• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeomorphic Add-ons Version 5.1.0 Released
«1234»
  • DeovanDeovan Posts: 5
    January 2025
    @Padone
    I managed to export and import through Thomas plugin but the HD mesh still doesn't have any materials applied and none of the meshes are bound to the armature. And it doesn't divide the meshes into "Raw" & "Raw_HD".
    The meshes don't come with the armature modifier applied.
    331 x 250 - 15K
  • PadonePadone Posts: 4,084
    January 2025
    Be sure to update, then use easy import with the correct preset for your figure, there's from G1 to G9.
    https://bitbucket.org/Diffeomorphic/import_daz/downloads/
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Import/Easy Import DAZ
  • automaticcolorsautomaticcolors Posts: 34
    January 2025
    I am converting filatoon models from daz to blender. Diffeomorphic is especially useful since Filatoon is not yet supported by daz on Macs. By the way, why does Diffeomorphic convert the outline to freestyle?
    DAZ displays the Filatoon outline as an inverted hull. So I want to use the solidify modifier (outline helper) in Blender to add an outline with an inverted hull. I would like to use the solidify modifier in Blender as well because it is more compatible and can be displayed in viewports, and since DAZ models have many polygons, Freestyle is too heavy and impractical.
    Could you add an option to convert to sokidify modifier if you like?
    January 2025
    Okay it's fixed. I don't know what it was but for some reason it works if I first load up the default Genesis 9 character in Daz Studio and then apply the character shape I want and export it.
    What didn't work for me was when I loaded the character I want with the authors provided scene subset and then exported that. Guess there must be some weird setting in that scene that ruins it.
    January 2025 edited January 2025
    @automaticcolors Freestyle was chosen because it doesn't affect the viewport, so it is better to animate, I agree that with rendering it may be somewhat slow. Using inverted hulls would affect the viewport and slow down animation, but it is certainly an option. It was proposed to Thomas to add options for the outline but he didn't seem interested. When I have some time I'll try again.
    update. Now there's options for the toon outline so we can choose among freestyle or greese pencil or solidify.
    https://diffeomorphic.blogspot.com/2025/01/with-daz-studio-4.html
    Post edited by Padone on January 2025
    January 2025
    Thanks and Please
    Viewport display is the most important for Japanimation.
    Viewport Display And Rendering - Pencil+ 4 Line for Blender
  • magrejun_115b1e76d6magrejun_115b1e76d6 Posts: 4
    January 2025
    @Padone, Thanks.
    Archive provided by you seemed to work(no errors at least), but this means that downloadable "Stable version 4.3.0" available through Wiki-Page on https://bitbucket.org/Diffeomorphic/import_daz/wiki/Home is outdated.
    January 2025
    Though Thomas does some efforts to publish a stable version, the latest bugs are only fixed in development, so personally I always use the dev version and advise to do so. I agree this may be confusing but this is it.
  • lioncrudlioncrud Posts: 29
    January 2025
    i was able to import my charcter no prob, however in the Daz Setup tab, the Rigging section/dropdown has no options there.  It used to say things like "Convert to MHX" but it's just nothing now...not sure what I may have done wrong. I installed the MHX Runtime zip as well and have it active in my Blender Addons preferfeences, and the MHX tab is in my UI next to the Daz Setup tab.
    January 2025
    answering my own question...looks like i installed the deelopment version of daz importer instead of the stable version. I also mde sure to check the rigging box in the Blender add-ons preferences section under Daz importer. That fixed it.
