Show Us Your Iray Renders. Part IV
18182848687100
  • L'AdairL'Adair Posts: 9,479
    edited October 2015
    pearbear said:
    (Also check to see if any other stray head or character morphs got loaded in with your Darius, because comparing your renders with the Darius promo pics and with what I get when I load Darius, it looks like something is off with yours. I've had a similar problem with G3F ever since I installed Karen. Half of the time when I load a G3F character, the Karen morphs load too on top of it, creating distortion, and I have to go and dial them down to zero. It's very annoying, and DAZ customer service told me they've reported it to the PA but most likely nothing can be done about it.)
    Rogerbee said:
    I see what you mean, and I know what is happening. For some reason, by default, when you load a character like Darius, M6 gets loaded in as well. When you check to see what is dialled in, M6 is dialled in at 100% as well as Darius. I thought this was how it was supposed to be, but it appears not. I'll go back, dial out M6 and see what is what.
    CHEERS!
    L'Adair said:
    I have the similar problem with Savannah and G2F figures, but it only shows up when I reload the scene. Everything looks normal when I create the scene, and it renders just fine. And if I've fixed the problem and saved the file, the next time I reload Savannah isn't there. But as you say, it's really annoying. I finally got around to reporting it to tech support on Friday. After what you said, I'm not feeling too optimistic. lol
    Okay. I spent a good three weeks working with tech support on this issue, my own fault it took so long as I work late, and stay up late... Anyway, after much trial and error, answering a bunch of questions, sending in screen shots, and so on, we found the issue. Now while I do have a fix, imo, DAZ has some code to fix.
    While working on a book cover, using an older character, I manually tweaked the settings for Iray. but I kept messing up the settings while tweaking other things, so I created a character preset. Turns out DS saved a ton of morphs into My Library for G2F. (C:\Users\Admin\Documents\DAZ 3D\Studio\My Library\data\DAZ 3D\Genesis 2\Female\) These morphs were being applied to all G2F models when the duf file was loaded, unless I'd specifically removed them and saved the file.
    I did a lot of testing before I came to the conclusion it was safe to remove everything inside of C:\Users\Admin\Documents\DAZ 3D\Studio\My Library\data\DAZ 3D.
    If either of you created your own character presets, check for a similar path in the My Library subdirectory. Roger, look for Genesis 2\Male; and Pearbear, look for Genesis 3\Female. (That's how they are set up in the data directory of My DAZ 3D Library in the Public Documents folder. (I'm on a Win7Pro x64 system. I expect the directory structure is the same with other versions of Windows.)
    Of course, there may be something else going on for you guys, but it's worth taking a look at your directories to see if your problem is the same as mine.
    -Anita
    Post edited by L'Adair on
  • RafmerRafmer Posts: 564
    edited October 2015
    This is a model a friend of mine did in 3DStudio based on concept art from utopies-charlene.blogspot.fr. I converted it for Daz Studio and applied default Iray shaders; it's still missing texture maps but I think it's quite nice already :P Gallery link: http://www.daz3d.com/gallery/#images/89728/
    Post edited by Rafmer on
  • nDelphinDelphi Posts: 1,957
    Ivy said:
    Title : VIP
     I think I got Iray lighting down pat and I really like the Iray real -ights they works very well with HDRi lit scenes.  anyway these are just 3 of the 10 scenes
     best viewed full size really detailed  lighting. in 1080 HD
    Those VIP helicopert shots are asweome.
  • Joe.CotterJoe.Cotter Posts: 3,362
    Interesting model Rafmer.
  • IvyIvy Posts: 7,165
    nDelphi said:
    Ivy said:
    Title : VIP
    Thank you very much I hope you got a chance to see the whole sries of them i have on my g+  The Iray real lights work really well with HDRi . which is what I used.
    edited October 2015
    Cosplay Girl ~ Kasumi
    Mie-lin, w/ daz stock Iray mats. Jazmin Hair wth out of touch Iray hair shaders with a  custom Kasumi Outfit recreated with Iray mats and super-smoother modifiers. rendered with a wall BG  HDRi  . No Post work.
