• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Mis-sized bones from Daz -> Diffeomorphic -> Blender
keirankingkeiranking Posts: 0
May 2025 in Blender Discussion
I am a beginner. When I try to move a 3rd-party Genesis 9 figure in T-pose from Daz to Blender via Diffeomorphic, the arm and hand bones end up the wrong size and position in Blender, and seem to match the size and position of a 'standard' Genesis 9 figure. I've tried fiddling with Daz and Diffeomorphic settings, but I'm at a loss how to correct this after a couple days of searching and trying. Any help or guidance would be appreciated.
  • PadonePadone Posts: 4,061
    May 2025
    If you're using the morphed option for figures, and/or ERC morphs, then this is as intended. Only the dbz option will bake the bones from daz. However, that is only a visual nuisance and the figures will work fine, as what matters it the bone pivot that's correctly preserved.
  • keirankingkeiranking Posts: 0
    May 2025
    Thank you, Padone. I've tried importing using as many different configurations as I can (including Mesh Fitting both Morphed and DBZ File), but the problem persists. I've attached a picture showing the mis-aligned/mis-sized bones, and how the bone distorts the hand when rotated.
    510 x 479 - 203K
    May 2025
    That is not possible if you use dbz. It happens if you apply a ERC morph without fitting the armature. You have to enable "ERC as armature" in the global settings, then use "morph armature" in the morphs panel. Or provide exact steps to reproduce the issue.
    https://diffeomorphic.blogspot.com/2021/09/morphing-armatures.html
    May 2025
    Thank you, Padone. Documenting the solution in case other beginners run into the same issue. On investigation, the problem was neither Blender nor Diffeomorphic. In Daz, the mesh was morphed without any adjustment of the rigging. I saw where others used Adjust Rigging to Shape in similar situations, but in this case it had no effect.
    I recreated the character from scratch, changing the sliders for the morph manually rather than by applying the preset 'character'. The wrists and hands adjusted as expected. Moving the figure from Daz to Blender via Diffeomorphic was then trivial.
    Root cause: Maybe a bug in Daz or in the preset, maybe beginner user error.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