  • istevee2.0istevee2.0 Posts: 0
    January 2025
    Python: Traceback (most recent call last):
      File "C:\Users\Dimensionary\AppData\Roaming\Blender Foundation\Blender\4.2\extensions\user_default\import_daz\error.py", line 200, in execute
        self.run(context)
      File "C:\Users\Dimensionary\AppData\Roaming\Blender Foundation\Blender\4.2\extensions\user_default\import_daz\main.py", line 739, in run
        self.easyImport(context)
      File "C:\Users\Dimensionary\AppData\Roaming\Blender Foundation\Blender\4.2\extensions\user_default\import_daz\main.py", line 756, in easyImport
        bpy.ops.daz.import_daz_manually(
      File "C:\Program Files\Blender Foundation\Blender 4.2\4.2\scripts\modules\bpy\ops.py", line 109, in __call__
        ret = _op_call(self.idname_py(), kw)
    RuntimeError: Error: Python: Traceback (most recent call last):
        self.run(context)
      File "C:\Users\Dimensionary\AppData\Roaming\Blender Foundation\Blender\4.2\extensions\user_default\import_daz\main.py", line 230, in run
        self.loadDazFile(filepath, context)
      File "C:\Users\Dimensionary\AppData\Roaming\Blender Foundation\Blender\4.2\extensions\user_default\import_daz\main.py", line 123, in loadDazFile
        fitToFile(filepath, main.nodes)
      File "C:\Users\Dimensionary\AppData\Roaming\Blender Foundation\Blender\4.2\extensions\user_default\import_daz\dbzfile.py", line 366, in fitToFile
        dbz.fitFigure(inst, dbzrig)
      File "C:\Users\Dimensionary\AppData\Roaming\Blender Foundation\Blender\4.2\extensions\user_default\import_daz\dbzfile.py", line 80, in fitFigure
        self.fitFigure(child, dbzchild)
      File "C:\Users\Dimensionary\AppData\Roaming\Blender Foundation\Blender\4.2\extensions\user_default\import_daz\dbzfile.py", line 76, in fitFigure
        inst.restdata = dbzrig.restdata["NODE"]
    AttributeError: 'NoneType' object has no attribute 'restdata'
    Location: C:\Program Files\Blender Foundation\Blender 4.2\4.2\scripts\modules\bpy\ops.py:109
    I got  this error trying to use the latest diffeomorphic addon on blender 4.2. How do i fix this?
  • phimetaversephimetaverse Posts: 11
    February 2025
    hey, im converting as i usually would but now my shapekeys are no longer converting into blender with my character & the eyelids no longer move with the eyes. im using blender 2.93 as suggested & the latest version of diffeomorphic. i have always successfully converted a character with the shapekeys & the eyelids able to move, but now for some reason it doesnt want to work. thanks :)
    February 2025
    update: i tried blender 4.2.4, managed to get the shape keys and the eyelids to move with the eyes but it takes an awful long time (over an hour to import into blender), now instead of the previous issues, the weights are broken on my characters face when posing the eyes. i just want to clarify i do have 4 years experience in blender & about 2 years experience when it comes to converting daz g9 to blender, so im not a newbie... but i am at a loss right now.
    1152 x 2048 - 593K
    February 2025
    You have to import G9 with FACS to get the eyelids to follow, in easy import there's a G9 preset you can use. Just tried and works fine here.
    diffeomorphic 4.4.0.2526 blender 4.3.2
    203 x 179 - 10K
    February 2025
    thanks, i ticked the FACS boxes but it wasnt this version of diffeo or blender, ill try this again now and come back with a result :)
    February 2025
    okay so it did work providing i didnt use any geografts, this being the gauged ears. as soon as i use the gauged ears, this is what happens. (photo attached). i ticked all the relevant boxes and enabled the addons for it to work. i really do hope this can be fixed, thank you for the advice on the versions of software i needed to use!
    1240 x 1002 - 427K
    February 2025 edited February 2025
    Yes I can see the issue when we export as HD, while non-HD works fine. This is probably due to the geograft being for the head, while we generally tested with body geografts. One workaround is to import without merging geografts, then merge by hand as a last step.
    https://www.daz3d.com/cgi-gauged-ears-for-genesis-9
    my steps:
    1. In daz studio load G9 with the gauged ears.
    2. Enter the geometry editor and export as HD with the HD convention, marking as HD only the figure and not the gauged ears.
