Adding to Cart…
The things that I'd like to add to that are:
UV set swapping. That way you can still use the old textures, but you could also switch to a new UV set that's laid out more like the Genesis figures. That would make creating textures in general and making higher resolution textures easier. I know how to UV map, but I've never done anything as complex as the generation 3 figure, though.
Geograft. I understand the basic concept of how it works, but don't know how to actually do it. Plus, I don't know if there's something about how the Generation 3 figures were created that might prevent them from working.
Like I previously stated, I was thinking about also adding HD Morphs, but there are a couple issues with that, so I don't know that it's necessary. I know this technology is proprietary and only PAs have access to it, so that's not something that the general public could do. Also, it is meant to be used with Sub-D on a lower-poly mesh.
One of the things that has confused me is the fact that over the years, on certain technologies when they came out, they would state, "this technology only works on single mesh figures". But what does single mesh even mean? Because if you take it literally, even Genesis isn't a single mesh figure, because the eyeballs, eyelashes, and teeth are all separate meshes, they're not actually connected to the main mesh of the figure.
UV swapping is something I had forgotten about. Which is silly, because I have done it [once] on a model of a fountain pen, and I've never done anything so complex either. Coping with the different areas from each generation for the material zones means it might be best to use a fit suit and hide the Gen3 character.
Geografting is something I have done twice, and vaguely understand. What would they be used for? That's the bit I'm not sure about. When TriAxed or General weight mapped the character is not a Generation 3 character, it just uses a Gen3 mesh, so there shouldn't be anything to prevent it working.
HD morphs are something we couldn't do.
As far as I know, Gen3 is welded on loading into DS into a single mesh. Don't think it's something we need to worry about.
Regards,
Richard.
