Clothing Smoothers for G2F - where and how?
Taoz
in The Commons
I've installed this:
http://www.daz3d.com/clothing-smoothers-for-daz-genesis-2-female-s
but can't find it anywhere in DS. Can't find any documentation for it either. Can anyone give me a clue?
You won't find anything in your library, if that's what you're looking for. It's only a set of morphs added to G2F, you should find them in the shaping or parameter tab when you select G2F.
When you want to use a smoother use the G2F morph, it won't change the shape of G2F herself but will be projected on the clothes and morph them.
Those types of things are normally found on the character and not the clothes.Have a look in the parameters tab under actor, there should be a few new sliders there.You may have to select a specific body region.
edit: ooops we posted at the same time :)
For this particular product the sliders are found in both the Parameters and Shaping Tabs.
While having no visible effect on the figure - conforming items will display the changes.
Ah, OK - found it now. Works great btw...
Thanks!
