UltraScenery - new(er) territory [Commercial]
1616263646567»
  • memcneil70memcneil70 Posts: 5,441
    barbult said:
    memcneil70 said:
    Artini said:
    What an extraordinary animal. Another reference video for our renders.
    I turned around and had two Gingers staring fixedly at the screen at that video. I hope they weren't taking notes.
    laughlaugh I'm sure they committed it all to memory and don't need any notes. You are doomed. I think yours have a few tricks of their own that they could offer up for the next video.
    They disappeared into the flatmate's bedroom (I had my bedding in the wash today) and refused to come back after the bed was made. When the flatmate returned from work, Simon arrived, then Charlie. I walked into my room to find Charlie hugging scrunched up folds of my orangie throw between his paws and next to his chest. Now he and Simon are sitting on opposite sides of the bed, with Charlie in possession of the throw. Weird. He has avoided it in the past. He is also looking like a Bob Cat right now.
  • barbultbarbult Posts: 26,396
    edited December 2025
    This is just another view of the Snake Bridge 07 that I posted earlier. See the extra water that I added? I just duplicated and moved the UltraScenery2 water. It is there in the other render, too, but not very visible.
    UltraScenery2 Woodl;and 1 Snake Bridge 07 Boat Highlands Mounds and HDRI_002_Camera 3.jpg
    2000 x 1125 - 2M
    Post edited by barbult on
    And here is a closer view of the bridge.
    UltraScenery2 Woodland 1 Snake Bridge 07 Boat Highlands Mounds and HDRI_Camera 2.jpg
    2000 x 1125 - 2M
  • ArtiniArtini Posts: 10,392
    Looks nice, @barbult and thanks for the tips about the lights.
  • Anyone else having issues with Ultra Scenery not appearing in Daz 2025 public build? No script, nothing and if you load an old scene the land form appears, but no foliage even when rendered. Has there been an update? I know there were some issues with older scripts not working in Daz 2025....
    edited January 21
    Scripts and plugins are not expected to work yet in the DS 2025 Alpha. UltraScenery is just one of many that don't work. DS 2025 is still evolving too much for PAs to finalize any script updates, I am told.
  • felisfelis Posts: 5,970
    edited January 21
    Many scripts and all plugins (as I understand it) will break in DS 6. And if they get updated it most likely will not be untill DS 6 is in beta, to avoid having to redo some changes again.
    And whether the update will be free or cost extra is up to the PAs. There are some scripts that will not be updated as the PA is no longer active.
    Post edited by felis on
  • Thank you, I was afraid that that was what it was. I'm trying to get a book cover done that uses USX in the background, (And has some VBD clouds, etc) and things are grinding to a halt in 4.24 so I was hoping 2025A would work. Well, back to the drawing board. Render each piece separately and then composite.
  • davesodaveso Posts: 7,883
    I've already made my mind up to not upgrade. Probably not even the next 4.xx as well. As long as what I already have works. If it stops working, I will do without.
    I don't expect any updates to DS 4. All development is targeted DS 6.
  • jjoynerjjoyner Posts: 762
    I agree with you wholeheartedly.  I do have DS 2025 ALpha running alongside DS 4.24.0.3 but only to play with it as it develops.  I'm not upgrading to DS 4,24.0.4 because it drops 3Delight rendering.
    there is one now - DS 4,24.0.4
    And that came in December, to remove 3DL before year end.
    Yes, they did give warning to save your back ups if you wanted to use 3DL in the future. Which I did, as well as renaming the folder that houses the old DS. So I can still use it later. I did update, and if I break the render into foreground and UltraScenery background, I can render each part finally.
