New Year, New Sales Thread: Report Issues Here 3 "Reporting Only"
11213151718100
  • felis said:
    RotomatteThis said:
    SCARY-DEAL makes things more expensive in the majority of tested cases.
    That is the Scary part devil
    Reasonable.
  • Cris PalominoCris Palomino Posts: 12,680
    SCARY-DEAL disclaimers are fixed.
  • colcurvecolcurve Posts: 171
    The coupon should not make things more expensive. Its hard to actually spot it. If the coupon makes things more expensive, reject it.
    Are you saying it is doing that? Can you screenshot a cart and explain?
    I don't think so. The deal says "extra 50%". Not "can't be combined with other discounts". But apparently, it doesn't stack with stacker discounts. I have 28 stackers. Thus doorbusters are 70% off. But not with the coupon code.
    1286 x 599 - 106K
    Can you show me a cart with the item with which you are encountering this with?
  • Cam FoxCam Fox Posts: 366
    One eligible test item from the Featured Artist stores.
    Cart without coupon, with a doorbuster in the cart and no tokens applied the discount is 80%
    Cart with coupon, the test item goes to 75% and also ignores tokens when those are applied.
    Coupon seems to be applying 50% discount which blocks all other stacking discounts and token discounts.
    1307 x 443 - 109K
    1299 x 453 - 110K
    Inquiring about SCARY-DEALS. Thanks to both of you for the cart images.
  • LeanaLeana Posts: 12,967
    Xellosz said:
    https://www.daz3d.com/stunning-high-ambient
    why needs (required item)
    https://www.daz3d.com/lux-high-heels-for-genesis-3-and-genesis-8-female-s
    Looks like they ended in the "required items" section instead of "products used in promo pics" by mistake.
  • Peter WadePeter Wade Posts: 1,679
    I'm coonfused about the SCARY-DEAL rules. It doesn't say anything is excluded except membership, giftcards and licences but when I use it with only Beatrice in the cart the pice goes up from $7.50 to $8.75. If a coupon code is not valid for an order the store normally tells you so and it isn't doing that so I suppose the coupon is being applied.
    Is it an error that the stacker saving is not applied if you use the coupon? If this isn't an error then the coupon is useless to anyone with enough stackers.
  • rokkrrokkr Posts: 354
    Scary-deal doesn't work due to unwritten rules, so, thanks but no thanks... I'll just pass...(like... it "works," but, though not written anywhere, tokens and doorbuster discount don't stack, so it's useless, thus, whatever...)
  • davesodaveso Posts: 7,921
    SCARY-DEAL still does not work. It actually increases the price/lessens the discount of an item when applied.
    1455 x 431 - 97K
    1459 x 448 - 97K
  • Joe2018Joe2018 Posts: 295
    Scary behavior of the coupon code:
    it works (more or less) with 1 Item in the cart (in my case https://www.daz3d.com/bald-eagle-by-am) Price before coupon 24,99 with Coupon 17,99 - this seems to be a limit (cross checked with an cart without being logged in. So stackers won't apply etc. - also 17,99).
    You can then add more items to the cart. Discount on the first item will stay at the price of 17,99 - even if you use token for the whole card.
    If you have a cart with more then one item before you use the Coupon: the price will increase! Scary Coupon!
  • Charlie JudgeCharlie Judge Posts: 13,400
    edited October 2025
    Today's Special advertisement clearly states that you gt an EXTRA 50% discount (with coupon) on any one item excluding gift cads, licenses, and memberships. This os clearly NOT what you get with any Doorbuster,Debute, or Still New item. DAZ needs to honor their offers! Please fix.
    1182 x 469 - 75K
    Post edited by Charlie Judge on
    edited October 2025
    it appears scary-deals take the discount from the discount applied in the catalog, not the one you get from having stackers, or anything else.
    Post edited by daveso on
  • CybersoxCybersox Posts: 9,552
    So what is the deal with this "Victoria AI agent" that keeps popping up on my screen when I'm on the DAZ store?  How did it get turned on and how do I turn it off?
  • joannajoanna Posts: 2,444
    Is the SCARY-DEAL coupon reported as not working on doorbusters/new/still new or already being worked on? Or, at least, if it's intentional, will the description of the coupon be updated?
    (At this state, I'm more curious now that in need to buy anything today.)
    its an AI chat bot..I just tried it for the first time after seeing this mention and have to say, it is extremely helpful. I pointed me to forum posts to help with my questions, pointed to product, to tutorials, etc etc. And its very fast. I'm impressed actually.
    Make sure you don't have any open discussions - if it keeps popping up that is usually the cause, saying goodbye should end the chat and stop it from popping up (unless you have found a new bug or compatibility issue).
    We were under the impression that it should be stacking, but it is possible that there should be a disclaimer for Stackers.  We are trying to find out.
    Fixed now
    Fixed now
    Thank you!
    Fixed now
    Fixed how? The webpage isn't updating with any changes.
    Fixed now
    It is stacking with Stackers now.
    Fixed now
    Have to admit. I wasn't expecting that outcome. Nice.
  • ElorElor Posts: 3,553
    Price of the bundle by HM is obviously wrong ($0.99) and it's currently wrong in the cart too:
    https://www.daz3d.com/hm-cosplay-hair-bundle
    Pricing has been fixed.
