Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
You should have your G9 character and the pose selected when you select the script. The screenshot appears that you not have a pose selected in your content library, but I could be wrong.
I just purchased the product for doing batch poses. When I double-click it from the Scripts menu, I get the error, "Can't find the required base product: Genesis 3 & 8 to 9 Pose Converter. Please make sure it is installed before running the script." I was able to run the Settings dialog box where I assigned a shortcut, but the shortcut gives the same error.
It was indeed installed and "Genesis 3 & 8 To 9 Batch Pose Converter.dse" appears in my "C:\Daz 3D\Applications\Data\DAZ 3D\My DAZ 3D Library\Scripts\Genesis 3 & 8 to 9 Batch Pose Converter" folder. What do I need to set to ensure the program is found when I double-click on it?
Here is the log file for my error mentioned above:
2024-10-04 16:44:39.475 [INFO] :: Loading script: C:/Daz 3D/Applications/Data/DAZ 3D/My DAZ 3D Library/Scripts/Genesis 3 & 8 to 9 Batch Pose Converter/Genesis 3 & 8 To 9 Batch Pose Converter.dse
2024-10-04 16:44:39.488 [DEBUG] ::
085cc16a-76b3-4c5a-828c-52aeada5a077
G3 and G8 to G9 Batch Pose Converter 1.0 (Dev 8)
OS: Windows 11, Build 22631, Workstation
Bit Architecture: 64
DS Version: 4.22.0.19
DS Edition: Pro
DS Release Cycle: General Release
RKEY: 085cc16a-76b3-4c5a-828c-52aeada5a077
Script: C:/Daz 3D/Applications/Data/DAZ 3D/My DAZ 3D Library/Scripts/Genesis 3 & 8 to 9 Batch Pose Converter/Genesis 3 & 8 To 9 Batch Pose Converter.dse
2024-10-04 16:44:39.491 [DEBUG] :: #KWd6HB: Unable to find abs path for base product.
2024-10-04 16:44:41.459 [DEBUG] :: #dY1w9Y: Original Pose Converter base product not found.
2024-10-04 16:44:41.460 [INFO] :: Script executed successfully: C:/Daz 3D/Applications/Data/DAZ 3D/My DAZ 3D Library/Scripts/Genesis 3 & 8 to 9 Batch Pose Converter/Genesis 3 & 8 To 9 Batch Pose Converter.dse
Well if you guys aren't going to help me make your product work, I guess I will have to ask for my money back.
Hi. Sorry I don't always get notified of forum activity. Do you have the base product installed? It is a requirement. Your log says it cannot locate the base product.
I don't know how to determine if the base product is installed. All I know is that I downloaded a file, IM00088686-01_Genesis3and8to9BatchPoseConverter.zip, from Daz and installed the items in the Content folder as I normally would. I reinstalled it again this morning, but now the Settings script won't even display the dialog box. When I tried it, I get this log file:
2024-10-17 10:32:30.801 [INFO] :: Loading script: C:/Daz 3D/Applications/Data/DAZ 3D/My DAZ 3D Library/Scripts/Genesis 3 & 8 to 9 Batch Pose Converter/Genesis 3 & 8 To 9 Batch Pose Converter Launch Settings.dse
2024-10-17 10:32:30.803 [DEBUG] :: ======================================================
2024-10-17 10:32:30.803 [DEBUG] :: Pose Converter Launch Settings
2024-10-17 10:32:30.804 [DEBUG] :: #gK19ed: Custom Action Name: G3 and G8 to G9 Batch Pose Converter
2024-10-17 10:32:30.805 [DEBUG] :: #jwY7S1: Custom Action Index: 15
2024-10-17 10:32:30.805 [DEBUG] :: #KOsoGa: Custom Action Shortcut: Ctrl+P
2024-10-17 10:32:30.805 [DEBUG] :: #gK19ed: Custom Action Name: G3 and G8 to G9 Batch Pose Converter
2024-10-17 10:32:34.644 [INFO] :: Script executed successfully: C:/Daz 3D/Applications/Data/DAZ 3D/My DAZ 3D Library/Scripts/Genesis 3 & 8 to 9 Batch Pose Converter/Genesis 3 & 8 To 9 Batch Pose Converter Launch Settings.dse
So it looks like the Settings script is executing, but it doesn't do anything. If I run the app, I get this log file:
DS Version: 4.23.0.1
DS Edition: Pro
2024-10-17 10:35:38.831 [DEBUG] :: #KWd6HB: Unable to find abs path for base product.
