How to attach a gun to right hand
I am having the hardest time attaching a pistol to my characters right hand. I have done the right click prop assign new parent and it won't attach to the hand.
  • Richard HaseltineRichard Haseltine Posts: 112,037
    What hapens instead? Is it litraly a prop - an item without any bones - or is it a figure?
  • wsterdanwsterdan Posts: 3,655
    Parenting a prop gun to a hand doesn't actually move the gun to the hand. If you parent it and you move the hand, the gun will move too (even if its nowhere near the hand), that would show that it's "parented". If that's the case, that the gun does move when the hand moves, you will have to move the gun to the hand and put it in place and – unless there's a pose for it – pose the fingers into position to hold the gun.
    Hopefully that helps.
  • sadiejfoxxsadiejfoxx Posts: 34
    Yes this did help so much! Thank you!
    You're very welcome, have fun!
  • ElorElor Posts: 4,264
    edited June 2025
    In Scripts/Utilities, Daz is providing a script called SnapParent which will move the prop to its parent (as long as it's a bone if I'm remembering right): it will not be perfectly placed, but it'll do part of the job:
    To use it, the prop you want to move need to be parented to the correct bone, then select the bone and the prop:
    Here I selected Left Hand and the gun, but with Genesis 9, they are 'Left/Right Hand Anchor' bones, which allows a better default positionning of the parented prop
    Parented to hand:
    Parented to anchor:
    1860 x 948 - 261K
    560 x 751 - 50K
    560 x 751 - 50K
    Post edited by Elor on
  • Drogo NazhurDrogo Nazhur Posts: 1,356
    I normally position the prop (in this case the gun) to where I want it on the body and then parent it in place.
  • kprkpr Posts: 508
    Correct answer smiley (parent to hand, but ALSO check Parent-in-Place).
    You might also want to look at the gun's x/y/z coordinates - see @maymeanshope in this often-necroed thread: https://www.daz3d.com/forums/discussion/128241/reset-the-x-y-z-location-on-an-object-to-0-0-0
  • @Elor, I never knew that script was there. Getting a prop to the hand, or wherever, is the part that takes me forever. Thanks!
  • SilverGirlSilverGirl Posts: 4,022
    +1 - mind blown! Thank you!
