Tutorial: Making TriAx Figures from Old Parametric Characters
124»
  • If it's a genesis clone, yes Natu should be modified to be as close as possible to the default Genesis shape. Where the Genesis model is outside the Natu clone shape model, there will be an axtra gap between the clothes & Natu when Genesis clothes are fitted. When the Genesis shape is inside the Natu clone shape, there is a possibility of pokethrough.
    Regards,
    Richard
  • Is it possible to show a clay render of the Natu clone obj at 0,0,0 at the same time as a different coloured clay render of Genesis at 0,0,0? That way we can see how close the clone shape is to Genesis.
    Regards,
    Richard
  • TorquinoxTorquinox Posts: 4,511
    Maybe for personal use and rendering this is a case where it will make more sense to make a natu morph for Genesis of choice?
  • CriosCrios Posts: 3,003
    No, because my attempt is to emprove Natu dressing Genesis clothes.
  • richardandtracyrichardandtracy Posts: 7,471
    edited February 2025
    Agreed, and that's what I want to get to.
    It really would be useful to show a clay render of the Natu clone obj at 0,0,0 at the same time as a different coloured clay render of Genesis at 0,0,0. That way we can see how close the clone shape is to Genesis, a screenshot of the genesis autofit clone parameter settings (like on page 3), and a screen shot of the parameters list that you'e worked to create (with any hidden ones showing too). Is there a chance you've got a Genesis 1 morph and a Genesis 1 autofit clone with the same name? If it's happened, it would seem likely that DS doesn't really know which to activate & it all goes odd.
    Final request for the moment - is it possible to see Natu with Genesis clothes so we can see what it looks like maybe close in where things may be going wrong?
    Regards,
    Richard
    Post edited by richardandtracy on
    Gimme a couple of day Richard, and i will post them
  • Thanks. I don't mean to harass you, not my intention, but it bugs me you've run into a problem and I would like to find out what it is. Regards, Richard.
    You've right, gimme just a bit of time, because I'm little busy in these days.
