Why does the shader work on a primitive, but not on an imported obj
Hey guys,
I exported an obj from blender and I tried to apply a brick shader to it, but no matter what I try to adjust under the horizontal/verticle tiles, it just does not work
However, when I create a simple sphere, then, with the Surface tab selected sphere, I can double click on the shader and it appears properly as I would expect it to do.
Do I have to export from blender with something special in the export window selected or do I have to import an obj file with something special selected in the import window?
Thanks in advance
  • nemesis10nemesis10 Posts: 3,968
    Try selecting your obj, select it in the surface tab and select the various surfaces, apply default iray shader from Default Resources>shaders>iray uber shader, then apply your shader to those surfaces.  The simple sphere primitive arrives with the iray uber shader already applied.
  • tam_c3df5332fctam_c3df5332fc Posts: 131
    edited June 2025
    @nemesis10 - thank you for your response. Yes, I tried that exact suggestions, but alas, same result. I also tried copying the original surface of the sphere, pasted onto my object, but it turned out to be the same result.
    BTW, is there a way to use a Bezier curve to lathe an object, like I can in Blender. I imagine that someone will suggest to use Hexagon, but I really do not want to learn another program.
    Post edited by tam_c3df5332fc on
  • Richard HaseltineRichard Haseltine Posts: 110,843
    Is the model UV Mapped? You should see an exploded view of the mesh in the UV View in DS or in Blender's UV window.
  • @Richard Haseltine - Thanks for the response. Yea, I deleted all the materials within Blender> Shading and I also went under the UV - Unwrap, followed by trying the Smart wrap.
    As far as Daz, under the UV View, it is just a white canvas
    3113 x 1935 - 174K
    Thank you for your suggestion once again. I re-opened the blender file, followed by going into the UV editor, but this time, I did a select all, followed by Unwrap, then I exported the object, with Material group selected. When I imported the newly created obj file, I was able to select and apply the brick shader with no issues - see attached render
    Thank you, thank you, thank you
    3840 x 2160 - 2M
    Glad it helped.
