Render your buys! 1, 2, 3 Testing!!
13»
  • Matt_CastleMatt_Castle Posts: 3,306
    It's definitely not specific to HDRIs, and indeed it's arguable that HDRIs are maybe less likely to have the issue, as they fundamentally generate light from all direcitons.
    The thing is that ultimately the models are polygonal meshes; normally there's a whole load of interpolation (such as the Phong interpolation method) that tries to smooth the virtual surface normals so that it doesn't look faceted.
    Normals in 3D rendering are kind of weird, in that the virtual surface angle can be different to the actual surface angle. I utilised that in this render here, where I made a Penrose triangle that's faked in a way that's not possible in the real world; the geometry is actually quite heavily curved, but I gave it normal maps that told it to treat the surfaces as flat - making it possible to have a refractive Penrose triangle (the real world ways of faking the triangles would be very obvious in a refractive material).
    However, while virtual normals works well from steep angles, it shows weaknesses when subjected to light from shallow angles. If you have a point source of light coming in at a shallow tangent to a "curved" mesh surface, there is strictly a very hard border on the model where one face of the model is facing the light source, and the next is facing *away* from the light source, and this transistion can be particularly apparent if the light source is intense enough.
    Algorithms exist that try to mitigate the issue, but ultimately the most effective fix is to give the algorithms less work to do by using a finer mesh.
  • barbult said:
    paulawp (marahzen) said:
    I finally got a chance to tinker a little this weekend. What causes the weird jaggy shadow lines?
    These items were new in recent days:
    https://www.daz3d.com/dforce-fv-enigma-veil-hair-for-genesis-9
    https://www.daz3d.com/artful-model--set-01-for-genesis-9
    https://www.daz3d.com/valon-tykki
    https://www.daz3d.com/vyk-conforming-cloth
    Look for information on Shadow Terminator. Try increasing the subdivision level and/or the triangulation direction of that part of the mesh.
    That usually shows as stair-casing, where one set of polygons is sahded facing away from the light and one towards. This doesn't look the same, so while I certainly wouldn't exclude it it might also be worth selecting one of the affected polygons with the Geometry Editor tool, then right-click>Geometry Editing>Rotate Triangulation of Selected Polygons and see if that helps - dForce splits quads into triangles when it simulates, and there are two ways to do that (top-left to bottom-right or top-right to bottom-left) one of which may work better than the other in any given situation.
    Unfortunately, dForce Starfall for G9 and G8F is another one I should really be putting in a ticket about.
    Gallery Link
    Parts of the long draped sleeves are weighted to the pelvis and torso, making it impossible to pose the arms without using dForce... and for a character with a generous figure like Becky, you really do need to pose the arms pre-dForce to stop the sleeves clipping into the skirt. Other parts are directly weighted to the forearm bones, rather than to the forearm twist bones as they should be.
    It also really needs morph rigidity maps on the draping sleeves to stop auto-follow morphs getting ripped up from copying from different parts of the mesh.
    I was able to fix it to the point I can get it to work, but getting clothes to fit things is kind of my thing, and a product should not require a user of my skill level to make it viable.
    3840 x 2160 - 2M
  • sidsid Posts: 590
    edited October 2025
    I bout a lot of things with the recent stacked discounts bringing so many items down to 2-3$, so I might spam this thread a bit with any findings.
    I like Alexander Hipster Hair and Beard For Genesis 9, but in some lights it really looks like Neftis3D groomed the beard with a very neat harvester!
    Pictured here on Lurym, who is pretty handsome for a green dude.
    https://www.daz3d.com/the-alchemist-workshop-bundle
    2000 x 2659 - 3M
    Post edited by sid on
  • FJM1977FJM1977 Posts: 353
    edited November 2025
    Testing:
    Lali Kamala's Spandex Suit 01 and removing the hood.
    ChungDan's Ankle Boots, and putting them on G9, while not having them deform.
    I was able to parent then to the feet (well, the feet of the suit), but I wasn't able to get them to conform completely, so I reset the foot pose instead
    dForce Studio Drapery.
