G8M is become all blue
Hi, since a while (I am not sure when but I have the impression that it is since the last G8M update, I don't remember the date...), when I load a G8M base character, he is all blue :
I first thought that it was a temporary bug, but he is like that every time I load him... However, G8.1 and G8F have no problem at all,. I also try with PA's G8M characters like DD Keita, and there is no problem too, so it seems there is an issue only on the G8M base character when I load him...
Maybe it could come from the last G8M update? Could you help me please?
Thank you in advance!
  • GordigGordig Posts: 10,844
    First guess is that the preset got screwed up and is loading normal maps instead of diffuse.
  • Thank you very much! I checked in the folder where the G8M textures are, and it seems that it is "actually" the diffuse maps: there is a D in the name of the textures, but there are all blue:
    Do you know how I can fix it? crying
  • CES3DCES3D Posts: 262
    Perhaps reinstalling "Genesis 8 Male Starter Essentials" will fix it?
    Alternatively, you could download the archive from here, extract the necessary texture files from it, and overwrite the incorrect files.
    I believe the texture files you need are likely in "IM00042071-02_Genesis8MaleStarterEssentials.zip".
    955 x 787 - 38K
    906 x 767 - 291K
  • Thank you very much! If I understand well, to reinstall the package, I have to go in DIM, uninstall it, and then reinstall it, still by using DIM, is it that?
  • frank0314frank0314 Posts: 15,116
    edited November 2024
    If you're using DIM go to installed tab click on the 3 vertical dots at the end of the selection and select "Re-install Genesis 8 Essentials......"
    Post edited by frank0314 on
