Adding to Cart…
I've been having trouble with Turbo Loader for G9. It used to work and I have many disabled morphs. When I search for new morphs, though, it stops working. The morph list updates, but, if I try to uncheck any item, Daz Studio crashes. When I try to click any button, like Save Config, nothing happens. I tried to click Execute and I saw this message in the log:
When I reopen Turbo Loader, the list has not been updated.
I also saw, in the log, this message repeated a few times among the AddRelPathToListView entries:
I have tried to uninstall some products listed around the Missing Product warnings, but that made no difference.
Any suggestions about what the issue could be?
First, it has nothing to do with the TurboLoader Missing Product, so we can ignore that. What version of DS are you using? What version of TL? What are the directories in your Content Directory Manager?
DS version: 4.24.0.3
Turbo Loader version: 1.60. The problems manifest only in Manager for Genesis 9 Base, but I also have 8 & 8.1 Male and Female installed, as well as the Booster Utilities, in case that is relevant.
Do you mean the library directories? I have a few: E:\daz\lib, D:\daz-libs\lib2, D:\daz-libs\lib3, D:\daz-libs\lib4, D:\daz-libs\lib-r.
I appreciate the help.
I mean what the Content Directory Manager lists for each of its types:
That took me a google to find, but it is the same list as in the Content Library.
Ok, thanks. Hmmm. Now you say the TLM for 8/8.1 works? No issues?
TLM 8/8.1 Male and Female work. No issues there.
Options are all the same.
Stupid question, you still have a My DAZ 3D Library\data\DAZ 3D\Genesis 9\Base\Morphs directory, correct?
Actually, I have three of those:
And I have even more corresponding directories for Genesis 8 morphs, so, unless there is something different about G9, it does not look like having multiple directories should be a problem.
I used to have multiple small disks and now I have two big ones, but I never figured out how to join libraries short of redownloading everything.
I'm not sure if this is relevant, but, in case it helps: looking into those directories, I noticed tlOff files. The products were in the TLM list and were indeed off. I turned them on and back off and it worked correctly. It looks like I just can't update the list. Unfortunately, I have not updated it in a long time and there are a lot of products to uninstall if that's what it takes...
I figured I should uninstall Turbo Loader for Genesis 9 and start from scratch. I did that through DIM and deleted the files I found in C:\ProgramData\DAZ 3D\Turbo Loader. Then I reinstalled it through DIM and now the TLM window for G9 doesn't even open. Here is the log from when I tried.
Restoring the files I removed did not change anything. I'm guessing that there may be more TL files I should remove too? Where could they be?
Another attempt: I found https://www.daz3d.com/forums/discussion/557186/released-turbo-loader-for-genesis-8-and-8-1-commercial/p17 that points to the registry. I found two TLMG9 keys there (certainly because the reinstall put it in a different directory) and I removed both. When I tried to open the TLM window, I got prompted to create a new list. After it ran over the morph list with many AddRelPathToListView in the log, the window did not open (same message as before) and no key was created in the registry. I guess I will try to reinstall TL again to see if the registry key is recreated in an empty state. I will report only if anything different happens.
I do not think this has anything to do with TL and installation. It seems like you changed your drives and somehow TL is not handling that correctly - unfortunately, it is crashing the script and it is not reporting the true error. I will have to make a debug version of the script to try and isolate the cause.
I really appreciate the help. Please, let me know if there is anything else I can try here.
I just wanted to drop by to leave a thank you note to RiverSoft Art. They have been trying to help me through DMs. My primary installation is really borked, though. It's not Turbo Loader 's fault, since I have a secondary computer working correctly. I have been "cleaning up" my library following some of RiverSoft's suggestions, and things got better, but I reached a point when I think that a clean install is better.
Can I ask for feature? In the manager, right click (or something) on a path and it opens the containing folder path in Explorer. I moved some files and now they show up as duplicates in Turbo Loader. Basically my library doesn't fit on one drive so I split it into G9 figure and everything else. I'm sure these duplicates are causing other headaches as well. Being able to find them quickly would help.
Thanks.
EDIT: Although this isn't the case here: There's just the one directory. Does this mean it's postgreSql issue?
Hmmm, I will think about this.
It looks like one of the times that TurboLoader asked for the product name, it didn't receive anything back so TL had to make something up.
