Daz Studio and Linux
1525355575869
  • RattelerRatteler Posts: 27
    edited December 2024
    I got the installer to run under Wine/Linux Zorin Linux 16, but I get the follow error message when I start DAZ Studo, and none of my products appeaar even though they seemed to install.
    HP Probool 650 G1I/I7/16GB/2TB SSD.
    HALP!
    1009 x 353 - 23K
    Post edited by Ratteler on
    HALP!
    I remember PostgreSQL being an issue in earlier wine versions (I think wine 7.X or something). But that was quite a few years ago.
    What wine version are you using (wine --version)? Have you tried wine-staging?
    Seems like I'm on wine 6.0.3.
    I'll see if there is an upgrade.
    It complain hen I try I upgrade update.
     winehq-stable
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    Some packages could not be installed. This may mean that you have
    requested an impossible situation or if you are using the unstable
    distribution that some required packages have not yet been created
    or been moved out of Incoming.
    The following information may help to resolve the situation:
    The following packages have unmet dependencies:
     winehq-stable : Depends: wine-stable (= 9.0.0.0~jammy-1)
    E: Unable to correct problems, you have held broken packages.
  • brainmuffinbrainmuffin Posts: 1,324
    I've had quite the success going back to Lutris to do the installs. Even have the simulation running.
  • I got everything to run great in Fedora 41 using the fusion RPM version of Wine and the flatpak version of Doors.
  • I installed everything using this excellent instructions in here on Arch.
    But I have an issue that I cant select anything in the viewport. It's like no object was loaded (but I see it obviously).
    Any suggestions ?
    Any suggestions ?
    Which tool is active?
    Any suggestions ?
    It's the wine10.0-staging - from multilib repos.
    I've installed the nvidia-libs0.8.1 (the latest release from repos).
    Appreciate your help.
    cheers.
    Any suggestions ?
    cheers.
    I meant which Daz Studio tool (checked in Tools menu) just in case it wasn't actually a Linux issue.
    Any suggestions ?
    cheers.
    It's Daz Version 4.23.0.1
    Any suggestions ?
    cheers.
    I was asking about the tool that was active - open the Tools menu and see which is checked.
    Any suggestions ?
    cheers.
    It was the Universal Tool, but it didn't work in Translate or Rotate Tool either.
  • Ok I solved it. It seems I have played around in the Interface Settings and activated the Pixel Buffer and set it to on.
    After disabling it, the selection is working again.
    Thanks for your help Richard.
    Cheers.
  • Sorry but I have to come back.
    While the IRAY Rendering performance under Lutris/Linux is close to Windows, the viewport rendering is very slow - like 2 fps slow. I use texture shading, so nothing really too fancy.
    Edit>Prefernces>Interface tab has several settings related to draw performance, check that the two system match and/or try nudging them in the direction of performance.
    Thanks again!
    I enabled the Hardware-Antialiasing and set the Display Optimization to Best - runs smooth and fast like in Win.
  • korbkorb Posts: 18
    edited February 2025
    korb said:
    ...and I will reply to myself one more time - I can have the best of both worlds, according to this reddit post:
    https://www.reddit.com/r/linux_gaming/comments/uswuv6/how_to_set_folder_as_caseinsenstive_with_btrfs/
    About ten replies in I found this gem:
    Use ZFS. It lets you create case insensitive filesystems from pools by doing zfs create casesensitivity=insensitive $pool/$fs.
    So I'll try my new 4.22 installation on a new WINE C drive and also put the entire installation in a zfs filesystem with case insensitivity enabled. It may take me a few days to find the time to work on this, but if/when I do and can confirm, I will reply to this and let you all know how I fared.
    Well, it took me considerably more than "a few days" - more like a few months. I had a hot project that I needed to wrap up before I could risk screwing things up. Anyways...I have validated this approach, and it works!
    I'll summarize here for anyone that wants to try to replicate this configuration.
    First off, my configuration:
    • OS: Linux Mint 21 Cinnamon
    • CPU: Intel Core i9
    • RAM: 128GB
    • Storage: 7TB nVME M.2 drives
    • GPU: nVidia GeForce RTX 4080 w/ 16GB VRAM
    • nVidia driver version: 550.120
    Probably the only important part of that is the OS & GPU/driver info, but I wanted to be up front. I suspect this will work on newer systems than mine (about a 2-year-old build) as well as older. Note that this post assumes you have already configured ZFS on your system. Not all distros include (or even support) ZFS, but anything that forked from Ubuntu should have it (like Mint).
