New Year, New Sales Thread: Report Issues Here 3 "Reporting Only"
19192949697100
  • Richard HaseltineRichard Haseltine Posts: 110,955
    Richard Haseltine said:
    Wolfwood said:
    jeffbdvs said:
    I'm puzzled why there's no discount on the London bus shown in my attached screenshots. Is it because it's a Daz+ item and I'm not a member? If so, then the main March Madness shop page is telling porkies.
    Is not because you are not Daz+, i also see no extra discounts except the 'star' when added in cart even with a new mad.
    Last december, during christmas sale happened the same. Daz+ items were included in featured artist but discounts were not applying. Richard had to flag the issue.
    I will ask, though it is as likely to be that it shouldn't be included as that it ought to have a discount.
    Seems to fail with any + item, I have sent in an enquiry.
    Fixed to work, by the look of it.
  • jeffbdvsjeffbdvs Posts: 53
    edited March 4
    Thanks to both of you. It's fixed now. I appreciate it.
    Post edited by jeffbdvs on
  • Star discount for Andre appears to not be working or star isn't activating for account? No idea.
  • NathNath Posts: 3,035
    I'm not seeing star discount either and I purchased both yesterday and the day before
  • I have a gold star.
    Andre is coming up as $6.05 instead of $2.99.
  • Rod Wise DriggoRod Wise Driggo Posts: 2,340
    Yup, all discounts are kind of broken. Not matching the last days although I have the necessary stars.
  • CybersoxCybersox Posts: 9,758
    I was going to pass on Andre anyway, as being a morph only character where one can't even dial out the pointed ears makes him of incredibly limited utility.  However, I put him in my cart to check and he's showing at $3.33 after 8 tokens and with a new item in the cart, so there's definitely something wrong with the way his pricing is being calculated.
  • Cris PalominoCris Palomino Posts: 12,905
    tjcall_88c6a765f8 said:
    I have a gold star.
    Reported.
  • 30% off Newly Mad Releases not working either
    Should all be working now.
  • Charlie Judge said:
     This bundle is included in the Premier free charcter bundle selection. Is this a mistake? It appears to be a PA item and not a DAZ Original.
    It's been removed. I saw it yesterday and wondered what happened. They had 2 or 3 joint PA/DO bundles in the selection last fall (Lunardo 9, Cider Brewery, etc.) but those had more than 2 items.
    jmucchiello said:
    MAD-METRO has outlet items in it that cost $0.99 in outlet but $1.99 with coupon. (Actually, some of them aren't even in the outlet. They're just discounted to $0.99 before applying the coupon.)
    https://www.daz3d.com/mikaela-for-victoria-7
    https://www.daz3d.com/de-michelle-for-genesis-3-female
    https://www.daz3d.com/tresne-for-genesis-3-female-s
    https://www.daz3d.com/dt-karen-for-genesis-3-female-s
    https://www.daz3d.com/nora-for-genesis-3-female-s
    https://www.daz3d.com/elsa-for-genesis-3-female-s
    https://www.daz3d.com/razor-cut-bob-hair-for-genesis-3-female-s
    https://www.daz3d.com/desiree-for-victoria-7
    https://www.daz3d.com/the-common-man-poses-for-genesis-3-male
    https://www.daz3d.com/music-and-jewelry-boxes
    And a bunch more. I had to dump most of my cart to get the one thing I wanted to use the coupon on to the top of the list.
    It's not just Outlet items that are an issue, although the inclusion of those is beyond sloppy at this point.  Since MM began, I've found that a large percentage of the items in many of the recent ancilliary sales have ended up being significantly cheaper without the coupon than with it, and it's especially common in sales that discount to a fixed price point.
    Those were DAZ Original bundles, though, which usually means thatDAZhas given the PA a buyout price.  This product was a purely PA bundle, and while I can't say for certain what the specific deal on those is, I do know that if I was a PA, I'd have very little interest in giving away something that represented so many hours of work as the contents of a bundle, especially when the purpose is to service the needs of a program that primarily benefits DAZ.
  • erostewerostew Posts: 240
    MAD-PERFECTION for the Mad Door Prizes isn't working for me. "Coupon Not Valid" error.
  • SilverGirlSilverGirl Posts: 3,780
    edited March 5
    PICK-UR-PERF not working on item that meets criteria specified. Coupon invalid.
    Post edited by SilverGirl on
  • Singular3DSingular3D Posts: 658
    edited March 5
    PICK-UR-PERF doesn't work for me either. Coupon code is not valid.
    Post edited by Singular3D on
  • deepred6502deepred6502 Posts: 439
    Same here with PICK-UR-PERF.
    Should be working now.
    And it certainly does.
  • JDORJDOR Posts: 16
    No, not fully. It now only works on one item. Not the additional items if you have Newly or Still Mad items in your cart.
    Checking.
    Hmmm...I'm seeing it work. Can you post a screenshot of your cart?
    Only the beach changed price, the other two remained the same as when the code wasn't working
    1112 x 893 - 180K
  • Halcon BlueskyHalcon Bluesky Posts: 723
    I concur, Same here with PICK-UR-PERF.
    edited March 5
    From our end, it appears to be working. Make sure you have the correct requirements for what you want to buy. Otherwise, prolly a ticket.
    Post edited by Cris Palomino on
    It clearly isn't.
    The requirements are with a Newly Mad (in my case the X-Fashion Denim Jumpsuit) you get 50% off up to 3 items.
    I... WAS... only getting 50% off one of them. $9.30 - with code reduced to $4.65 (as per my screenshot). The other two items, no difference.
    However, I am now not getting any discount on ANY items again. Just "coupon code is not valid" and Tropical Beach has increased to $9.30 again
  • memcneil70memcneil70 Posts: 5,990
    Cris,
    I am also getting the infamous 'coupon code not valid' statement when I tried. I have taken items out, deleted my tokens, tried a variety of combinations and verified they are all today's and yesterday's products.
    Cart - 5 Items
    MbM dForce Whimsical Dress Bundle
    new recent best $34.99
    $49.99$16.0668% Off
    Add Interactive License
    Add 3D Printing License
    Retro Reverie Outfit for Genesis 9
    new recent best $12.59
    $20.99$5.7872% Off
    Bare Minimum Poses for Genesis 9
    new recent best $11.89
    $16.99$5.4668% Off
    dForce LV Retro Vogue Outfit for Genesis 9
    new recent best $13.79
    $22.99$6.3372% Off
    L3D Colors Add-On Textured Strands
    new recent best $11.39
    $18.99$5.2372% Off
  • felisfelis Posts: 6,440
    memcneil70 said:
    Cris,
    The code does not work on Newly Mad and Still Mad, they only work for triggering it working on up to 5 items.