2024-10-17 10:35:45.577 [DEBUG] :: #dY1w9Y: Original Pose Converter base product not found.
I don't understand where it is trying to look for the product.
Note that I upgraded Daz Studio to Ver 4.23.01 yesterday.
Base product needs to be purchased and installed. The batch converter is an addon for the base product, and requires the base product.
Oh goodness! I didn't notice that there was a requirement for this product! Of course, now I see what you mean by "base product"! I will purchase it now. Thanks for your patience with my absentmindedness.
NP. Thanks for the support.
Hi all- I'm having the same issue here... batch converter works fine, single pose converter does not. Windows 11, DS 4.23. I don't use the connect / smart content in DS since I keep getting the "...valid PostgreSQL cms connection could not be established..." message on startup, so I can't even if I wanted to (no biggie there, my content library still works fine otherwise). These scripts are both installed on the same external drive via DIM (since I use several different HD's for content)- Have uninstalled, reinstalled, cleared caches, etc. nothing seems to work thus far...?
I checked the log file, and it appears that it's trying to locate/call the script on a different drive from where it's currently installed. I did originally have all my Genesis products on that drive, but had to move some to a new drive due to space. (and there have been DIM/user snafus in the midst of the changes). These scripts are in the batch that got moved. I'm going to try to manually remove the files (from the old location) listed in the "installed files" list in DIM, then unistall and reinstall to the new location again and see if that works...
OK, that didn't work either. I've attached the screenshot of the log file where the warning shows up (about half way down). I ran the batch converter after, and it still works fine and calls the correct location (D:GenesisChars)
Any help is appreciated!
Thanks! ~Amy / featherwitch
Hello, the script no longer works for me. I have tried to install a new one for daz3d studo 4.23 several times. It does not work and I do not get any error messages.
I urgently need this script for my promo. -.-,
I hope that there might be an update in the future...
Chasoqueen
I have tried adding instructions.png to the suggested folder but I am still getting the error message about base pose converter not being found. The single pose converter works fine, I was just hoping to use the batch. Running Daz Studio 4.23.0.1
Why didn't it come with the pose corrector? It was very useful and fast for me with the previous Genesis figures pose converter.
why doesn't it work???? the green gear supposed to be appear but it didn't... I used it and nothing happened.
I selected G9 and selected G8 pose and look at what happened. what do I do???
Hi. It was not needed. Having a pose selected and doing a direct conversion was a better solution.
Is the pose file highlighted when script is ran?
Hi. Works fine on my side.
I just happened to use the script today to try some G3 and G8 poses on one of my G9 characters.
It worked beautifully (as it always has.)
I'm on DS 4.23.1.27 (Beta) on a Mac.
The steps I use are:
1) select figure in viewport
2) select pose file in Smart Content
3) select script from the Scripts menu
4) wait a moment and the pose is applied
5) close the script dialogue box
This script works like magic. I've always been very impressed by this quality product.
Thanks, Zev0!
Lee
Thanks for the kind words
I believe it doesn't work because I have a download icon on the product. It happened as I deleted all of Daz Studio and products and reinstall everything on another drive. I don't know how daz connect work but I'll find a way to solve. I will let you know once I sort it out.
I did what you do and nothing happens. your script has a icon and mine doesn't. Why?
[Oh, goodness]! this product is in daz connect-- that's why it doesn't work! How can I disable daz connect and use it through DIM???
According to your screenshot it is not installed through Connect - the arrow in a circle means it is available for installation through Connect.
I installed it and now I got this
You should not have installed it through Connect - unfortunately the store doesn't "know" that some script products are not written in a way that works with Daz Connect instalaltion and shows them as available; stick to DIM (or manual) installation for script products unless the writer explicitily states that they are Connect compatible..
I managed to fix it in hard way. Now I can make my character pose easily with your product in different way. Scripts may be not work but it does work under smart content. I know it is strange but I like this way instead. good day.
Hi, does not work for me. I select a G9 caracter, then a G8 or G3 pose and use the shortcut i create, and nothing happen.
It telles me that the product isn't installed.
Hi, nothing has worked for me for a long time, since 4.23 Daz3DStudio. I have to say I find it quite frustrating.
I have tried several things, I can't get them to work.
