G8M is become all blue
yuyu.atem
Hi, since a while (I am not sure when but I have the impression that it is since the last G8M update, I don't remember the date...), when I load a G8M base character, he is all blue :
I first thought that it was a temporary bug, but he is like that every time I load him... However, G8.1 and G8F have no problem at all,. I also try with PA's G8M characters like DD Keita, and there is no problem too, so it seems there is an issue only on the G8M base character when I load him...
Maybe it could come from the last G8M update? Could you help me please?
Thank you in advance!
First guess is that the preset got screwed up and is loading normal maps instead of diffuse.
Thank you very much! I checked in the folder where the G8M textures are, and it seems that it is "actually" the diffuse maps: there is a D in the name of the textures, but there are all blue:
Do you know how I can fix it?
Perhaps reinstalling "Genesis 8 Male Starter Essentials" will fix it?
Alternatively, you could download the archive from here, extract the necessary texture files from it, and overwrite the incorrect files.
I believe the texture files you need are likely in "IM00042071-02_Genesis8MaleStarterEssentials.zip".
Thank you very much! If I understand well, to reinstall the package, I have to go in DIM, uninstall it, and then reinstall it, still by using DIM, is it that?
If you're using DIM go to installed tab click on the 3 vertical dots at the end of the selection and select "Re-install Genesis 8 Essentials......"
