reset the x,y,z location on an object to 0,0,0
too many links involving axis and zero.. to get a hit...
Object is at 500x, 20y, 200z (on the grid)  ... when it's parameters are set to 0,0,0
I can move it to 0,0,0 but then it thinks it's at 500,20,200... I want to reset it so it  reads 0,0,0 when I put it at 0,0,0
how, where do I make its 0,0,0, match the scenes 0,0,0. --- I want to save it as a scene subset and then bring it back in at the center with it's parameters set to 0,0,0
thanks
  • MarcCCTxMarcCCTx Posts: 947
    If it is a figure, check the both the figue and it's hip bone. Alot of poses move the hip of a character.
  • thanks...
    but it's just an object ..  and it's default position isn't in the world center even when it's object centered..
    so it needs it's object center to be changed to the world center
    I can move it to the center but I want to reset it's default coordinates...
  • If it's a prop, just export as OBJ with it at the origin, then import that OBJ and reapply materials.
    first time I tried it didn't change the numbers
    but exported it again and turned off "write object statement  option" and it worked..
    thanks
  • laststand6522732laststand6522732 Posts: 866
    edited December 2021
    Post edited by laststand6522732 on
  • This is something that should be a button or a command in Daz studio >>> making a prop or character reset to 0,0,0<<<
    Make a feature request please
  • and nope..  just tried it again and it's not doing it... did one object three times..  exported from the center and still come back at -6700 x, etc
    That is unexpected, to say the elast. Please post a screenshot of the OBJ export and import options.
  • I've been tossing stuff back and forth between daz and max with no problem
    but these are set of architectual object I bought and the person who put them together put them all in one file.
    the 30 separate items came in as one in daz ---  or as 30 in max .. but for some reason there position data is locked to where they were in the original positioning..
    and even in max I can't reset them to 0 because according to the data box they are at zero....
    but at least when I import them the pivot for moving is right at the bottom instead of miles away...  but the use their spot in the big file as their absolute point...
    so I will do some more research there..  I actually brought them in.. put them in the center .. exported them and re-imported and they still have their original setting point.. maybe I need to find out about editing object files...  that has to be a header setting or such
  • alan bard newcomeralan bard newcomer Posts: 2,423
    edited October 2018
    okay. if I bring the object into daz...  put it on center, even though it thinks it's at 120,-300,-4000, and then export it as fbx and then import it .. it is centered and  says 0,0,0
    so I can convert them to work with standard increments
    and having done that .. once again I went to the original object, 234,-456,20 exported it as an object
    reimported it and tada this time it says 0,0,0.....
    excuse me while I go away and quietly gnaw on my arm a bit...
    brought in a new object.. centered it .. it reads 100,-72,17, (these are extracted from 30 objects in max that came in as one file so their coods are all different.
    exported as object brought back in it says 0,0,0..
    so perhaps the fbx export import changed some flags or internal settings?
    anyway .. it seems to be happy again...
    Post edited by alan bard newcomer on
  • Right, that is what I was addressing in my earlier post - you need the item to be at the origin, regardless of what the coordinates say, then export and reimport. If the thing is modelled off-centre, which it clearly would be if it was part of a gorup of items in a single file, then off-centre is its zero position as originally imported.
  • I am sorry to necro this thread, but this is the same thread I keep getting when I search for this every year or so.
    There is a much easier way to resolve this issue and I wanted to share.  Also, when I inevitably forget this solution, I will find it here. :D
    1. Select the figure that is off from 0,0,0
    2. Edit -> Figure -> Memorize -> Memorize Figure Pose
    3. Edit -> Figure -> Zero -> Zero Figure Pose
    This should reset the figure to absolute 0,0,0
    I hope this helps.
  • n.jmurovn.jmurov Posts: 91
    I hope this helps.
    Did not help at all, although the advice might have been intended for simple props.
