New Year, New Sales Thread: Report Issues Here 3 "Reporting Only"
1…7576788081…100
  • mrpenguin76mrpenguin76 Posts: 120
    edited January 31
    KAPOW50 Coupon does not work for me with 3 Fuse New Releases and 20 Wishlist Items.  It says "Items must be on wishlist prior to January 31" which I added all 20 of these to my Wishlist directly from the Store-Wide Blowup page yesterday, and they are still part of it today, so there is no reason the coupon should not be working.  UNLESS it is either a recycled coupon? or It is NOT counting Items added yesterday and is still using the 30TH as the "Prior To" date.
    Anyone want to place bets on this being fixed in the next three hours?
    Just tested it with Only 5 Wishlist items, and ONLY 5 from the Store-Wide Blowup page and it doesn't work with those either.
    Post edited by mrpenguin76 on
  • Cris PalominoCris Palomino Posts: 13,062
    The KAPOW50 works for me, but my wishlist is much older items. Could you try items that are older to see if that works so I can try to pinpoint the issue?
    edited January 31
    I can't, I bought all my wishlisted items that were dated before the 30th during yesterdays sale. So I can only add WL items that I put in yesterday, which if its working for you then it must still be locked with a prior to the 30th, and not the 31st.
    I'll try to query.
    They had the wrong date on the KAPOW50 coupon.
    Still doesn't work for me, so I assume they are going to change the "prior to" the 30th.
  • FrankTheTankFrankTheTank Posts: 1,632
    I can't use a Premier $10 coupon on a cart load of January Flashback items. All of these items should be eligible, none of them are new, none are in QG or OC, none are at their respective floor limits of $3.99 or $2.99 yet, so there is enough wiggle room that I should be able to use the coupon.
    1662 x 1746 - 721K
    1673 x 672 - 177K
    I've sent Daz a note as I believe the disclaimer is incorrect again. The same disclaimer last night says this does not stack. This should also is what I'm thinking.
  • PixelPiePixelPie Posts: 385
    Your code THUNDER50 doesn't work even when I put multiple new sales items in the cart.. It is late here so just thought I would let you all know
    1010 x 864 - 134K
    1300 x 873 - 361K
  • Same problem with THUNDER50. I've tried various combination of just 3 wishlist items, and it does not work for even those.
  • CybersoxCybersox Posts: 10,038
    Not exactly the New Sale, but the Outlet section has suddenly been emptied of all but 12 items as compared to the several hundred that were there yesterday.
    I'll send a query.
  • XelloszXellosz Posts: 855
    I'll send a query.
    1st of Febr on weekend.
    ROCKET50 Does Not Trigger the discount for 20 Correctly if using a "Fuse New Release" from Yesterday or Friday, (ie anything below the first line) It does trigger for 20 if using one from today.
  • memcneil70memcneil70 Posts: 6,206
    I hadn't really looked at the sales options so I went back after looking at this thread and noticed one of the FUSE offers for buy 3 new get 20% off and it applies to Gift Card too! So I added a gift card and as I looked at the shopping cart, I was hit with a question.
    I know gift cards have to be paid by credit cards, but the other items, can they be paid by my existing store credit?
    Mary
    @Mary Sadly no.  If you have a gift card in your cart it will ignore store credit.
    Thanks for answering @mrpenguin76. Although I have been buying gift cards for a long time, this just happens to be the first time I ran into this choice.
    Mary
  • Richard HaseltineRichard Haseltine Posts: 112,078
    Is that still affecting the new code? I don't have any older items on my WL to test.
    Mary
    Yeah, it's a pain, but it's one of those occasions where I can totally see DAZ's logic, as if you could buy a GC for $100 at a 20% discount, you would pay 80 and could then turn around and use the resulting $100 store credit to buy another gift card for $125 at the same 20 discount and just keep repeating that process with increasing larger amounts each time until you had a DAZ Gift Certificate large enough to pay the national debt for a cost of $80.  (Please do not pass this concept on to any politicians, as one of them is likely want to use it as part of their platform pitch for the next elections.)
    Yes the new code "SURGE50" is doing the same thing as Rocket50 was, only giving a discount to 5 of the 20 with yesterday and Fridays. Any combo of old three also still triggers the 20% as it should, and was with ROCKET50.
  • rokkrrokkr Posts: 407
    Nowhere here does it say that Fuse items, new items, or any other item is excluded from the sale, except items added to the wishlist after February 1st (the latter date included):
    "Use code:
    SURGE50
    Extra 50% off up to 5
    Store-Wide Blowup items from your Wishlist
    OR up to 20* with any “Fuse” New Release
    Items must be on wishlist prior to February 1.
    *Items must be simultaneously in cart for discount to apply."
    But I've put 3 Fuse items in my cart, added to the wishlist no later than January 31st, but the coupon doesn't work.
  • felisfelis Posts: 6,656
    I would assume that they need to have been added no later than 30th January, and neither be new.
    edited February 1
    @rokkr you need to click on the Orange "Store-Wide Blowup" text under the code to be taken to the page that will show what is eligible and then filter by wishlist. In others it's not our "whole" wishlist that is avaible for the code.
    MASSIVE50 is currently Invalid.
    Completelty or the same not seeing an olfder Fuse item as enabling the twenty item limit?
    Yes, the text was fixed yesterday so I am not sure why it is wrong now.
    edited February 1
    No it's not working with any of todays "Fused" nor the older ones. So I assume it is probably not working to trigger the just "5 wishlist" without a new release.The earlier coupons today never popped invalid, at least for me.  I would test the "5 wishlist" but I don't want to have to rebuild this cart.
    ***nevermind that rebuilding the cart, I'm getting tired lol, I threw out the new fused releases to test for the "5 wishlist" and the coupon did fail for that too.
    We are told that the WL code is now fixed, please gie it a whirl.
    edited February 1
    Still a NoGo for me.
    Also logged out, Closed browser and then got back in, same thing so shouldn't be a cache issue.
    Even for the base five items? Do you havea  screenshot of the cart?