    3120 x 3840 - 4M
    Post edited by FJM1977 on
  • edited April 26
    I'm back! As some of you know from other posts I've made, my 10-11 year old computer died & I had to wait to replace it. This is my first project since getting my new laptop earlier this month. Content was bought during MM2026, except for Centaur 9 and Astaroth's pants (random pair from my library), and all straight out of the box right now. New Laptop is an HP Victus with i5 CPU & RTX4050 graphics card, if anyone's curious.
    This WIP & products tryout is titled "It's Not What It Looks Like!" in which a hapless demon tries to explain WTH just happened to some irate forest denizens. Don't ask me, I have no idea what happened, either. I haven't done any posing yet, since I was so eager to get something rendered to show people. I might do it in both Iray and Filatoon.
    1) https://www.daz3d.com/bend-of-the-river. This was one of the many flower/plant freebies I got over Easter weekend. As the product page & several forum posts mention, there is a Visible in Preview button in Parameters to toggle the high-demand foliage, etc. off & on. You have to have this on for those to be rendered, too, which isn't clear, so it didn't make it into the trial render. I do like the looks, expecially how reflective the water is. Maybe too mirror like? Any suggestions if I decide it's too reflective?
    2) https://www.daz3d.com/sylvia-9-dryad-hd I've loved Sylvia 9 since she was released, but had held off on the add-on. It looks pretty good for a quick render. Needs more flowers, & Yes to the (Faye) Dress, as one of my next steps in this project.
    3) https://www.daz3d.com/astaroth-9 (Yes, I got a bunch of bundles during MM.)
    4) https://www.daz3d.com/centaur-9 I used the Standardbred Masc preset.
    5) https://www.daz3d.com/battle-boar Looks pretty good in the distance with one of the included poses. He'll either be the Dryad's mount or try to shove the car around.
    6) https://www.daz3d.com/llamaghini-gallopngo A old but fun Matty Manx creation, with standard Daz license but is pre-Iray. I just converted all the materials to the base Daz Uber Iray shader, then picked an automobile shader & a velvet (for the upholstery) from that material set, included with DS. Note that Llamaghini is old enough it will be installed to the Poser section of DS.
    7)I used Code66's https://www.daz3d.com/legacy-set-converter script on the Llamaghini props (tires, spoiler, etc.). Note that the full car is a figure, so if you want it in .duf format, you must use the Save As methiod, since the converter only works for props. I found the converter easy to use, although sometimes I had to try twice, which may have been due to me never using it before. There's also a good PDF manual/tutorial available from either inside DS or as a download.
    605 x 657 - 845K
    Post edited by miladyderyni_173d399f47 on
  • Here are a couple more try-outs of various products I've picked up the last few months.
    The dragon lady is the "Crone" version of https://www.daz3d.com/cc-catalina-for-genesis-9 plus https://www.daz3d.com/dragon-wings-and-tail-for-genesis-9. Hair is https://www.daz3d.com/hs-kelly-messy-curves-hair-for-genesis-9-8-and-81-females, & outfit is from https://www.daz3d.com/sy-fantasy-wear-megapack-genesis-8-female-s. (HDRI is part of Sickleyield's Good to Go! Lighting set I got from Rendo some years ago. Not sure if it's still available.) The dragon tail has enough bones to be able to easily pose. And Catalina looks great, as I expected from Changling Chick.
    The other is my combo of https://www.daz3d.com/lyra-solenne-hd-for-genesis-9 & the https://www.daz3d.com/lauryn-9-cervitaur-add-on. The crown is from the  https://www.daz3d.com/bw-sea-queen-outfit-for-genesis-9 and hair is https://www.daz3d.com/dforce-fe-elegant-wave-long-hair-for-genesis-9. I used the white cervitaur to go with Lyra's albino coloring. When I loaded the cervitaur without having Lauryn 9 installed. DS flagged the missing files but let me continue. Unfortunately, Lyra is too young looking to "fit" well with a full-grown deer body. If I do more with this one, I will probably either mix in Lauryn, or just use Lauryn with Lyra's skin, since I don't think there's a fawn or younger morph for cervitaur. I like the look of the Elegant Wave Hair, but it could use more morph presets IMO.
