Genesis 9 Eyebrows not exporting
hello, im new here, im trying to export my figure on fbx so i can animade it on clo3d with the clothes i created there, the problem its that daz is not generatin the eyebrows, when i check the texture maps they're not there but when i look for then on the surface editor on daz the eyebrows doesnt apear on any daz studio folder on the system, how can i export the texture of the eyebrows with the fbx object please?
  • Richard HaseltineRichard Haseltine Posts: 112,099
    Fibre style means they are made of lines, not polygons, and those don't export reliably. Use a card style eyebrow instead.
  • lilweeplilweep Posts: 2,883
    unless you intend to render in CLO, is it actually necessary that you have eyebrows for your simulation?
  • crosswindcrosswind Posts: 10,359
    You need to go to the Scene tab in CLO3D, select Mesh of the Eyebrows, set its Opacity to 100% ~
    Check this post of how to set it : https://www.daz3d.com/forums/discussion/comment/9353881/#Comment_9353881
  • GordigGordig Posts: 10,849
    False. Fiber-style eyebrows - at least in terms of the ones that come with G9 - are fibermesh, meaning that they are made of tubes of geometry. It's not impossible that some PAs incorrectly label dForce/strand-based eyebrows as "fiber", but that's not what the term means.
    Thanks, and sorry for getting it wrong.