    One caveat up front: I did not do a clean install of Mint, so I cannot tell you exactly which packages I installed to get this working. I will share what I feel is pertinent, but you will need to know enough about Linux to discover and install any missing packages as you move ahead on this. Installing & configuring Linux is beyond the scope of this post.
    NOTE: There are many commands run at the Linux command line in this post. Lines that start with "#" are run as root (or sudo root). Lines that start with "$" are run as a non-privileged user - in my case, as "korb".
    Setting Up Your New WINEPREFIX and Installing DAZ 3D Studio
    Since NTFS is a case-insensitive filesystem (that is, files name "abcd", "Abcd", and ABCD" are all the same file), we need to create our WINE instance in a similar filesystem. While NTFS filesystems can be used on Linux, ZFS is a far more advanced and capable filesystem, and in fact, does support creating a filesystem with case-insensitivity enabled.
    # zpool list
    NAME    SIZE  ALLOC   FREE  CKPOINT  EXPANDSZ   FRAG    CAP  DEDUP    HEALTH  ALTROOT
    bpool  1.88G   443M  1.44G        -         -     7%    23%  1.00x    ONLINE  -
    rpool  5.44T  1.80T  3.63T        -         -     4%    33%  1.00x    ONLINE  -
    # zfs create -o casesensitivity=insensitive -o mountpoint=/daz rpool/daz2025
    # df -h /daz
    Filesystem      Size  Used Avail Use% Mounted on
    rpool/daz2025   3.6T  128K  3.6T   1% /daz
    Once the filesystem is created, we can validate that it works as expected. First, demonstrate a filesystem that is not case-insensitive:
    $ echo "This is a test of ZFS case insensitivity." > /tmp/README.txt
    $ cat /tmp/README.txt /tmp/readme.txt /tmp/Readme.txt
    cat: /tmp/readme.txt: No such file or directory
    cat: /tmp/Readme.txt: No such file or directory
    In our new case-insensitive filesystem, however, it works as desired:
    $ echo "This is a test of ZFS case insensitivity." > /daz/README.txt
    $ cat /daz/README.txt /daz/readme.txt /daz/Readme.txt
    Now that we have our target filesystem, we need to create a WINE installation within this new filesystem where we will subsequently install Daz Studio. This installation is on Linux Mint 21 using wine 10.0-rc3 (Staging).
    $ which wine
    /usr/bin/wine
    $ wine --version
    wine-10.0-rc3 (Staging)
    To get the wine installation placed in our new ZFS filesystem, we have to supply a WINEPREFIX that will reside within that filesystem. I will just create an entirely new WINEPREFIX within my new /daz filesystem: /daz/.wine
    Get the latest nvidia-libs from github: https://github.com/SveSop/nvidia-libs/releases
    Unpack the nvlibs into /opt. I do this as my non-privileged user by using sudo to grant myself the needed permission, though you could unpack it using sudo and let root own the files.
    $ tar -xvJf /ptmp/downloads/nvidia-libs-0.8.1.tar.xz
    nvidia-libs-0.8.1/
    nvidia-libs-0.8.1/version
    nvidia-libs-0.8.1/x64/
    nvidia-libs-0.8.1/x64/nvcuvid.dll
    nvidia-libs-0.8.1/x64/nvencodeapi64.dll
    nvidia-libs-0.8.1/x64/wine/
    nvidia-libs-0.8.1/x64/wine/x86_64-unix/
    nvidia-libs-0.8.1/x64/wine/x86_64-unix/nvml.so
    nvidia-libs-0.8.1/x64/wine/x86_64-windows/
    nvidia-libs-0.8.1/x64/wine/x86_64-windows/nvml.dll
    nvidia-libs-0.8.1/x64/nvapi64.dll
    nvidia-libs-0.8.1/x64/nvoptix.dll
    nvidia-libs-0.8.1/x64/nvcuda.dll
    nvidia-libs-0.8.1/x64/nvofapi64.dll
    nvidia-libs-0.8.1/Readme_nvml.txt
    nvidia-libs-0.8.1/proton_setup.sh
    nvidia-libs-0.8.1/bottles_setup.sh
    nvidia-libs-0.8.1/bin/
    nvidia-libs-0.8.1/bin/nvapi64-tests.exe
    nvidia-libs-0.8.1/package-release.sh
    nvidia-libs-0.8.1/x32/
    nvidia-libs-0.8.1/x32/nvcuvid.dll
    nvidia-libs-0.8.1/x32/nvapi.dll
    nvidia-libs-0.8.1/x32/nvcuda.dll
    nvidia-libs-0.8.1/x32/nvencodeapi.dll
    nvidia-libs-0.8.1/setup_nvlibs.sh
    nvidia-libs-0.8.1/nvml_setup.sh
    I like having a symlink to the actual version with a more generic name so I can upgrade later and simply update the symlink to use the newer version:
    $ ln -s nvidia-libs-0.8.1 nvidia-libs
    Run the nvlibs setup using the new WINEPREFIX:
    $ WINEPREFIX="/daz/.wine" ./setup_nvlibs.sh install
    WINEPREFIX does not point to an existing wine installation.
