Fatal Errors
Good evening, all.  Daz haz been shut down by three fatal errors in the last ten minutes.  This after four such errors last night.  Does anything in the attached pictures mean anthing to anyone?  Or is there some other information I could give to try to figure out what's going on?  Any help would be appreciated.
  • backgroundbackground Posts: 948
    edited April 30
    nvoglv64.dll which is mentioned in the screenshots is part of Nvidia OpenGL, so it looks like something associated with the graphic card. You could check if your Graphic card drivers are up to date, but first I would check which versions you have installed now, and download backup installers so that you can revert the change if needed, just in case updating makes things worse
    Post edited by background on
  • jecswpjecswp Posts: 78
    That was it.  I checked before I posted, and the nvidia app said I ws up to date with the "Recommended" drivers.  I decided to switch just to see if it would help.  I went with the"Leading Edge" version and no fatal errors all day. Thanks for inspiring me to look at the drivers again.
  • mikael-aronssonmikael-aronsson Posts: 607
    Don't ever check if you have the latest drivers, check if the drivers has been updated around the time of the problems, (drivers don't just stop working, it's the updates that do that) there is no reason to update drivers if there are no issues, these days you have a 25% chance of braking something when you update the drivers, sometimes it looks like nVIDIA stopped doing any QA any more on the drivers they release. (And DON'T let nVIDIA install drivers by itself, always keep it on manual).