    3. In blender easy import with "FACS" without "merge geografts"
    4. Then merge geografts as a lst step: setup > finishing > merge geografts
    Anyway, now reported to Thomas to see if this can be fixed.
    https://bitbucket.org/Diffeomorphic/import_daz/issues/2398/
    update. Fixed in the last commit.
    501 x 219 - 34K
    Post edited by Padone on February 2025
    February 2025
    my steps:
    Thank you, I exported the ears seperately last night and merged them onto the body :) Will reconvert if & when it can be fixed. Her weights & shape keys now work with no issues, so I'm super grateful for that. Again, thank you for helping me. :)
    919 x 1080 - 1M
    March 2025
    I need your help.
    I install Blender4.32portable, DAZ 4.23.01 and Diffeomorphic 4.3.0.
    I can see Nothing in Operator Presets.
    Would you mind telling me how to fix it?
    930 x 1304 - 162K
    March 2025
    Probably you deleted the preferences, which are in the "daz importer" folder under "documents". Just reinstall and don't delete anything.
    327 x 156 - 16K
  • crosswindcrosswind Posts: 9,749
    March 2025 edited March 2025
    automaticcolors said:
    I need your help.
    Open File Browser, go to the folder : %appdata%\Blender Foundation\Blender\4.3\scripts\presets\operator\daz.easy_import_daz  Check if you can find the preset py files... (ss1)
    Re-installation should fix the issue. Let us know if that won't help... or you can find the preset py files but the issue still persists ~~ or maybe the culprit is Blender Portable version... I've never used it yet.
    1672 x 367 - 46K
    Post edited by crosswind on March 2025
    March 2025
    I need your help.
    By using the regular version of Blender instead of the portable version of Blender, I was able to solve my problem. Thaks!
    March 2025
    I have imported G9 toon. But there is no contour line.
    I have checked the global settings in Deffeomorphic and there is no contour line setting.
    Can someone help me?
    Blender 4.32 Diffeomorphic 4.3.0 DAZ Studio 4.23.0.1
    2880 x 1920 - 930K
    Outline option was given to a certain minor version of 4.3.x+... suggest you directly install the latest development version in here (4.4.0.xxxx): https://bitbucket.org/Diffeomorphic/import_daz/downloads/
    And refer to: https://diffeomorphic.blogspot.com/2025/01/with-daz-studio-4.html
    2560 x 1392 - 679K
    March 2025
    I install the latest development version and get outline! Thanks!!!
  • ThomasLarssonThomasLarsson Posts: 100
    April 2025
    Version 4.4.0 has been released. See first post in this thread.
    • DAZ Importer: https://www.dropbox.com/scl/fi/ikl7ewt2vyry4yokmexee/import_daz-4.4.0.zip?rlkey=6icungsgz5e2jf1xrfp4tu6a1
    • MHX Runtime System: https://www.dropbox.com/scl/fi/wr5pe0azugvoqwx071uy1/mhx_rts-4.4.0.zip?rlkey=yj839xajudf5rzeuln9l4u1vi
    • BVH and FBX Retargeter: https://www.dropbox.com/scl/fi/jp7t4j6q9r00y0b7ufhxx/retarget_bvh-4.4.0.zip?rlkey=aecabc76pafykzqh54m9d6y1v&st=ap5ywyda
  • Singular3DSingular3D Posts: 637
    April 2025
    Thanks a lot Thomas. You are amazing!
  • riuken1riuken1 Posts: 157
    May 2025
    Hello Thanks for the addon. Question, do this version work with blender 4.4.3 just trying to be sure to download the correct version.
    May 2025
    The 4.4 addon works fine with blender 3.x 4.x
  • brainmuffinbrainmuffin Posts: 1,285
    May 2025
    I know this may sound odd, but I've never installed Diffeo on Windows (only Mac and Linux) as I tended to pull the git repo and build a zip. How are people typically installing?
«1234»
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