    This has been a long-standing problem for me. Although I can't say I've tried very hard to resolve it but a few threads on this form were not helpful. Sometimes I save a human figure as a scene and the location or rotation of the figure are not exactly all zeros. When I then bring the figure back in and apply a pose that is intended to place the figure at 0,0 - even I place the figure at 0,0 manually before I do that - it never works, the figure goes to some wacky location that is saved somewhere within the file, I guess, so the figure always gravitates to it. I've tried zero object, zero figure, zero pose and whatnot. Obviously, with a human figure it does not make sense to try exporting and then re-importing it as .obj as all the rigging will be lost.
    So if I choose Zero Figure it goes NOT to 0,0,0 but to some other X,Y,Z location. If I bring the figure manually to 0,0,0 and then apply a pose that is intended to put the figure at 0,0,0, it goes back to that X,Y,Z location. Same happens if I use memorize. This seems to be random and wrong. Guess I need to unarchive the file and search through it for where that random location is stored and do all the other hard work :-(
    If I resave the object as a scene subset at 0,0,0, it does not work either. When I reload the figure and try to apply a 0,0,0 pose, it takes it to the same X,Y,Z location as the one before saving. A rather blatant bug in my opinion.
  • Wow. This truly is a button/feature DAZ needs to add to their app! To be causing issues EVERY YEAR OR SO as Don Davis stated above.
    IF your model whatever it is, be it a girl or a prop gets pushed or pulled off its 0-0-0 coordinate in DAZ, simply hit Parameters then choose your model. From there you will notice one or more of the X Y Z coordinates are NOT 0Do something about that... then have joy.
  • Wouldn't that be nice? Still not in 4.22. Put a set of high heels on girl and watch the numbers go wacky. When exporting FBX the body goes to 0 and shoes go thru floor and gets all bent out of shape.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,127
    edited January 2024
    there are a few scripts floating around to do this Richard Haseltine needs to add to his scripts list if I can find them all
    https://sites.google.com/site/mcasualsdazscripts9/mcjzeroorigin
    is the only one out of the 3 I have that I can find a link for
    the others do slightly different things
    RH has linked
    http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/nodes/node_origin_center/start
    Stem at home made https://hpclscruffy.daz3d.com/forums/discussion/comment/7413816/#Comment_7413816 a useable version
    and both alan bard newcomer and myself have multiple threads asking for this that come up in search wink without answers which did not help searching Google
    I did find an older veriosn that displays the movement arrows at its location.
    And while the object in question s a prop its a window with a set of morphs to raise and lower it's sash, its shade, and open a close a set of curtains.
    but it's loaded via a duf file.
    certainly there is data the tells the program where to load it and it's loading at x-10, Y+23, z-38 there must be somewhere to say set x, y, z to zero?
    In this particular case the drag transfer gadget is miles away from the object which if i"m replaceint a 100 windows gets time consuming.
    I  removed all the windows from thise stonemason bldgs and dragging windows into place from 8 inches away from where the window was loacated was a "real drag"
  • PetipetPetipet Posts: 130
    edited April 2
    I also had a problem installing pivot and I wrote this script, maybe it will be useful to someone. Please try it. Video :
    zip
    zip
    ResetPivotAndMemorizeUniversal(Eng).zip
    1K
    Post edited by Petipet on
  • Use Richard Haseltine's method, but while in Blender:
    Go into Edit mode by hitting the tab key.
    Clear all selections by hitting alt-a.
    Hit 1 ( the 1 not the numpad) to select vertices.
    Either
    a) select the vertex you want to be at the origin and hit shift-s 2 to move the cursor to that vertex
    or
    b) Hit n and go to the view tab and move the cursor wherever you want the origin to be, it doesn't have to be a vertex
    And here's the part that was left out:
    Hit tab again to go back to object mode
    From the menu bar near the top of the screen, select Object, Set Origin, Origin to 3D Cursor
    Then export to object back to DAZ, as Richard said.
  • There's a product in the store that is really useful for moving things wherever you want them to be, all but automagically https://www.daz3d.com/face-to-face-and-virtual-origins
    thanks, so many products and great utilites and I bought  them . . . now i have to remember to use them, particulary ones like this that I own. duh.
