• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
About the JCMs after importing 'G9 Anime' into Blender with Diffeomorphic.
nyasigutonyasiguto Posts: 8
August 2025 in Blender Discussion
Using Diffeomorphic’s import_daz, import "G9 Anime Base Feminine Dev Load" into Blender.
After applying Import JCMs, set the model to T-pose.
The JCMs look different from how they appear in DAZ.
What should I do?
The first image is from DAZ, and the second is from Blender.
  • crosswindcrosswind Posts: 10,276
    August 2025
    If you check the hidden properties of corrective morphs (cbs) on the anime figure, you'll see there're two more BaseAnime related corrective morphs with a 2nd stage controller : Base Anime Body Feminine.... (screenshot 1)
    As default, Diffeomorphic doensn't import them... you can mark them as Favorities then import Daz Favorites. Dial Base Anime Body Feminine to 1,  zero and Lock BaseAnimeF_body_bs_BodyFeminine-0xa39d1a4... then four corrective morphs will be correctly triggered ~ (screenshot 2)
    You'll have the very same shape of Anime figure in Blender as what you get in DS.
    2018 x 1138 - 474K
    2560 x 1392 - 1M
  • PadonePadone Posts: 4,326
    August 2025 edited August 2025
    Be sure to select "feminine" in easy import, and that "baked morphs" is enabled in the global settings, then everything will import fine same as Crosswind did by hand. In general there may be some slight difference in jcms because blender uses a different type of interpolation, but that's not noticeable for practical use.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Global/Morphs
    update. In the last commit the baked morphs values are always imported and the option is gone. Also docs are updated.
    208 x 322 - 18K
    Post edited by Padone on August 2025
    Padone said:
    Be sure to select "feminine" in easy import, and that "backed morphs" is enabled in the global settings, then everything will import fine same as Crosswind did by hand. In general there may be some slight difference in jcms because blender uses a different type of interpolation, but that's not noticeable for practical use.
    Right, that's it !  The baked option in Global settings is unchecked . Thank you very much !
    Edit: But importing Feminine is not really necessary for the case of using G9 Anime because BaseFeminine corrective morphs are not used on G9 Anime figures. If importing Feminine, two BaseFeminine corrective morphs will be triggered 'cause its 2nd stage controller : BaseFeminine is not used on G9 Anime figure i.e. not imported as Baked. The Anime's shape will be different from the one in DS.
    Post edited by crosswind on August 2025
  • nyasigutonyasiguto Posts: 8
    Many thanks to crosswind and Padone!
    Because of your help, I managed to load the JCMs that match the model.
    I’m truly grateful!
    Post edited by nyasiguto on August 2025
    August 2025
    No problem !
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