    402 x 651 - 540K
    605 x 657 - 234K
  • TorquinoxTorquinox Posts: 4,990
    @miladyderyni_173d399f47 gotta admit, Catalina is one of my favorite g9 figures and the crone aspect is especially useful.
  • Catalina is wonderful. I think I am going to be using her a lot more.
  • nemesis10nemesis10 Posts: 4,039
    edited May 7
    The weapons are the recent buy: https://www.daz3d.com/fantasy-spear-collection-01
    1820 x 1112 - 2M
    Post edited by nemesis10 on
  • I like it. What lights did you use?
    It is https://www.daz3d.com/ultrumarine-ocean and https://www.daz3d.com/iray-water-caustic-lights. I used an hdri from the former and a foreground light from the latter.
  • csaacsaa Posts: 1,082
    edited May 10
    1024 x 1024 - 493K
    Post edited by csaa on
    edited July 3
    1821 x 1112 - 2M
  • A WIP for the finished "Fish Dinner!" that I just posted in the All Time Renders thread. (https://www.daz3d.com/forums/discussion/comment/9545376/#Comment_9545376) It's mostly to show the differences in the vintage https://www.daz3d.com/pteranodon & https://www.daz3d.com/pteranodon-by-am. The older figure doesn't look good in this render, but is fine for for far background, which is how it got used in the final render. I wouldn't recommend it for anything else except perhaps Filatoon or other toon renders.
    Also used: https://www.daz3d.com/secluded-shoreline. This is an older 3DL environment by FirstBastion I recently picked up in a sale. Like the Daz pteranodon, I used the https://www.daz3d.com/rssy-3delight-to-iray-converter to convert the shaders & one of the Skies of Iradiance replaced the original dome and lighting. Secluded Shoreline has an environment sphere that needs to be hidden/deleted as well, to avoid an all-black render.
    Finally, dinner is this unlucky, scaled down https://www.daz3d.com/feligalodon-original-figure.
    The AM Pteranodon and the Feligalodon are both very easy to pose by hand, so to speak. For both I started with an included pose and altered that.
    1600 x 1200 - 3M
  • paulawp (marahzen)paulawp (marahzen) Posts: 1,810
    nemesis10 said:
    I wanted to do something with https://www.daz3d.com/jp-udo-hd-with-dforce-body-hair-for-genesis-9
    That expression is great.
    I only just saw this, and yes the expression. Especially the eyes. I wonder what's in that steam or fog?
  • Working on a character portrait for a friend's upcoming Star Wars roleplaying game. I used https://www.daz3d.com/lekkulian-for-genesis-9 plus some dial-spinning for my character, one of the iconic SW aliens, wearing https://www.daz3d.com/ashleigh-jumpsuit-for-genesis-2-female-s and the boots from https://www.daz3d.com/dforce-star-explorers-gogo-dress-outfit-iray-textures. The jumpsuit autofits easily to the character, and the boots come with a white shader that's easy to recolor. The environment is https://www.daz3d.com/spaceship-crew-room, right out of the box. I didn't do anything with the lighting or render settings before I started the test render, so those were defaults.
    460 x 651 - 516K
  • I spent most of the afternoon & evening playing with both new & old content.
    I took advatage of the delays with Outlet & Quick Grab changeovers to pick up a few inexpensive goodies, inclduing https://www.daz3d.com/arianna-81, wearing https://www.daz3d.com/dforce-cb-apollonia-clothing-set-for-genesis-8-and-81-females. Hair is the very old https://www.daz3d.com/wild-orchid-hair with https://www.daz3d.com/uht-hair-shaders-for-iray. Background is https://www.daz3d.com/molto-bello, currently in the Daz freebie selection. Lighting is from a Skies of Iradiance set, and I need to do some tweaking of either the lighting or perhaps the hair. (The UHT set has some utility settings.) Once I figure that out, I am going to do some posing. Wish me luck, as I haven't done much with dForce.
    309 x 500 - 141K
    309 x 500 - 143K
