doing something wrong I am so confused right now!!
    edited May 6
    No, that looks like a server or DIM issue, though it may be caused by something local to your machine (e.g. security permissions, disc space on the drive you are downloading to, folder permissions). I would check that you have space to spare on the drive with the package Archive (the downloads folder) in the Downloads tab of Advanced Settings
    Ok I did a clean reinstall and it is doing the same thing and I have 4T Ex HD there is plenty of room for it. not sure about the rest of the stuff like permissions but it is not saying anything about that not saying anything at all just not installing.
    So the downloads folder is on the external drive?
    There have been a few reports over the last few days of  downloadissues, it may just be that the server node you are getting is slow or otherwise problematic. We did flag those issues up to Daz.
    Ok then I will wait to see if the issues get resolved, plz let me know if they do get resolved
    edited May 9
    YAY!!! Finally rendering not much to it cause have download and install from Daz 3D Studio for each thing until the server gets fixed!!
    605 x 657 - 175K
    edited May 9
    I am getting there slowly building the scene from ground up!!
    605 x 657 - 286K
    I am so happy to be back rendering again but I think I am going to have to learn everything all over again been a few years since I have set up scenes or rendered.