    Proceeding will create a new one in /daz/.wine
    Continue? (Y/N) y
    wine: created the configuration directory '/daz/.wine'
    002c:fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
    002c:fixme:winediag:loader_init wine-staging 10.0-rc3 is a testing version containing experimental patches.
    002c:fixme:winediag:loader_init Please mention your exact version when filing bug reports on winehq.org.
    004c:fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
    0054:fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
    0054:err:ole:StdMarshalImpl_MarshalInterface Failed to create ifstub, hr 0x80004002
    0054:err:ole:CoMarshalInterface Failed to marshal the interface {6d5140c1-7436-11ce-8034-00aa006009fa}, hr 0x80004002
    0054:err:ole:apartment_get_local_server_stream Failed: 0x80004002
    0054:err:ole:start_rpcss Failed to open RpcSs service
    004c:err:ole:StdMarshalImpl_MarshalInterface Failed to create ifstub, hr 0x80004002
    004c:err:ole:CoMarshalInterface Failed to marshal the interface {6d5140c1-7436-11ce-8034-00aa006009fa}, hr 0x80004002
    004c:err:ole:apartment_get_local_server_stream Failed: 0x80004002
    0080:err:ntoskrnl:ServiceMain Failed to load L"C:\\windows\\system32\\win32k.sys"
    0080:err:ntoskrnl:ServiceMain Failed to load L"C:\\windows\\system32\\drivers\\dxgkrnl.sys"
    0080:err:ntoskrnl:ServiceMain Failed to load L"C:\\windows\\system32\\drivers\\dxgmms1.sys"
    00a0:fixme:file:NtLockFile I/O completion on lock not implemented yet
    00a0:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
    00a8:fixme:file:NtLockFile I/O completion on lock not implemented yet
    00a8:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
    00a8:fixme:msi:internal_ui_handler internal UI not implemented for message 0x0b000000 (UI level = 5)
    00a0:fixme:msi:internal_ui_handler internal UI not implemented for message 0x0b000000 (UI level = 1)
    0110:fixme:msg:pack_message msg 14 (WM_ERASEBKGND) not supported yet
    002c:err:setupapi:do_file_copyW Unsupported style(s) 0x10
    0134:err:setupapi:do_file_copyW Unsupported style(s) 0x10
    [1/4] nvcuda :
        Creating DLL override...
        Creating symlink to nvcuda.dll...
    [2/4] nvcuvid :
        Creating symlink to nvcuvid.dll...
    [3/4] nvencodeapi :
        Creating symlink to nvencodeapi.dll...
    [4/4] nvapi :
        Creating symlink to nvapi.dll...
    [1/6] 64 bit nvcuda :
    [2/6] 64 bit nvoptix :
        Creating symlink to nvoptix.dll...
    [3/6] 64 bit nvcuvid :
    [4/6] 64 bit nvencodeapi64 :
        Creating symlink to nvencodeapi64.dll...
    [5/6] 64 bit nvapi64 :
        Creating symlink to nvapi64.dll...
    [6/6] 64 bit nvofapi64 :
        Creating symlink to nvofapi64.dll...
    Symlinks created in /daz/.wine. Do NOT remove this source folder!
    OBS! NVML is NOT enabled by default. See Readme_nvml.txt for info or run nvml_setup.sh
    You need to REMOVE old overrides if older version of nvml have been used in /daz/.wine
    Configure your new WINEPREFIX to your liking. I personally like to emulate a virtual Windows desktop when I use Daz, as I find it is much less intrusive (I use "Focus follows mouse" mode, and Windows apps such as Daz routinely steal focus when not run in virtual desktop mode). The other life hack for me is the "Screen resolution" setting. I have seen multiple posts in this thread asking how to change the size of the text in Daz, but it is not possible. However, you can make everything larger, including the text, by increasing this setting from the default. I use 144dpi to get a more usable appearance for my old eyes.
