• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Morphs in Blender: scale to 100 before export?
pixelquackpixelquack Posts: 370
November 2025 edited November 2025 in Blender Discussion
Have a G8 actor at 95.16% scale, tried to create a morph in Blender. Morph Loader Pro loads the obj but moving the slider to the minus enlarges the character up (well, technically you dial the main body morph out so that seems correct) but moving the slider into the plus distorts the character and shrinks it.
My first attempt at morphs. I might be doing it wrong. My prime suspect is the scaling - I'd have to scale to 100% before exporting?
I followed this tutorial, Daz 4.x, Blender 4.4.3
Post edited by pixelquack on November 2025
  • Richard HaseltineRichard Haseltine Posts: 109,292
    November 2025
    Ideally yes, work with no scaling applied or you bake the scaling into the morph so it gets double-applied when you combine it with the original. Alternatively, check Reverse deformations when importing the morph to leave only the changes you made.
  • pixelquackpixelquack Posts: 370
    November 2025
    Export at scale 100 and import works. That means on existing scenes I'll have to scale up, load morph, scale down - sounds like a script job.
    Another tut suggested to "Overwrite Existing: Deltas only" , seems to work.
    November 2025
    Ok, loading the morph in an existing scene does not work at all, scaling goes all crazy - so I have to reset the pose before loading the morph?
    In that case it'd be easier to save the figure as a new subset, load that into the scene and clone pose, expressions and whatnot.
    That's a lot of work on an existing series. Pointers appreciated if I can have that easier.
    November 2025
    Can I load the morph at standard resolution or do I have to switch to base res, then load, then switch back?
    Loading the morph doesn't matter.
    One way around the issues is to load the exported OBJ as a morph and set it to -100%, load your modified OBJ as a morph and set it to 100%, export the result as an OBJ, then load that on a fresh copy of the figure/scene (so you don't have the other morphs bloating the file size) as your final morph.
    Make sure that you are using the same preset in the OBJ Export and Morph Import dialogues - if they don't match you may introduce additional scaling or orientation issues.
    Post edited by Richard Haseltine on November 2025
    November 2025
    I should have watched the whole thing, save the morph properties, save the morph out to library -- I have it working actually.
    It now works in the scenes with the scaled down character, too, of course.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
