G9 Rendering Semi-Transparent
I haven't had much experience with Genesis 9, so I don't know if this is a known issue. I was doing some test renders with a G9 character, and I noticed that the figure was somewhat transparent, as if it was a window. It doesn't reveal other objects that are behind the model; the transparency goes right through the props behind the model to reveal the blank background.
In the attached image, I used a graphical editor to add a pale gray background and several colored bars. If you look closely, you can see the bars through the model's abdomen, despite the fact that there is a cube primitive directly behind her. I discovered that if I turn the model's translucency slider all the way to zero, this transparency goes away and the model is opaque.
Can anyone give me a clue as to what is causing the model to render like this?
