Creating Shape Preset
2»
  • crosswindcrosswind Posts: 10,253
    Joe.Cotter said:
    There's no way to scale it in the app, then lock in the scale and update the morph asset?
    Sorry, I don't understand what you mean by "there's no way to scale it in the app" ~~~  Scale is a Pose rather than a morph. You can save a Properties Preset for the character so as to include both Shape and Pose.
  • Joe.CotterJoe.Cotter Posts: 3,362
    Ok, thank you for clarifying that. I really appreciate all of your help btw, I have been learning a lot.
    You're welcome !
  • Richard HaseltineRichard Haseltine Posts: 111,390
    crosswind said:
    Joe.Cotter said:
    I figured it out... I was looking under the shaping pane... you know, the logical place one would look for reshaping a character... not the parameters pane since that would make no sense, unless I'm missing something.... why are they under the parameters pane rather than the shaping pane?
    Btw, ty... I only looked there because I was rereading your comments (very closely, as if I was debugging code) and noticed you said parameters pane...
    Ah, that's the culprit ~~ Shaping pane only shows you the morphs under Actor path while the morphs created by Shape Transfer are under the path of Shape Transfer. I personally never use Shaping pane and Posing pane ~~
    Well, if you want them to be shown in Shaping pane, remember to change, in Parameter Settings, Path to Actor/Full Body or with other sub-path. Then save the morphs by using File > Save As > Support Assets > Modifier Asset(s)...
    The Shaping and Posing panes filter what they display by type (modifier/shape, modifier/pose)
    Not only by modifier Type...  Shaping pane > Modifier/Shape + Actor path ONLY.  Posing pane > Modifier/Pose ONLY, Path irrelevant ~~
    Yes, changing only thr path of a shaping
    Ok, I missed those last three remarks, too much shorthand.
