• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeo scale and position issues
globallyglobally Posts: 128
January 29 in Blender Discussion
Hello,
ive been using diffo for a while now and always had an issue where the eyebrows, vellus hair and sometimes gens would be in differnet positions to the main character (g8f). i figured out that is down to the location of my character pose in daz (ie the pose might be +10 on the y and the eyebrows etc would import at zero) i always worked around this by just making sure the pose was at zero for all translations. i recently changed the scale of my character using the main scale slider and im having the same issue, the eyebrows, vellus hair and gens are importing at the old scale. what am i missing? i tried memorizing the figure but that doesnt seem to work.
  • PadonePadone Posts: 4,018
    January 30
    Be sure "apply transforms" is set in easy import.
  • globallyglobally Posts: 128
    January 30
    Hi Padone, thanks for all the help you give here for diffeomorphic.
    i did think I’d tried "apply transforms" but i tried it again but the scale (and I'm guessing transforms if I didn't have the pose set to zero) is still off on the eyebrows,  vellus hair and gens.
    im exporting an HD g8.1f using the geometry editor trick. Sometimes the gens will follow but it seems to happen randomly and not to the other items.
    January 30 edited January 31
    The dbz exporter bakes from the viewport so what you report should be impossible. Be sure to tessellate in the viewport before exporting, just in case. If this doesn't work please provide a test scene as simple as possible, so we can give a look.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Features/Hair Tools
    Post edited by Padone on January 31
    January 30 edited January 30
    Ah you learn something new everyday. Ok I'll give it a try first. How do you tessellate in the viewport? I've never heard of that before. Is that a setting on the eyebrows and vellus?
    Post edited by globally on January 30
    January 31 edited February 1
    It's the usual tesselation and PR hair in the daz hair settings, if you're not aware that's probably why it works random for you, depending on the settings.
    444 x 250 - 31K
    Post edited by Padone on February 1
    January 31 edited January 31
    Sorry Padone but i dont see any tesselation settings anywhere. Is this per hair item? I am looking at the eyebrows for example and i cant find anything called tesselation in parameters, surfaces, render settings or draw settings. What am i missing here?
    Post edited by globally on January 31
    February 1
    Select a hair object, then parameters > general > line tessellation, as shown in the picture above. This is also explained in the docs I linked above. If you can't see it then the hair is not SBH or dForce, and you should be able to import it as a regular mesh. If you have no idea what a dForce or SBH hair is, then ask/search in the daz forum to better understand it.
    Or again provide a test scene as simple as possible, if the issue is limited to a specific asset that doesn't work.
    February 1
    Ok so it seems like the eyebrows and vellus hair dont have tesssellation settings so they should import as a regular mesh. ive made a simple scene with the base 8.1, bj ensley eyebrows and the standard 8.1 vellus hair on cheeks and mouth. im exporting using the geo edit export trick to get HD and the gens. i tick apply transforms which works for the gens but not the eyebrows or vellus.
    duf
    duf
    test scene.duf
    164K
    February 2 edited February 3
    I don't have any issue importing your scene, I exported the dbz as HD within the geometry editor. There's currently one python error in the latest dev version so I'll report to Thomas, but this doesn't affect the hair position as you noted. I'm using daz studio 4.23.0.1 and blender 4.3.2, diffeomorphic 4.3.0.2490. May be you just need to update.
    https://bitbucket.org/Diffeomorphic/import_daz/downloads/
    https://bitbucket.org/Diffeomorphic/import_daz/issues/2370/
    update. The python error is now fixed in the last commit.
    623 x 202 - 54K
    Post edited by Padone on February 3
    February 3
    Thanks Padone, I will update and try again later.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
