• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Eyelid Subsurface Scattering and Eyelid Shadow
hello_4493841hello_4493841 Posts: 7
January 2023 in Blender Discussion
I notice with my daz characters I get a shadow under the top eyelid. It's most noticeable with subsurface scattering turned on. Where the eyelids seem to glow from the SSS. You can see in my low light example the eyelids glow even where the eyeball and surrounding skin fall into the shadows. I have the SSS set as low as I can at 0.001.
Has anyone else had this issue?
Is there anyway to control the SSS on just the eyelids, with a map or something?
  • PadonePadone Posts: 4,016
    January 2023 edited September 18
    With diffeomorphic you can use the bsdf material option to mimic iray. Or the principled option to get easy materials to customize/fix as needed.
    p.s. Also using burley instead of random walk usually gets away the artifacts. Reason is random walk doesn't work fine with open meshes at the borders.
    https://docs.blender.org/manual/en/4.5/render/shader_nodes/shader/sss.html
    Post edited by Padone on September 18
  • VanillaStuffVanillaStuff Posts: 24
    January 2023 edited January 2023
    A quick workaround would be to duplicate the face material, then go edit mode with the duplicated material still selected unassign all verts. And reassing all faces for that area. Then either turn off SSS for those faces or go even lower for that area to not completely lose SSS.
    If you need more detailed way, I can probably do tomorrow. With pictures or an animated gif. But only if you don't get what I mean.
    Post edited by VanillaStuff on January 2023
  • PinkspectrePinkspectre Posts: 51
    September 17
    I am having this exact same issue, were you able to actuall fix it?
  • gregsgraphics_cafd0962a0gregsgraphics_cafd0962a0 Posts: 112
    September 17
    Create a control map and plug it into the SSS weight input.
  • hardwire666hardwire666 Posts: 74
    September 21 edited September 21
    If you haven't noticed yet by all the different replies SSS in Blender can be a PIA. For a while my preferred setup was to run the diffuse texture through a Color to BW node, then a brightness/contrast node, then finally through a color ramp. The color ramp allowing you to to control things pretty well. It's no replacement for having an actual SSS map, but I did okay with it. I like to fine tune the SSS by doing an extremely bright back light on the head and looking at the ear form the front. Once I get that looking right it typically works everywhere else just fine.
    Post edited by hardwire666 on September 21
  • Krys KryngleKrys Kryngle Posts: 313
    September 25
    As gregsgraphics_cafd0962a0 said, you can create a black and white map to control which parts get SSS and how much.  Simplebake can generate a thickness map, and then you can modify that with texture painting and/or a map range/color ramp.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
