Is This Surface Master Tutorial still relevent?
IceDragonArtIceDragonArt Posts: 12,954
https://www.daz3d.com/ds-surface-master-part-1 ; Would this still be useful given all the changes to Daz recently? Specifically the Alpha  version, although I believe changes have been made to how lighting works in 4.24 as well.  Not sure if the shader information is still valid either
  • nightwolf1982nightwolf1982 Posts: 1,239
    I doubt it will be relevant for DAZ Studio 4.24, after 3delight was removed.  If you have an older version of DS from before 3delight was removed it might be helpful.
  • IceDragonArtIceDragonArt Posts: 12,954
    I was afraid of that.  don't know why the link all of a sudden doesn't work, its in the shop under one of the special categories for march madness.
  • TorquinoxTorquinox Posts: 4,494
    The link has some garbage on the end. That happens sometimes when sharing links in the forum.
    Thanks!
  • CybersoxCybersox Posts: 9,524
    There's a lot of 3DL product still being hawked, which I would think would at least need a disclaimer on things like shaders stating that they probably won't work in future versions of DS.
    edited March 11
    The fancier shaders likely won't work properly in the present versions of DS. I say likely because I've not installed 4.24 without 3DL or any of the next version alphas.
    Post edited by Torquinox on
  • vrba79vrba79 Posts: 1,548
    Daz3D really should delist that stuff.
