Show Us Your Iray Renders. Part IV
16061636566100
  • jag11jag11 Posts: 885
    edited September 2015
    Fiddling with Kori's skin.
    565 x 800 - 538K
    Post edited by jag11 on
  • Fantastic results!!!! Would love to know your settings......?
  • ZilvergrafixZilvergrafix Posts: 1,385
    iPad Pro resolution...
    2208 x 1242 - 381K
    Post edited by Zilvergrafix on
  • L'AdairL'Adair Posts: 9,479
    Very nice. I love the iphone...
    And I notice her, ah... talents... aren't quite so robust as some of your other images. (snicker)
  • SzarkSzark Posts: 10,634
    As I don't have any Gen2 or 3 products this is Genesis rendered in Daz Studio/Iray with using 3 Spot lights and 1 distant light for the back lighting. For my first portrait I don't think it came out that bad.
  • RogerbeeRogerbee Posts: 4,460
    Yeah, that's really nice. I haven't done much with lights other than HDR's.
    CHEERS!
  • Oso3DOso3D Posts: 15,119
    Szark: Very nice overall, and I particularly like the hair.
    As for lights, it's one of those things a lot of us sort of breeze past, but it can make such a difference. Heh. But yeah, I usually just use one of Mec4D's portrait HDRs.
    Where do you get them from? I wasn't using Iray when her birthday thread was active so I missed all the freebies she had.
    CHEERS!
    Rogerbee and timmins.william thanks
    I tried a studio HDRI first but it washed out the detail so I went with a 3 point light rig instead
  • Jack238Jack238 Posts: 117
    That is an understatement in my estimation. Very nice render. May I ask what you used for shaders on Genesis and the hair. Both are excellent. Thanks for sharing.
    Jack
    Thanks Jack
    I just used Iray Uber Shader Metalicity/Roughness on everything. I will take some screen shots of the settings later. I did use DT's Interjection SSS strength maps in the Translucency Weight channel. The Skin texture set came with SSS colour maps so they went into the SSS colour channel
  • barbultbarbult Posts: 27,534
    Szark, I think she turned out GREAT! The hair is fabulous, too.
    thanks barbult
  • nicsttnicstt Posts: 11,715
    Rogerbee said:
    nicstt said:
    L'Adair said:
    Rogerbee said:
    Very nicely done,
    I don't think I'll be upping anything till I have a GPU taking the strain.
    CHEERS!
    Thank you.
    I envy you your upcoming purchase. I'm not sure I can put an Nvidia card in my HP. And the cost of one is definitely not in the budget. Especially if I keep buying DAZ products! lol
    And you buy a card then want  need to buy more Daz products to test it /nod
    Yes, that will doubtless happen. I expect G3M/M7 will be out before I get a new card.
    CHEERS!
    I've been putting it off; there is the risk that faster renders will mean buy more product to test; the alternative is that i'll be waiting less time for renders so spend less time looking for stuff to buy. :)
    Scott 6 portrait.
    565 x 800 - 486K
    Szark said:
    Thanks Jack
    Interesting, I wouldn't have thought to do that. Nice going.
    CHEERS!
    jag11 said:
    Scott 6 portrait.
    Looks good!
    CHEERS!
    Indeed it is; I like the slight gap on the teeth too, adds some believability to the scene.
    Rogerbee said:
    Szark said:
    Thanks Jack
    CHEERS!
    Thanks. This is why Sharing helps us all learn. If I make money on something I won't share though. :)
    I can't wait to get some Gen3 products.
  • an Old scene too
    you're right, but this can be fixed easily:
    1527 x 2160 - 588K
  • ScytharScythar Posts: 127
    Been a while;
    Just for the record...
    • HDR 360° environment
    • Iray AtmoCam
    • Tubo Hotel
    • Vanguard / Pocketstar / Thunderbike
    • G3F + Leyton Hair / CS Sandels, Shorts and Top
    • G2M + MicaHair / Jeans-Brodie / Shoes-Brodie / 2Tattoos_7S
    • Dramatic Lights on couple.
    2000 x 1125 - 1M
    my pleasure Jack
    Interesting, I wouldn't have thought to use that Top Coat Thin Film, I based what I did on Mec4D's settings.
    CHEERS!
    Ok, I tried Top Coat Thin Film on Darius with the same setting and only noticed a very slight difference in the skin tone. Here he is anyway..
    CHEERS!
    577 x 750 - 168K
    It depends on the lighting. HDRI's won't show the difference. Use some spots and change the thickness to 400 NM and see the difference. In fact sebum has a wave length of 400 to 600 NM which I tried but the colour was too intense. I need to play with Top Coat and Gloss strengths to get a fine balance without the Top Coat giving a vivid colour.
    Also I noticed the HDRI's I have give less highlights than spots do.
    Post edited by Szark on
    In honor of my money drought finally ending, here's a new thing I got!
    BIG HUGS FOR VALANDAR!
    2000 x 1236 - 1M
    Yes, that's Slime Beast http://www.daz3d.com/slime-beast . Tweaked a bit for Iray.
