Clothing Smoothers for G2F - where and how?
TaozTaoz Posts: 10,371
I've installed this:
http://www.daz3d.com/clothing-smoothers-for-daz-genesis-2-female-s
but can't find it anywhere in DS. Can't find any documentation for it either. Can anyone give me a clue?
  • LeanaLeana Posts: 13,615
    You won't find anything in your library, if that's what you're looking for. It's only a set of morphs added to G2F, you should find them in the shaping or parameter tab when you select G2F.
    When you want to use a smoother use the G2F morph, it won't change the shape of G2F herself but will be projected on the clothes and morph them.
  • IceCrMnIceCrMn Posts: 2,334
    edited September 2015
    Those types of things are normally found on the character and not the clothes.Have a look in the parameters tab under actor, there should be a few new sliders there.You may have to select a specific body region.
    edit: ooops we posted at the same time :)
    Post edited by IceCrMn on
  • NadinoNadino Posts: 258
    For this particular product the sliders are found in both the Parameters and Shaping Tabs.
    While having no visible effect on the figure - conforming items will display the changes.
    642 x 627 - 232K
  • TaozTaoz Posts: 10,371
    Ah, OK - found it now. Works great btw...
    Thanks! smiley
