New Year, New Sales Thread: Report Issues Here 2 "Reporting Only"
1…7475777980…100
  • barbultbarbult Posts: 27,585
    Cris Palomino said:
    Xellosz said:
    Why is there a $3.99 minimum price when the sale doesn't say it? https://www.daz3d.com/flashback-and-bundles
    For:
    • 2025 Flashbacks
    • 2024 Flashbacks
     Could you give me more info? I took one of the 2025 flashback items and put the 2025-FLASHBACK Coupon on it and got 60% and then removed the coupon and added a new release from tonight and got 70% as expected.
    The question is about a $3.99 minimum price, when that minimum price is not disclosed in the ad. Your response did not address that question. Did you get prices lower than $3.99? Are there intended limitations that are not disclosed in the ad?
  • ElorElor Posts: 4,160
    edited August 2025
    Using the cheaper items over 3.99 in both selections, there indeed seems to be price floor active:
    2025-FLASHBACK: discount should be 60%.
    2024-FLASHBACK: discount should be over 65% because it's a Daz Originals.
    Edit: I didn't thought about adding a new release but I checked with the 2025 Flashback code and it didn't lower the price, the chair collection 1 was still at $3.99.
    615 x 177 - 18K
    633 x 231 - 22K
    Post edited by Elor on
  • Cris PalominoCris Palomino Posts: 13,008
    barbult said:
    Cris Palomino said:
    For:
    • 2025 Flashbacks
    • 2024 Flashbacks
    I'm asking, but the original query didn't give me enough info. I couldn't figure out what 3.99 had to do with what was being pointed out.
    We've let Daz know; will likely happen in the AM cuz of what time it is now.
  • rokkrrokkr Posts: 394
    Not quite clear this here...
    60% off
    One with code
    2025-FLASHBACK
    - Useable once per customer -
    70% off*
    Up to 3 with any
    "Memory" New Release
    75% off*
    If its in your Wishlist
    prior to August 16
    ... so, I'm asking... Do the 75% info is related to the 70% info (i.e., must also have a memory release in the cart PLUS also limited to only 3 items)?
  • frank0314frank0314 Posts: 15,114
    Sorry, we forgot to update the thread that the $3.99 was fixed and now shows in the disclaimer and if it doesn't for you do a hard refresh. It was fixed about an hour and a half ago.
    edited August 2025
    60% off
    One with code
    2025-FLASHBACK
    70% off*
    Up to 3 with any
    75% off*
    prior to August 16
    No you don't need to have an FNR in the cart. If the product you're picking from the link they provided is in your WL than it is 75% off. It "looks" like there is no limit. I just put 5 in my cart and I get 75% off all of them.
    Post edited by frank0314 on
    frank0314 said:
    60% off
    One with code
    2025-FLASHBACK
    70% off*
    Up to 3 with any
    75% off*
    prior to August 16
    Thank you. Yeah. Just tested and it works. It changes everything.
  • kimhkimh Posts: 408
    edited August 2025
    I am not getting 20% off as per Orange banner for Bone Minion Batch Converter for Genesis 3 Poses. I am only getting an extra 10%
    781 x 420 - 40K
    827 x 863 - 138K
    Post edited by kimh on
    We have a summary of the offer and it says 10%, so I think the banner is wrong - but we will try to get that checked.
  • namffuaknamffuak Posts: 4,520
    edited August 2025
    The orange banner says 10%; when you clck on it, the popup shown above appears claiming 20%.
    Post edited by namffuak on
    Yes, this is a mistake which is being fixed (or has been, I am not sure as it is not one of my offers).
    edited August 2025
    1183 x 740 - 182K
    245 x 496 - 11K
    Post edited by barbult on
    edited August 2025
    They forgot to update the text of the 2025 Flashbacks and 2024 Flashbacks and it's missing a 'Minimum price after after discount' information (the minimum seems to be 3.99 like yesterday):
    617 x 289 - 26K
    TY
    Should be fixed.
    edited August 2025
    Thank you :)
    I found another problem: the extra 20/30 or 40% on Daz+ Flashback for having any “Memory” New Release in the cart doesn't work if the Memory NR in question was released yesterday (the Cyberpunk product was to check if the problem also happened on the Featured Artists Stores but there is no problem with the FAS):
    With the Darkwood Asylum, a release from yesterday (which is labeled a Memory New Release), the Daz+ item has a 93% discount (which is the one advertised on its page: https://www.daz3d.com/ebil-baby-bundle ):
    With a release from today, it got an extra discount, as advertised:
    620 x 442 - 41K
    652 x 463 - 46K
  • LorraineLorraine Posts: 1,082
    edited August 2025
    Items are not getting 80% off. All are from the wishlist selection and have been in my wishlist for some time.
    1129 x 570 - 693K
    1361 x 630 - 103K
    Post edited by Lorraine on
    The three items in your cart are from the 2025 Flashback selection, so the 75% they are getting is correct.
    Elor said:
    Thank you :)
    Reported.
    Thanks mate, can't see for looking!
    Elor said:
    Thank you :)
    Should work with all the listed "Memory" new releases now.
  • I have a cart where the price is above what it should be (with $10/$25 Premier coupon & 1 token). With only https://www.daz3d.com/filatoon-shader-bundle, https://www.daz3d.com/da-rottweiler-for-daz-dog-8, & https://www.daz3d.com/phenotypes-for-dog-8 in the cart total is $17.05. When I add https://www.daz3d.com/lorez-horse-2-bundle total is $21.23, when it should be around $19, assuming it is eligible for both tokens & the coupon.
    (Note the Lorez Horse bundle is $2.84 because I own 2 of the 3 items.)
    I decided to just purchase the Horse bundle separately; I'm flagging this to provide more data in case others have similar problems.
    800 x 1280 - 163K
    800 x 1280 - 134K
    800 x 1280 - 178K
    800 x 1280 - 141K
  • I seem to have an issue with the classic bundles offer, I have added the biker outfit to my cart, which I believe should at least receive the 50% discount without the "Memory" release but it appears to be getting a 40% discount. With the "Memory" new release it should get a 70% discount but it does not appear to be doing so?
    538 x 662 - 133K
    955 x 823 - 224K
    692 x 989 - 140K
    I think it already has the 50% (it's on the category) so there is no change for that when you add it to the cart. When you add a Memory reelase it takes off another 40% (50% after the first discount and then another 40% off that is 20% of the base price, 50% of the base plus 20% of the base is 70% of the base which is the correct discount).
    Is there supposed to be nine outlet products in this weeks Quick Grab?
    I see 90 currently, which is similar to last week number.
  • LeanaLeana Posts: 13,554
    Princess is listed as one of today's "Pretty artists" but they have no product included in the selection. Is that intentional?
    Will enquire.
  • RangerRickRangerRick Posts: 332
    Looks like "Princess Pa" items aren't triggering the extra discount off "Pretty" Artist Stores. I have:
    "dForce Princess Series Oriental Blossom for Genesis 9, Genesis 8 and 8.1"
    "Princess Series Oriental Updo for Genesis 9, Genesis 8 and 8.1"
    and "L3D Bodytalk Poses Genesis 9 Vol. 2" in the cart and only getting the base 50% off discount on:
    "FG Fantasy Pub Bundle"  and  "SIC dForce Paula Dress for Genesis 9"
