New Year, New Sales Thread: Report Issues Here 3 "Reporting Only"
1…3334363839…100
  • FJM1977FJM1977 Posts: 350
    Renha said:
    So how do I use MID-FRIDAY now, which is according to oferta is still active? I'm fine with applying it retroactively to my previous order instead, I guess
    It isn't active.
  • The BUNDLED code is for starter bundles only - does anyone know what counts? Does it have to have "starter bundle" in the name?
    The BLACK-OUTLET code is for the Outlet Store (not quick grab) and it DOES work
  • RenhaRenha Posts: 24
    False, see the attachement. If something is broken on the DAZ side that their offer which is very much displayed and hence active, it is to be fixed, please don't galsight me, I can read.
    FJM1977 said:
    It isn't active.
    2245 x 1813 - 845K
  • ElorElor Posts: 4,160
    edited November 2025
    The bug is not the coupon not being usable right now, it's the website still showing it.
    Post edited by Elor on
  • mcpughmcpugh Posts: 105
    Richard Haseltine said:
    mcpugh said:
    Same [issue] with "BUNDLE" code.  I mean why bother and waist our time?
    The code is BUNDLED, not BUNDLE.
    Well, I simply copy and paste from what's provided.  BUNDLED didn't work either and now lunch break is over.  Thanks for trying.
    If offer is displayed as active, it should be available to be used
  • Welcome to the DAZ shop lol.
    For BUNDLED, I just typed "starter bundle" into search, it worked on 2 of the more recent ones, which were the 4 horsemen and monster mashup bundles, didn't test anything else.
  • i think your sale is broken. codes don't work just say invalid, and i have no clue how to find the 10 for 1.99 or .99. or the bundles available for 9.99 or 5.99. it's so broken i'm not even bothering looking no further. so i won't be buying nothing today :0(
    I don't know if there is a link with all the Starter Bundles, but for the other code, it's the outlet store:
    https://www.daz3d.com/outlet
    Pick up to 10 items from here and all will be at $0.99.
  • jme4500jme4500 Posts: 27
     The main DAZ store page is displaying the previous 6 hour offer and codes in error.
    The current offers are:(1)  10 Outlet items for 1.99/99c each (select Outlet window in top centre of main store page to see available items) uses code BLACK-OUTLET and it does work.
    (2) Starter bundles for 9.99/5.99 I guess type STARTER BUNDLE in search and use code BUNDLED. Not tried it myself.
    Ah, now DAZ store gives the correct offers and codes. :-)
    Post edited by jme4500 on
  • jmucchiellojmucchiello Posts: 2,319
    Ends 18:00 MST, 01:00 UTC on 29/11/25
    What qualifies as a starter bundle?
    Sorry, I don't have a link - or any more details. I would assume anything that is a Daz original with Starter and Bundle in the name, but don't quote me on that. Few if any Genesis 9 characters have Starter Bundles now, even the oens that were initially released as Starter/Pro have since been split into Character/Add-on.
  • xyer0xyer0 Posts: 6,515
    TSS*
    *this store sux
  • csaacsaa Posts: 1,082
    Brian&Alicia,
    I've been able to make good use of the sales so far. What's worked for me is to do the following before purchasing anything:
    1. Log out of Daz3D
    2. Clear my web browser cache, removing web data for the last 12 hrs
    3. Log back into Daz3D.
    I don't have any premium membership like Daz+, so everything I bought was at the base discount (i.e. $1.99 not $0.99 per item).  To pick out the Outlet items ...
    You won't make the most of the Outlet sale unless you purchase the most expensive items. So sort your list from highest $$$ to lowest. For me, the most expensive ones came to about $10 a piece. Add any one to your cart, then use the BLACK-OUTLET code. This will apply the discount, reducing the price down to $1.99 for each item (or $0.99 if have a Daz+ membersip).
    I didn't buy any starter bundle, but I assume the code below also unlocks that discount.
    Hope thi
    Cheers!
    1024 x 339 - 206K
    1024 x 536 - 239K
    Post edited by csaa on
  • XelloszXellosz Posts: 855
    Checked a lot of HD bundles. Those don't work.
    MY tip:
    0./ Filter for bundles (Only bundles) and probably DAZ  only, so filter the artist too for DAZ original.
    1./ Throw a lot of bundles in your cart that you want  ( the names probably should have starter in it, but test it with others if you want)
    2./ at the end, throw https://www.daz3d.com/monster-mashup-for-genesis-9-starter-bundle in the cart,
    3./ then use the code BUNDLED.
    The price of the https://www.daz3d.com/monster-mashup-for-genesis-9-starter-bundle would change. So if anything before it could be used with the BUNDLED code, then the https://www.daz3d.com/monster-mashup-for-genesis-9-starter-bundle price will stay the same, and you've got yourself a bundle before it in your cart on which the code could be used other than the monster-mashup.