    $ export WINEPREFIX="/daz/.wine"
    $ winecfg WINEPREFIX="/daz/.wine"
    NOTE: Once you have this new WINEPREFIX working as desired, you may want to add the above export command to your login profile so that it is set whenever you log in to your system.
    Download the latest Daz Studio Installation Manager (DIM) to start installing the latest version (4.23 as of this writing).
    https://www.daz3d.com/install-manager-info
    Run the new DIM installer using wine:
    $ wine DAZ3DIM_1.4.1.69_Win64.exe
    Provide your Daz account information when prompted, then complete the installation.
    Post Install Steps
    At this point the basic Daz 3D Studio app should be able to run and it should see any NVidia GPUs installed on your system. If you're new to Daz Studio on Linux, you're done! Have fun.
    On the other hand, if you are like me, and you have been using Daz for a while on Linux in a different WINEPREFIX (that was on a case-sensitive filesystem), then there's more work to do to get back to where you were. The remainder of this post focuses on that scenario.
    Relaunch DIM to install all of your purchased content since it doesn't do that as part of the initial install.
    $ wine 'C:\Program Files\DAZ 3D\DAZ3DIM1\DAZ3DIM.exe'
    Reinstall any addons from other sources that were not installed using Install Manager (e.g., content downloaded from RenderHub or other non-Daz Store sources). This is required due to the fact that we installed in a new WINEPREFIX, so any manually installed packages need to be manually installed again.
    Any changes made to the old installation (in my case, v4.21) need to be manually copied from the old installation/WINEPREFIX to the new installation. Here are the most notable that I have found thus far:
    • /daz/.wine/drive_c/users/korb/AppData/Roaming/DAZ 3D/Studio4/user layouts/  (my saved Daz Studio layouts)
    • /daz/.wine/drive_c/users/Public/Documents/DAZ 3D/InstallManager/Downloads/  (products installed with DIM but manually downloaded)
    NOTE: for the InstallManager/Downloads/ subdirectory, there will be lots of files already present in the new installation. As such, you just want to copy those from the old installation that are missing into the new one, then launch DIM again to install these manually downloaded packages. They will be listed under the "Ready to Install" tab when you launch DIM.
    Lastly, the primary reason for this entire exercise was to deal with assets that were created on NTFS but the creator was not careful about using consistent case when referencing files/folders (because they didn't have to be!). Any such content that you have installed in an old Daz installation will need to be reinstalled in the new installation. The details of that process are beyond the scope of this post - it can be anywhere from something as simple as unpacking a ZIP file into your "My Library" folder to running a custom installer supplied by the content creator.
    Conclusion
    If you rely on Daz 3D Studio to do your rendering work but have had enough of the hassles of running Microsoft Windows, what are you waiting for? Follow these instructions and you, too, will be up and running in no time with Daz on Linux. Enjoy!
    Post edited by korb on
  • IceCrMnIceCrMn Posts: 2,333
    If you are on a 4k monitor and your fonts are too small you can adjust this using the winecgf tool
    in winecfg on the "Graphics" tab on the bottom set the "Screen Resolution".
    Default is 96.
    I use between 120 to150 depending on how bad my eyes are that day.
    On Windows I usually set the scaling to 150% so this is close.
    You'll need to experiment with this to find the size you like best.
    this adjustment is for all programs you run in this wineprefix.
    I only have 1 so it adjusts for all windows programs I use.
    Whiich is a good thing for me, I like it this way.
    Post edited by IceCrMn on
  • This thread has been running for 10 years and we still don't have a native version for Linux.......
  • MasterstrokeMasterstroke Posts: 2,454
    If DAZ does not intend to support Linux, then this will be a market opportunity, right? winkwinkwink
  • Well perhaps not, but the Linux user base is growing and with the support ending for Windoze 10 it will continue to grow, so who knows if it is an opportunity or not.
  • Robert FreiseRobert Freise Posts: 4,693
    And on top of that a lot of those W10 computers can't run W11
  • csaacsaa Posts: 1,053
    Hi, Folks.
    I stumbled my way into getting Daz3D installed in my Ubuntu box (a Mint distro, atcually). Probably the hardest part was getting the NVIDIA drivers properly set up. In the process, I tried plain vanilla Wine, and later on, Bottles. The project has taken me a number of months, given demands of work and life and so on. Over the weekend I stated to download assets and spin up Daz for simple renders.
