Solved: Rag Doll posing
MarcCCTx
Is there some way to apply a rag doll effect to a character? Like dropped over clutter on the ground, or thrown against a wall, or hit by a car? Something like dforce for creatures, especially clothed figures.
Post edited by MarcCCTx on
This is what the Victoria AI said...
A Static dForece Modifier dosn't chnage shape - hence the name. You would want to aply a Static dForce Modifier only if you wanted to adjust settings, mainly friction, that control how the surface interacts with dynamic modifiers (all objects that are included as collision targets have an implicit Static dForce Modifier with default values, so thjere is no need to do anything with those). That sounds more like a somewhat garbled version of getting surrounding objects (e.g. soft furnishings) to react to the figure.
This isn't working. No matter the setting he isn't falling down on the crate.
If you buy a used copy of Poser 12 ( or higher) there is a free ragdoll simulation plugin
for it via a FREE third party python script
https://bitbucket.org/PhysicalcSoftware/poserphysics/src/master/
I used it to create these ragdoll animations that I retargeted to G9 with another FREE script from Renderosity
@wolf359 Would you be able to share the name of the retargeting script from Rendo? Tried to find it myself with no luck.
You could also try Cascadeur, the free/base version should have ragedoll physics (I don't have the free version to test).
Get it here
https://www.renderosity.com/freestuff/items/93511/genesis-1238-pose-converter-for-genesis-9
Thanks Wolf359! I glossed right over that one ;)
