DAZ Character and Redshift
Masterstroke
When trying to render one DAZ character in c4d with redshift, I get an error warning, telling me my GPU runs out of memory.
I am running a RTX 3060 12GB.
I can render several DAZ characters in DAZ Studio with the same GPU.
So, what is wrong with C4D and Redshift?
Post edited by Masterstroke on
There is nothing wrong, DAZ characters can eat all your GPU memory if you are not careful, set all subdivision levels to zero or one if you have any and start from there, hair is usually a big offender, try to turn off some meshes (hair...) and see if that helps (just to find out what the problem is, polygon hair can usually be optimized a lot without loosing any quality).
Check the vertex count for each object (Right click in object manager and click Object Information) and see if you have any crazy high values (again.... hair).
These are two different renderers, they may use memory in different ways so it's difficult to compare but Redshift is not known for being GPU memory friendly.
I assume you are not running other application that eat your GPU memory.
I don't use Redshift often so I don't know if the Automatic Memory Management is still turned off by defult, if it is, turn it on and see if that helps.
Just out of curiosity, what version is your character and how did you export it to C4D ? that could have some impact, G9 can be a road to hell if you are not careful.
I found that hair may be the worst offender, if you're using card hair with lots of transparencies. If you haven't tried it, C4D Redshift has render nodes called "Sprites" that render transparencies a zillion times faster (I won't go through the process, best to look it up). The caveat is that the transparency has to be only black and white, no greys, but for complicated hair, I took the transparency, upresed it to like 8000x8000 in Photoshop, and changed the mode to Bitmap, then used that in C4D for the transparency. It looks really great, and renders in a snap. You can see examples in this segment of my latest Aurora video:
