Easy Geometry Hider [Commercial]
2»
  • UtiltarianUtiltarian Posts: 76
    edited May 2025
    Choppski said:
    I was foolish and did not read the pdf very carefully. What happened was that I selected some surfaces on the gens graft, put opacity to 0, and then ran the script. I didn't notice anything different, but when I put the opacity to 100, nothing changed--i.e., the surfaces were still gone. However, when I tried to unhide the new graft, nothing seemed to happen. I did NOT save the scene because I feared it would ruin what I had, which was foolish because I could have saved it as an alternate scene. When I try to open it, it always crashes as it is trying to load items. I also tried opening a backup of the scene and it crashed. I worried that I had damaged the gens graft, but I opened other scenes with the gens and they opened fine. I think the issue was that I should haven't tried it on a geografted item first and that I should have saved the scene separately. Fortunately the scene in question was nothing vital.  Oh, but the figure ALSO had the legacy geografts to use genesis 8 materials. So I wonder if there were too many geografts and I did not detach the graft. Mostly, I should have played with it on something like clothes or hair before trying a geograft.
    After a few tests, I realized what I previously wrote was wrong: there's actually no issue with creating conditional grafts on items that have a geograft (e.g. gens) attached. The issue that did exist was that creating selection sets from conditional grafts improperly included the faces the geograft covered. But I actually just found the solution for that, so I'll include it with the coming update. So, contrary to what I had written in previous post (which I updated for future readers), as far as I'm aware, there are no issues with creating conditional grafts on either a base item with a graft, or the attached graft.
    After reading your followup, here's my guess as to what might have happened:
    You said you set opacity to 0 and ran the script. The default setting is to not reset the opacity for 0-opacity materials, and I'm guessing you kept the setting off. You successfully created the conditional graft which also hides the content, which is why when you reset opacity to 100, the content remained hidden. Perhaps you then set the opacity back to 0 (maybe accidentally via undo?) before going to disable the graft, and when the content was still hidden, that's when you thought something was off. (In hindsight, I should probably enable the option by default to prevent this confusion.)
    As for the crash, I'm not sure what's going on there. If you created a conditional graft that ended up with bad data, in theory it could cause a scene that's using it to crash during load. But you mentioned you didn't save the scene after making the graft, and that a backup scene is also crashing, which I assume you had created/backed up before you tried making the conditional graft? It's unlikely that even if the conditional graft has bad data, that it would cause a scene in which it's not being used to crash. For that matter, I actually tried intentionally creating and enabling one with bad data, and to my pleasant surprise, Daz Studio didn't crash: instead the graft simply did nothing. So with that said, I'm inclined to think there's something else causing the issue with your scene.
    If you really want to confirm, you can create a fresh scene, and try to repeat the steps you previously did and see whether this scene also has a problem. I would note that anything you do within a scene should have no effect on any of the underlying content files used (such as the character, item, gens/graft, etc), so I wouldn't worry about "damaging" any files. And so, if the recreated scene does end up misbehaving/crashing, then it should be an easy fix from there. But I can't reproduce any problems, whether I'm creating a conditional graft on the base figure that has a geograft, or on the geograft attached to the figure, nor even on a geograft attach to the geograft. Which is to say, to answer your original question: there shouldn't be any problems caused by what you were trying to do.
    Post edited by Utiltarian on
    edited July 2025
    rhye_7b205b2b74 said:
    Did you run the script from within Daz Studio as instructed?
    Yes I did from your within within Scripts in Daz, but it could not find the corresponding scripts, perhaps it only accepts a C: drive path in your coding?
    however it did work when I clicked on the DSA file from the folder it is in
    Update is live, so no reason to manually update at this point, assuming you weren't able to.
    The update is now live (sorry again for the delay!). Most important fix was enabling support on 4.12 and up, and adding support for DS 2025. I also added the ability to choose the content library path where the files are saved, and fixed a bug where the "Product Name" value (i.e. the sub folder where the file got saved) was being ignored.
    Lastly, I added a new option when auto-creating selection sets to order them by position. Now with the spatial ordering, consecutive selection sets are generally next to each other, whereas previously, the ordering was based on the number of faces assigned to the selection set (in descending order), and so it was more difficult to locate the one you wanted when going through them one by one.
  • Does this only work for hiding geometry of clothes? Or can I use it to hide body parts of my character?
  • ElorElor Posts: 4,048
    Conditionnal grafts can be created on any figure, characters included (I just tested it on Genesis 2).
    Do you have a specific goal in mind?
    I want to use it to create custom characters with 4 arms, so I would need to hide every thing except the arms.
    Don't forget that you cannot fit one figure to another with an offset, if you want the arms to be non-overlapping.
    edited February 22
    Yes, the tool can create conditional grafts on characters too. It'll work on any character/figure, clothing, environments, props, etc, including Poser content. The only thing it won't work on is strand-based hair, since those aren't polygonal models, and so don't support conditional grafts.
    Hiding everything but the arms should be pretty straightforward too, here's my attempt at Genesis 8 Orc cosplaying as Goro. The only problem is that, as Richard mentioned, the shoulders for the extra arms will be intersecting with the base model, so you won't get a perfect transition with the rest of the torso. To get it looking perfect, you'd actually want to create a proper geograft between the extra arms and torso, which would require some modeling work and texturing at the seams. But if you don't need perfection, then this works fairly well. You can parent the model with just the arms to one of the spine/chest bones so that, as you pose the base character, the extra arms move along with the rest of the torso.
    1222 x 1054 - 209K
    1222 x 1054 - 67K
    1222 x 1054 - 177K
  • SotoSoto Posts: 1,451
    edited April 6
    I just wanted to say thank you for this awesome product. It's simplifying my work, and less steps means less chance for a mistake :)
    Post edited by Soto on
     Hey, thanks for that! Happy to hear you've found it helpful. I'm quite the fan of your work as well, so it's an honor to know that I've been helpful to your workflow!