    Given the same DUF scene, my cursory tests show that the Wine set up is loading and rendering faster than the Bottles one. Has anyone noticed this too? I do prefer the Bottles framework as it's UI easily lets me configure environment settings and file paths.
    In any case, I've completed my transition from Windows to Linux.
    Cheers!
    Perhaps they will reconsider that in time if enough people are running the software under Linux.
    I'm another one starting the process of making the switch from Windows to Linux. I've got a Win 7 Ultimate system (with pretty old-ish hardware, although it IS a 64-bit machine) that's overdue for a reformat anyway, and I have absolutely zero desire to put Windows back on here if it can be helped at all. The last hurdle is just figuring out whether or not I can use Studio/render in Linux. I'm also brand new to Linux,so my poor hubby has been trying to help me along here (he's a Mint user himself, but has no idea about using Studio in it).
    Maybe they might reconsider making a native Linux version if there's enough demand. I suspect that there might be more demand soon as MS gets heavier handed by the day. I'm sure that I'm one of many that are making the switch over to Linux. There might be an increased number of people doing that soon, no? I mean, my laptop is at least ten years old. It's 64-bit, but it's still old hardware. There's no way I would even attempt to put a current version of Windows on this thing - even if I did want it.
  • bluejauntebluejaunte Posts: 2,223
    I've been playing around dual booting into CachyOS (Arch Linux based)  lately and seeing this thread I thought why not just try boot up Daz Studio. To my surprise it works. As in just starting the exe from my Windows partition and pointing to the content libraries there. The only issue is obviously the CMS, and my GPU isn't recognized. Only my CPU, which renders fine. But hey, not bad for starters and basically configuring just about nothing.
  • felipe.a.v.lopesfelipe.a.v.lopes Posts: 28
    edited April 2025
    Hey, everyone,
    Been using Fedora for maybe a month (Started with Fedora 41 KDE and recently updated to Fedora 42) and I've been able to get Daz Studio working for the most part.
    At first I had no luck with getting iray to render on the GPU, until I installed DS via DIM using Lutris.
    I then Imported the Lutris install using Bottles, which sorted some issues like the capital "I" letters not being displayed in the various tabs, etc.
    What I can't seem to get working though is dForce. as it reports that it can't find a valid OpenCL 1.2 device.
    I'm using the latest Nvidia drivers 570.133.07 and my GPU is a RTX 3070.
    Anyone having similar issues with the latest driver?
    Cheers
    Post edited by felipe.a.v.lopes on
    Hi, felipe.a.v.lopes.
    I use Linux Mint, an Ubuntu derivative, running on an AMD cpu and an NVidia gpu. I've only installed Daz via Botltes recently and have had good success rendering in iRay without needing to fiddle with any sytem setting. (Ofcourse, I needed to install the NVidia drivers beforehand.) I haven't tried dForce, as my render and posing workflow is heavily Blender dependent.
    I haven't used Fedora in ages. Looking at your issue and searching online, here's an old WineHQ thread that might help you - https://forum.winehq.org/viewtopic.php?t=30859
    This OP there reported OpenCL errors in a Fedora systems with an NVidia gpu. Long story short, people recommended installing: (1) the Linux OpenCL libraries; and (2) the Wine-OpenCL libraires. NVidia cards are OpenCL compliant, so deploying the OpenCL software drivers makes sense.
    Hope that helps. Please let us know if this solves your problem. Share a Daz render image to indicate so, if you can. laugh
    Cheers!
    felipe.a.v.lopes said:
    Hey, everyone,
    Cheers
    edited April 2025
    Cheers!
    Hi smiley
    Thanks for the reply.
    I've been looking around that thread you've linked and after installing the Wine-OpenCL Libraries, I do see my 3070 on the Advanced section of the Simulation Settings tab but only on the DS install I got on Lutris, which has issues (like not displaying the capital "I" anywhere on the UI and it also displays in the Hardware section in the Render Settings tab a third device ( CUDA 42944967295 with a memory size of -1 Byte and the mode is WDDM Display) between my CPU and GPU.
    I've tried reimporting this updated DS into bottles but there are no changes unlike with the Lutris one.
  • Lylahl1212Lylahl1212 Posts: 9
    I'm going to try installing it on Bazzite tomorrow. Did any ever figure out the small text issue?
  • StarkdogStarkdog Posts: 176
    Just out of curiousity, has anyone tried installing/rinning DS2025 Alpha version on any version of Linux yet?  I'm saving up for a new machine, and really don't want to use WIN11, but would rather use Linux.  Also, how are the 50x0 series cards running on Linux?
    Thanks, -David
