Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
Screen left? Extreme left as in on the border or before one gets to the Avatar? I don't see the black box at all. I'm running Cyberfox which is Firefox but 64 bit.
See, I told you everyone would want them!
Dana
Oh, those little black boxes, bullet points it looks like. Do you also see the first post of every thread as bein without one, so slightly out of kilter with the rest of the first page .
Border, I suppose is the best description...
Indeed, 'tis true!
Vin
Current version of Firefox here, too, and I don't see them, not even if I select and highlight the whole page.
Could it be some weird sort of tracker graphic that not everyone sees? I use Adblock Plus, which does indicate 7 blocks on this page.
I guess something in the Cyberfox code hides those. I don't see them! Oh well!
I'm on a low-speed (dial-up) connection - so what I see is the page loading normally and rendering as expected - and then everything does a re-flow to the right and the boxes pop into place - gotta be some style sheet that hits near the end to do this.
Might very well be something like that — I frequently see similar bouncing page elements, but on the store front page, on my first visit each day before I log in. Wouldn't be the first time a DAZ stylesheet's done Weird Stuff™...
...don't see them here, then again I have popup and ad blockers active as well as NoScript.
And apparently "they're working on a fix". Fingers crossed...
You probably wonder (if you even bother reading my posts) why I keep whining on about old style links not working with this new forum software.
Okay, so I sound like a broken record continually repeating.
But just for a laugh go to Richard Haseltine's stickied "DAZ Studio 4 Frequently Asked Questions" thread at the top of the DAZ Studio Discussion forum, and under the "General DAZ Studio 4 Questions (first heading in the OP) click the ">>>" link at the right of "Do I have to uninstall previous versions of DAZ Studio before I install DAZ Studio 4?"
Now tell me that old style links not working isn't a problem that should be fixed !
Actually, that's been broken for quite a while...
forum.daz links broke LAST forum software update!
Hmm, I wonder if they didn't convert because they are links within the thread? OK, fun job for me to do sometime.
Is there a way to ignore a thread?
I like to go through the new threads since my last visit, and some of the threads I'm not interested in, and it just makes it all cluttered.
I know I can remove these threads using AdBlock, but this method slows down the browser after a while.
I'm not aware of a way to hide threads, sorry.
Too bad. :( Thanks for the response! :)
And their vertical position is not fixed. I waa going to mention that the little black box I see is (relative to your avatar) on a level with your hair line and just a bit further from the left edge of your avatar that the distance between your eyes. Then I see this post and it is in line with your nose! I guess it must be based on a percentage of post height.
Have you noticed that the first post in a thread does not have the little black box? It is like all following posts are indented as a bulleted list.
That was what I said in this post http://www.daz3d.com/forums/discussion/comment/903641/#Comment_903641
Ah, so you did! I missed or forgot that (getting to that age of forgetfulness, you know.
OK. Now I'm getting some weird bug report banner at the top of my page here and in the store. There is some weird error that tells me it can't access my account or my cart contents. Sheesh! I can't access any of it either!
I'm getting the same error, and the store won't open , and the gallery is broke :(
I relogged and it seems to all be working again.
I can't even log out. I get the error and stay logged in.
I also rebooted my computer, I don't know if that helped at all, but I needed to go get another drink anyway, so I just restarted the whole thing.
Whenever I see that, I think 'Send in the X-Men!', then I see it's Magento!
CHEERS!
Seems better now....
...looks like they swapped the login/new account buttons on the homepage.
