G9 Rendering Semi-Transparent
I haven't had much experience with Genesis 9, so I don't know if this is a known issue. I was doing some test renders with a G9 character, and I noticed that the figure was somewhat transparent, as if it was a window. It doesn't reveal other objects that are behind the model; the transparency goes right through the props behind the model to reveal the blank background.
In the attached image, I used a graphical editor to add a pale gray background and several colored bars. If you look closely, you can see the bars through the model's abdomen, despite the fact that there is a cube primitive directly behind her. I discovered that if I turn the model's translucency slider all the way to zero, this transparency goes away and the model is opaque.
Can anyone give me a clue as to what is causing the model to render like this?
Hey, did you ever figure out what the issue was? Or did it just go away on its own? I've seen some forum posts that point to the SSS Chromatic mode that could be the culprit:
https://www.daz3d.com/forums/discussion/287446/skin-tend-to-be-transparent-as-the-rendering-progresses?srsltid=AfmBOorlozk4ePO1_vEwhleZ-3K50NatwJBJCdzzCBFn28b73JHhhQRy
but enabling Draw Dome causes the issue to go away.
