Live In Store Now! - Ivy Scatters for Ultrascatter 2 (Commercial)
Martinjfrost
This bundle of low res Ivy foliage is intended for use in Ultrascatter 2 - there are both plants and ready made ultrascatter scene subsets which can be added to your scene and applied as a scatter on most objects - depending on how the object has been constructed and uv mapped will depend on how well the scatter works.
Althought not infallable this adds a quick way to cover many objects or parts of them in ivy - other plants will follow watch my store for them.
THe included scene subsets are applied to an object by parenting the ultrascatter 2 instance sets they contain to the object you wish to scatter them on ( dont parent the actual plants containnded in the subset). Once this is done they should show up in the ultrascatter 2 window for that object and can be adjusted according to your desires.
Insturctions below.
Does it works in UltraScatter2 Pro?
Pro? the link to the version of ultrascatter it works with is in the product page. It will NOT work with ultrascatter or ultrascatter pro.
@Martinjfrost have you seen in the Ultrascatter Pro thread that Ultrascatter Pro under certain conditions crashes Daz Studio?
I am aware that there are crashes sometimes,. but these have been quite well tested and should be ok, as with everything to do with scattered objects, its always best to use the fewest possible instancees that helps avoid freeze ups and crashes.
The issue is that importing Victoria 4.2, and possibly other ExP figues, crashes DS if Ultra Scatter 2 is installed. This has been posted to the US 2 thread.
Good to know as general info, this product wont be affected by that (unless you do import v2 ) as it has no relation ship to those things.
I guess the hope was that you would make sure Howie was aware of the issue, since it is with the plug-in not content like yours.
Thanks. My bad, I was thinking about UltraScatter2.
An update for UltraScatter2 (v2.0.0.19) that fixes this problem should be available for download now.
I might eventually buy it now
I do use Ultrascatter 1 quite a lot but also use V4 quite a lot and when I saw this issue mentioned I held off
Installed update, and confirmed not crashing Daz Studio when loading Victoria 4.2
Thank you for the update, and for the confirmation that it works.