    667 x 1080 - 62K
    Post edited by Ivy on
  • BobvanBobvan Posts: 2,653
    That model looks killer mad skills. Diorama close up http://fav.me/d9cfxvk
    Thems giant bugs http://fav.me/d9coz85
  • TaozTaoz Posts: 10,308
    edited October 2015
    Tjohn said:
    Karen Seven
    Hm what camera did you use here, Canon, Nikon ? cheeky
    One of the best I've seen for a long time...
    Post edited by Taoz on
  • V3DigitimesV3Digitimes Posts: 3,417
    Wow and suddenly I feel like playing DOA! Nice!
  • daveleitzdaveleitz Posts: 459
    That looks great!  Your friend is a superb modeller with a nice design sense.  You really did it justice with this fine render.  You should edit your post to include the gallery page link so it can get more views there!  laugh
    Ha Ha I know right?   , Thank you for the comment :)
    edited October 2015
    Cosplay Girl - Bat Girl , 1970's version
    Custom Bat girl outfit, retro fitted with Iray shaders, Custom Bat Mobil with Iray auto paint shaders and Daz Real Light shaders.  Rendered in a Bat Cave HDRi  I found at HDR Labs.
    Click for best 1080HD details
    1920 x 1080 - 176K
  • TJohnTJohn Posts: 11,355
    Very nice, but where's Ms. Gordon's Batcycle? smiley
    edited October 2015
    Tjohn said:
    Yea,  I needed her Bat Bike but didn;t have one, your loks great
    edited October 2015
    Cosplay Girl - Wonder Woman ~  HDRi & Iray custom mats for the wonder woman outfit. These outfits are Terry McGs at sharecg. I just re did the texture maps in Iray and applied supersmoother modifiers to the outfits to make them fits Silvers Character better. The hair is by OutofTouch  Natasha hair with OOT's Iray hair shaders.
    667 x 1080 - 79K
  • ZilvergrafixZilvergrafix Posts: 1,385
    Sayumi Working at home.
    1800 x 1800 - 741K
    Thank you very much for your comments! I'll take your advice on this smiley
    edited October 2015
    Cosplay Girl.  Super Girl (teen years) 1980'sTV  version
    HDRi BG, Custom Iray mats to the super girl outfit, which is a kit bash. I used g2f with pretty 3d school hair for my character.
    667 x 1080 - 63K
  • I think I am close to finished with converting Planet Lava by Stonemason. All of the lights here are coming from emissive textures including the lava, sparks, and the skydome prop. I tweaked the settings on the lava textures many times before getting to this stage.
    http://www.daz3d.com/planet-lava
    2732 x 2048 - 2M
    2732 x 2048 - 2M
    2732 x 2048 - 2M
    2732 x 2048 - 2M
    Wow! It looks great, nice job!
  • grinch2901grinch2901 Posts: 1,247
    edited October 2015
    With the PA sales I was going through all the sets and props to see if there was something I wanted that was on sale and I came across a complete White House Oval Office set. I have another that I bought at another site and it had excellent props but only half the room was modelled.  The one on sale here was the full room but no props. Marriage made in heaven! I spent some time finding other props to flesh out the room and converting textures to Iray and the lot, and this is what I came up with.  Finally a place to issue super secret orders to my spies. Also I want to make a "In the not too distant future War nerve center" version of the room which has the couches cleared out and some large map tables and comms equipment and stuff like that added. Needed a full room to do that so I'm really happy I was able to get this at a good price.
    1013 x 570 - 526K
    Post edited by grinch2901 on
  • K T OngK T Ong Posts: 486
    This ought to make a great illustration for a children's book. Love the zany design.
    Tjohn said:
    Karen Seven
    Great render. Where did you get the bookshelf and its books from? laugh
    edited October 2015
    A very recent render of mine...
    Post edited by Cris Palomino on
  • Cris PalominoCris Palomino Posts: 12,801
    KT, did you delete your attachment?  I'm suring it can't be found.
    I did actually. Sorry about that. Here's the attachment again.
    1024 x 768 - 2M
    Fixed the image.
    K T Ong said:
    Tjohn said:
    Karen Seven
    Thanks. That's an HDR interior from Dimension Theory. smiley
  • Oso3DOso3D Posts: 15,104
    Wednesday, time for a comic update! Iray with some post work:  http://thefarshoals.webcomic.ws/comics/38
    Las Flores que Cultivan -- whereupon more is revealed about the setting, mostly concerning travel...
