• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Need help with importing Linday's Classic Long Hair with dForce to Blender
usahawansufi6c2usahawansufi6c2 Posts: 38
May 2025 in Blender Discussion
I want to be able to import this hair: https://www.daz3d.com/classic-long-hair-with-dforce-for-genesis-8-females and simulate it in Blender, but it causes lags to Blender and I cannot turn this hair to particle for simulation.
Please, if anyone can help me... I am willing to pay you as well if you can solve this problem for me.
  • PadonePadone Posts: 4,353
    May 2025
    With diffeomorphic you can convert geometry hair to hair curves, including simulation. There's also a "sparsity" option to reduce the hair strands.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Features/Hair Tools
  • usahawansufi6c2usahawansufi6c2 Posts: 38
    May 2025
    Hi Padone. I am already using Diffeomorphic, but when I try to use the "make hair" function, the Linday's classic hair just disappears from my viewport and also from Objects pane :(. I have been dealing with this issue for months and haven't found a solution till now.
    May 2025
    If the hair disappears it can be because you selected the wrong type so none of that type is found. From the product page it seems these hairs are tubes instead of strands, so be sure to use the "tube" option.
    In general daz hairs can be very cumbersome and don't fit to animation, be sure to use the sparsity option to reduce the strands, then in blender you can always use children to fill the gaps, which follow parents and don't crowd the viewport. Also be sure to update to the latest development version so you get the most recent bug fixes, as there's some for hair curves too, don't use the stable version as it doesn't get fixed anymore once released. When converting keep an eye at the windows task manager to check how the system memory goes, after conversion check the blender system console for any error.
    Let me know how it goes.
    https://bitbucket.org/Diffeomorphic/import_daz/downloads/
    208 x 428 - 21K
    May 2025
    Thank you, Padone. Let me try this and I will get back to you shortly.
    May 2025
    Hi Padone, I've tried that but it didn't work :( This is sooo demotivating, I am considering quitting Blender at this point. I've spent so much on Linday products, I just want to make them work inside Blender... I don't want to have to make my own hair system...
    1532 x 958 - 1M
    May 2025
    You're using 4.3.0, again please update before reporting bugs, the current version is 4.4.0.2607 at the link I provided before.
    May 2025
    My bad. Is the version 4.4 for Blender or Diffeomorphic? Should I be updating both softwares?
    May 2025
    The 4.4 importer works with blender 3.x 4.x.
    May 2025
    Hi Padone. I just updated the script to 4.4 and it's working a lot better now but the result looks funny... Are there settings that I can follow to maintain the original look of the hair even after the conversion?
    1756 x 906 - 816K
    May 2025
    That looks suboptimal. You can reach the hair modifiers in the modifiers tab and play with the parameters or add new modifiers depending on the effects you want. The hair tools are mainly tested with strand hairs and transmapped hairs, so it is possible that tubes have bugs. My advise is to use strand hairs with a haircap to export to blender, the Linday's hairs look quite original, you probably should abandon them in favor of more standard options.
    However, I'm going to test them myself and let you know how it oges, eventually reporting bugs to Thomas.
    397 x 606 - 60K
    May 2025
    Ok, I had a look. The Linday's hair are basically geometry tubes with dforce applied, they don't really fit to be converted to strands. My approach was to don't convert at all but keep them as they are and just apply a cloth modifier for simulation. Or you can simulate in daz studio then export the shape as dbz.
    For the cloth modifier I used the cotton preset, and the dforce pin group with some stiffness. It went quite well here, screenshot attached.
    681 x 299 - 47K
    May 2025
    I am going to try this and get back to you.
    Just one question before I go: should I simulate the hair in Daz3D first before exporting to Blender and applying the cloth modifier?
    May 2025
     Okay, so I tried this method and my whole PC slowed down :( Not sure what am I doing wrong now.
    May 2025
    The Linday's hair has some shape presets for simulation, if you want to simulate in blender then export those shape presets. The viewport slows down because the cloth modifier is active, you usually disable the cloth modifier and all other phisics simulation during animation, then run the simulation as a last step after the animation is in place.
    To disable a modifier go to the modifiers tab then use the realtime and render icons, depending on what you want to disable. I'd advise you to take some tutorials online about using phisics in blender and the cloth modifier, if you're interested. Otherwise just simulate in daz studio then export the baked shape if you're more comfortable with that.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
