Genesis 3 loading issue
Lonnie DudeLonnie Dude Posts: 51
Hi,
My drive crashed with most of my content, so I have to start over. Anyway, I try to load Genesis 3 female and get this:
I uninstalled the product and re-installed it all through DIM, but that didn't fix anything.What's wrong?
Post edited by Lonnie Dude on
  • NorthOf45NorthOf45 Posts: 5,921
    Either you have your viewport set to Solid Bounding Box (where you select Iray, Texture Shaded, Filament, etc.), or the data files cannot be found.
  • felisfelis Posts: 6,625
    Try to look in your log Help > Troubleshooting > View Log
  • crosswindcrosswind Posts: 10,351
    Make sure the path of your Daz Libaray to where you installed G3 Starter Essential packages in DIM is correctly configured in Content Directory Manager.
    Did you get any message of missing files when you loaded G3 figure?  Also you can check your DS log.
  • Lonnie DudeLonnie Dude Posts: 51
    No Message that D/S couldn't find anything. The log didn't offer any clues either, at least as far as I can tell. I think it may be the data file issue.
  • Richard HaseltineRichard Haseltine Posts: 111,949
    edited April 4
    How did you instal? If you are not getting an error it probably isn't missing files, it may be that the files are there but not  decrypted proeprly (whichc an be an issue when installing with Daz Connect, that is through Daz Studio). In that case the log file should tell you that it couldn't find an opening { or [ in one or more of the files.
