Help with Matte Fog Setting
MrRogerSmith
I struggle to get the matte fog setting to make any change in my renders. I see other users make really nice effects with it, but in my renders it never does anything. See the attached example. One render is with matte fog turned on at the default setting (screenshot of settings attached) and one is with matte fog turned off. I have also tried playing around with the values but have never seen an effect.
Any suggestions?
Here are two illustrations of Matte Fog and Ground Fog
Or did you want to have something that sometimes is called God Rays?
Thanks for the responses. I was not aware that matte fog only applies in the distance. I thought it created a haze effect throughout the entire environment.
Ah, now I understand. I think Daz could rename this setting to make it clearer: "Matte Fog Distance." By calling it "Matte Fog Visiblity" it suggests a higher value will cause the fog to be more visible.
Thank you for your help.
It does have (m) after the name, to indicate it is a value in meters.