    4. / Open that bundle in a new page
    5. / Clear your whole shopping cart (Don't bother throwing things out 1 by 1)
    6. / Put that bundle back and use the code BUNDLED
    This is trial and error. (ps: Over 20-25 items, the cart is usually slower, so you have to try it a few times before succeeding.)
  • This one seems to have updated anyway, but in case that was just luck:
    Use code:
    FRIDAY-TOOLS
    Get 90% OFF any 1 'Select Tools & Effects' Item
    OR 90% OFF* up to 3 with any “Shopping” or “Still Shopping” New Release
    https://www.daz3d.com/toolsgiving#index=0&order=popular^1&filtered=1
    This was the one I started with as it was the only G9 starter bundle I didn't already have. And it's the one I got the discount on. No point for me to purchase any of the older gen bundles.
    There were a bunch of DO G9 character bundles 92% off already. I suppose this promotion worked as I grabbed a few of the ones I'd passed up because I only wanted one thing in them. At ~$4 for the bundle, that was an okay deal for the one thing plus extra stuff. And it fuels my slow exploration of filatoon stuff.
    I'm still seeing purchased I made yesterday and today as "ADD TO CART" in the shop even though I own them.
    It's minutes away from the next set. Are the codes available yet?
  • riuken1riuken1 Posts: 167
    Use code:
    FRIDAY-TOOLS
    After I open the store in a new windows tab all the info update fine, thanks for the link.
  • The codes did not work for me. At all.
  • The current 90% off for tools has a 4$ minimum price, that's not 90% off. Don't know if that's intended or not.
  • HavosHavos Posts: 5,705
    FRIDAY-TOOLS worked for me, but there appears to be a min price of 3.99, which is not advertised on the page, so you may not get the full 90% off. Tokens also do not apply to it.
  • jjoynerjjoyner Posts: 856
     I experimented as well when I saw the first item that I placed in my cart only come down to the unadvertised $3.99.  More expensie items will get a 90% markdown off their full price as long as the discounted price is $3.99 or higher.
    Post edited by jjoyner on
  • frank0314frank0314 Posts: 15,114
    Works for me as well if you have a qualifying product
  • GoggerGogger Posts: 2,535
    Disregard - figured it out - the offer timed out while I had the page still open.  <sigh>
    It was a PEBCHAK Error (Problem Exists Between CHair And Keyboard)
    ____________________________________________
    Anyone else having any luck with coupon "BLACK-OUTLET"?  I go to the Outlet tab up top, I put an item in my cart and try to apply the coupon "BLACK-OUTLET" and it says Coupon is Invalid.  I'm not new to this, so...  The only (and this would downright SILLY) thing I can think is the Outlet store item had to be in your Wishlist prior in order to qualify.  Please tell me that is NOT it.
    I am DAZ+ and Premier so should be getting them at 99 cents.  NOPE.  I even emptied my cart and started putting stuff in one at a time with the coupon applied - nope.
    Any hints would be appreciated.  I mean, I won't die or cry if I don't get them, but again, why bother spending my valuable time trying to make selections and trying to make it work?  I have plenty ofother things to do.  </rant>
    Thanks for your time.
    FWIW:  Desktop PC, Windows latest version, using FireFox browser.  Just like always.
    Post edited by Gogger on
    The BLACK-OUTLET coupon expired 30 mins ago. There is a new offer now.
    CELESRA QN883DArts you need to be picking from this catagory as well as have a product within the "Shopping" or "Still Shopping" catagory to take advantage of the 90% off. This is hte 90% off link. The code is also only usable once per customer. https://www.daz3d.com/toolsgiving#index=0&order=popular^1&filtered=1
    Edit Not uderstand the full issue like it needs to be $3.99, thesse reports are correct after testing, once I was replied to furthur down and the full issue was explained and tested again. There seems to be missing exceptions but I'm having another person on staff to reverify.
    Post edited by frank0314 on
  • SilverGirlSilverGirl Posts: 3,945
    Needing to have the buy-in is supposed to increase it to 3 items at 90% off. ("Get 90% OFF any 1 'Select Tools & Effects' Item OR 90% OFF* up to 3 with any “Shopping” or “Still Shopping” New Release)
    You're still supposed to get 1 item at 90% off without the buy-in. See screen-shot attached of item from that category with code applied, there is clearly an undisclosed floor price.
    998 x 678 - 138K
    Post edited by SilverGirl on
    Uhm, no. The banner says 90% off 1 from the list or 90% off 3 from the list with new release(I did test both possibilities before posting). In both cases the 90%off aplies only to assets with 40$ or above base price, cheaper assets go down to 4$ instead of 90% off.
  • WandWWandW Posts: 2,907
    Playing around with the FRIDAY-TOOLS offer, it seems to give 90% offthe list price, not the currently discounted price, with a minimum discounted price of $3.99... indecision
  • barbultbarbult Posts: 27,585
    No, this is misinformation. There is no buyin required for using the coupon on one item, only for 3. There also seems to be an undisclosed minimum price applied, so not all items in the selected group really get 90% off. That price floor makes the advertised 90% off untrue.
