Can't install this third party character
Hello,
I wonder if files are missing from this third party character or simply I'm not installing it correctly
thanks for help.
https://www.patreon.com/posts/cp2077-panam-for-146187368?utm_medium=clipboard_copy&utm_source=copyLink&utm_campaign=postshare_creator&utm_content=join_link
  • OlloOllo Posts: 19
    edited December 2025
    Hello!
    I was wondering if there's a correct way to install third party charactes since I tried and failed by just placing the unzipped folder of the Genesis 9 character in Genesis 9 charactes folder and apparently it doesn't load the textures when I open the character.duf
    Post edited by Ollo on
  • Jan_ScrapperJan_Scrapper Posts: 798
    Since I install everything manually anyway, put your zip file in a folder with the name of your character.  Unzip it there.
    You should have three folders.
    Data
    People
    Runtime (which contains the Texture folder)
    Find your Daz Library in Windows Exployer where you have your other Genesis 9 characters.
    There will be many folders there and including Data and Runtime.
    Move your new character's Data and Runtime there.
    Open Daz Studio again and your everything should be in it's proper place.  I have attached my Genesis Daz Library.  I actually have many Daz Libraries.
    You can see highlight where I have my Genesis 9 products AND where the Data and Runtime folders are.
    You should always keep a copy of your purchase somewhere else in it's original form as a backup.  If you have an external drive, you can put it there.  If you have Microsoft One Drive, put it there.
    1396 x 1013 - 195K
    Post edited by Jan_Scrapper on
  • felisfelis Posts: 6,600
    I have just tested it in a test library, and she works.
    But the file structure does not follow the general concept overall.
    To find her you must look in your content library, as the product doesn't have metadata. It is also a little weird, that there is only a scene subset with her including her hair.
    Tell more about what you are doing and where you are looking for her.
    Post edited by felis on
  • Merged the general thread and the thread about the specific character.
  • I just saw this listed with the product:  The OG model was completely broken so I re-made it.
