just an observation - omni hair shaders don't render in DS 6 Alpha 6.25
Like it says in the subject line.
I have an RTX 5080 so I am running DS6 (I mean, I don't *have* to run on GPU, but I get better renders than if I use the CPU).
I notice that while omni shaders are aplied correctly, from insecting the details in the Surfaces tab, I don't get them rendering correctly - mostly coming out black.
Is this just me or is this a quirk of the set up, or whatever ?
  • Richard HaseltineRichard Haseltine Posts: 111,816
    The base shader or the material sets for it?
  • lilweeplilweep Posts: 2,879
    you probably dont have the shaders installed in your shader folder.  i dont mean the .dsa i mean the .mdl
  • OK, I'm using 3rd-party Omni shader sets for hair, and I have the base Omni shader.  I apply the Omni then I apply the colour shaders, but the hair remains black.  I can manually change the settings in the hair shader tab, but was just wondering why none of the hair shader collections work. Those were working fine in DS 4.
    Have you checked the log file after apoplying the shader and prset, and after trying to render?
    go to C:\Program Files\DAZ 3D\DAZStudio6\shaders\iray\OmniSurface
    and check you installed them
    also check your driver?
  • edited February 7
    Thanks for reply.  I do have the MDLs installed and I am using just an example hair ( the issue occurs with all hair using omni shaders ).  There appears to be no issue with the rendering process.
    Post edited by ibr_remote aka infinity10 on
  • No matter which colour I apply, the hair always renders black.
    615 x 597 - 235K
  • edited February 7
    There is no error or unusual report in the log file after rendering, either.
  • edited February 7
    923 x 311 - 36K
    970 x 789 - 403K
    782 x 852 - 148K
    What does the editor tab of the Surfaces pane look like after applying the shader preset?
    Here we go...
    1076 x 885 - 339K
    select one of the surfaces that should be changing (click with the Surface Selection tool if you can't deduce that from the names), currently the shader is given as <Multiple> which doesn't help with diagnosis.
  • Here are screenshots showing the tab for each part of the hair
    993 x 884 - 264K
    995 x 879 - 261K
    995 x 874 - 264K
    997 x 874 - 262K
    993 x 880 - 263K
    995 x 878 - 261K
    991 x 883 - 269K
    994 x 879 - 261K
    OK, it looks as if the right shader is applying which is one potential issue out of the way.
  • Just for the sake of showing that the shader application problem exists across hair products, here's the Lauralei Hair with the white shader applied.  DS6 alpha has some issues interpreting the sahders.
    927 x 803 - 226K
