Parameters Lockup
csteell_c2893e4ab6csteell_c2893e4ab6 Posts: 536
edited April 29 in Daz Studio Discussion
I have twin screens. Pesently I am using DAZ Studio 4.24 Beta. When working on a animations the paramaters dials freeze up.They are greyed out! Is anyone else having these problems? Computer specs are: Custom built. Windows 11.RTX 4060 TI 16 GIG Graphics card. 128 gigs RAM. Intel i9 12 generation. Several SSD Hard Drives 4 Terabytes each.Cheers
Post edited by csteell_c2893e4ab6 on
  • garrett_3dgarrett_3d Posts: 815
    Just out of interest, why are you still using Beta? Have you tried using the general release version of 4.24? I don't experience these issues.
  • Thank you for your reply. I have two desktop computers.The second computer has a RTX 5060 TI Graphics card.The beta version of DAZ Studio 4.24 will render with this card.The general release will not render with RTX 5060 TI! Cheers.
  • LeanaLeana Posts: 13,482
    The beta version of DS4.24 does not render using your 5060, the version of Iray in DS4 doesn't support them. Only the beta of DS2026 supports 50xx cards.
  • Maybe I am doing something wrong but I have been rendering with this version for a few months now with a RTX 5060 TI. Cheers
    960 x 720 - 332K
    3840 x 2160 - 738K
    You would be rendering with the CPU, not GPU.
  • Thank you for your reply.How do I tell if I am rendering with a GPU? Do I turn off the CPU? I am talking about rendering in DAZ Studio Premier 2026! Cheers
  • Richard HaseltineRichard Haseltine Posts: 111,244
    The screenshot shows the DS 4.24 about/splash screen, not the DS 2026. What is used to render, where supported, is set in the Hardware tab of Render Settings.
  • Sorry about the confusion. I have started using DAZ Studio Premier 2026 Beta. Will it always render with RTX 5060 ti card in automatically in IRAY when I start a render or do I have to turn of the CPY setting? Cheers
    Uncheck the CPU in the Hardware tab of Render settings,  under PhotoReal Mode and Interactive(biased) Mode and Allow CPU Fallback, and it won't use the cpu during rendering.
    with fall back turned off, if you exceed the Vram of your card, it'll just produce a black/empty render, depending on Environment settings.
