New Year, New Sales Thread: Report Issues Here 3 "Reporting Only"
18384868889100
  • Yup, yesterdays coupon worked on new releases as well. Todays doesn't.
  • Cris PalominoCris Palomino Posts: 12,891
    Charlie Judge said:
    There are no exclusions shown but the WISHY-TUESDAY coupon is not working for new items. Please fix..
    I've sent an inquiry.
    Should be working now.
  • NathNath Posts: 3,021
    Today's sale page offers 'angelic offerings' and 'demonic dealings' (up to 3 for 4.99 each with any 'divine' new release) don't appear to be working. Items remain full price in cart.
    Report sent.
    Should work now.
    Cris Palomino said:
    Should work now.
     It does, thanks!
  • Does the Flash Sale not work with Daz+ New Releases? I have both of yesterday's D+ new releases in the cart (which I did put on WL yesterday) plus an older dress from the flash sale selection that I've had wishlisted for a while. The dress appears to get the correct 75% discount for being in my WL. But it doesn't appear either the dress or the New D+ items are getting the extra 30% off for having those 2 New Releases. The D+ items should drop to the $2.99 floor price if the store was discounting correctly and New D+ products aren't an unmentioned exclusion.
    (I don't think the screenshot shows it but the coupon was applied)
    800 x 1280 - 139K
    800 x 1280 - 384K
    800 x 1280 - 161K
  • xyer0xyer0 Posts: 6,486
    Guess what? TOP-NOTCH doesn't work on any New Release in my cart, and I have three.
  • vwranglervwrangler Posts: 5,019
    edited February 18
    Neither part of the TOP-NOTCH flash sale coupon works with a new release in the cart as stated. It doesn't reduce the cost of either the new release OR any of the other flash sale items in the cart by the stated 30%.I tried it with a Daz+ new item, and when that didn't work, tried it with another new item, and that didn't work either.
    The 50% off any item and 75% off wishlisted items DOES work as stated. It's just the new release effect that doesn't work.
    flash sale problems
    1481 x 603 - 120K
    Post edited by vwrangler on
  • CybersoxCybersox Posts: 9,737
    edited February 18
    Verifying that the Top-Notch flash sale, the advertised" additional 30% off both the Flash Sale items and the "new" items added to the cart" does not seem to work.  With 8 tokens and 4 items that were on my wishsale prior to today, plus the coupon, I'm seeing the same 82% discount on the flash sale selection and no discount on the new tiems no matter which new items I put in the cart.
    Post edited by Cybersox on
  • Ron KnightsRon Knights Posts: 2,669
    edited February 18
    Seems to me that the Top notch Flash sale is wrong.
    It mentions your wishlist, but does not bring you to your wishlist.
    I followed the provided link and only found one item in my wishlist.
    929 x 481 - 516K
    Post edited by Ron Knights on
  • rollandrolland Posts: 23
    TOP-NOTCH works for wishlisted (prior to today) items but not not on New Releases
  • Reported the failure of the extra 30% offer for the flash sale.
    If I load the cart with a flash sale item plus three new items and apply the TOP-NOTCH coupon, nothing happens to the new items. BUT if I delete the flash sale item, THEN I GET THE EXTRA 30% OFF THE NEW ITEMS. I'll take it!
    This has been fixed.
    edited February 18
    But Top-Notch doesn't bring up my wishlist.
    It's not supposed to.  It's a general sale that happens to give you an extra discount if one of the items in the selection happens to be in your wishlist, so it goes to the sale category and it's up to you to see if anything on your wishlist is there..
    There is a filter check-box to show only items on your wishlist in the top bar of the store list, alongside Hide items I Own and Show PC+ Only
    This is needlessly confusing.
    In the past I was told the "add" page would show the proper eligible wishlist items. In otherwords, don't go directly to the wishlist.
    So now we got to the "default" link and search for wishlist items?
    It is the same advice as before - go to the category. However, now you can use the check box while in the category to see only the items that are also on your Wishlist.
  • ElorElor Posts: 3,947
    edited February 19
    I don't see any discount on the various items included in the four 'Incredible generations' selections: they are supposed to have a 60/70/80 or 90% discount, but they have none in my cart:
    https://www.daz3d.com/wheres-my-super-suit#incredible
    I picked the first non-DOs items of each selection (the first item is from the first selection, the second from the second, etc) and from what I understand, they should have, respectively, a 60% / 70% / 80% / 90% discount, but don't:
    727 x 558 - 48K
    Post edited by Elor on
    Discounts appeared after I put in a "suitable" debut, but still not correct. Reported.
  • jmucchiellojmucchiello Posts: 1,728
    edited February 19
    Same, I put a suprising super in my cart. And it went to 30% off. Not 80%.
    Two weird things about that. This G2 item in my cart https://www.daz3d.com/the-hero-and-the-damsel-poses is probably getting the 30% for "New Supers" (as there is a new release in my cart). But I would also think a G2 item would be 60% for being a "Veteran Supers".
    EDIT: Never mind that last bit. I thought the New Supers and Veteran Supers was generic, not a specific set of items. Thus, I can't explain the 30% instead of 80% at all.
    Post edited by jmucchiello on
    edited February 19
    Should be working now. Edit: works without needing the DNR.
    Post edited by Cris Palomino on
  • JDORJDOR Posts: 16
    I'm only getting 30% off "Veteran Super" items even though I have a "Suitable" item in the cart, not the 60% as advertised
    1072 x 684 - 135K
    It does, thank you :)
  • FJM1977FJM1977 Posts: 332
    same for me
    The super category has been reported.
