• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Blender Modifiers to Daz3d [Solved]
aidanthomas77aidanthomas77 Posts: 1
April 25 edited April 26 in Blender Discussion
Hello, I am Prepping a Structure in Blender to export to Daz3d, I have the Boolean Modifier (Difference) Applied to some of the Meshes and when I import the Structure into Daz3D as an Obj the Modifiers Disappear. As a Note I have the Option "Apply Modifiers" Enabled when Exporting From Blender, But the same Problem still Occurs.
Post edited by aidanthomas77 on April 26
  • TheMysteryIsThePointTheMysteryIsThePoint Posts: 3,336
    April 25
    From the semantics of "Apply Modifiers", I too would think that would work. But there is "space" in there for a Blender dev to have a different interpretation.
    But what I would think doesn't have that space would be copying the object, applying the modifiers manually on the copy, and then exporting that?
  • lilweeplilweep Posts: 2,877
    April 25 edited April 25
    aidanthomas77 said:
    when I import the Structure into Daz3D the Modifiers Disappear.
    This phrasing is odd. What does this acutally mean - "disappear"?
    And what is "the modifiers" in this description?
    a) The resulting mesh that the boolean modifier produced in Blender?
    b) Or you think the modifier should carry over into Daz?
    If (a) above, does this mean you cant see any mesh in your scene? If so, click the focus button to focus on it. It probably imported at too large or too small size.
    or if (a) above, and the boolean is messed up, it could be because the boolean produced n-gons, and daz will not render n-gons properly. If that's the problem you need to triangulate before import to Daz.
    if (b) above, then obviously that is not going to happen.
    But yeah, try what mysteristhepoint said (apply within the modifer stack before export rather than applying via the export dialog)
    Post edited by lilweep on April 25
  • PadonePadone Posts: 4,344
    April 26
    Booleans will typically result in ngons, daz studio is more limited than blender handling ngons, thus not everything will import fine. Below an example that's similar to your scene, where daz studio fails to compute the geometry. One workaround is to triangulate before export, or use the triangulate option in the obj exporter.
    474 x 244 - 36K
  • aidanthomas77aidanthomas77 Posts: 1
    April 26
    Thank you Very much for the Help all of you,
    Enabling the Triangulated Mesh Option in the Export Dialogue Resolved the Issue.
    I apologise for the Phrasing in my First Message I am Very New to all of this and I'm not so used to Expressing in Technical Terms of what I want to achieve in Blender/Daz3D.
    But Thank you very much again, I am very Grateful.
    1395 x 1078 - 59K
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
