3D Comic Book Tips And Pictures
14344464849
  • Leana said:
    mmitchell_houston said:
    This looks very nice, and very promising. What, exactly, is Filatoon? Is it a render setting built into Daz Studio or is it a separate product? I saw a bunch of Toon products recently listed, but non of them list a prerequisite for another product. Also, does it allow for pure b&w output?
    Filatoon is a shader (well, a combination of a shader and a geoshell for the outline) that you use with the Filament render engine. The shader is available in the latest version of DS default resources, and you need DS 4.23 to use it.
    Very interesting. Is there a tutorial on how to use this?
  • Space JingorohSpace Jingoroh Posts: 176
    edited October 2024
     Anime Toons and Filatoon Shader Q&A
     FilaToon / Cell shaded rendering with Filament
    Post edited by Space Jingoroh on
    Thank you so much for the links. I'm not thrilled about needing to use a geoshell, but I am going to tinker with this and see what I can do. Thanks again!
  • 3Diva3Diva Posts: 12,058
    edited October 2024
    3Diva said:
    I'm so excited about Filatoon! I'm planning on using it for my comic work. Here's the result of an experiment I'm doing with the Filatoon settings and the Filament Draw Options. This is a Filament render with zero post-work:
    Is anyone else exploring Filatoon? One of my favorite parts is that it renders just about instantly - in about 1 second, even on my older machine! And what you see in the viewport is what you get! So cool!
    It utilizes the Filament render engine in Daz Studio. It's pretty awesome. Here are a couple of threads in the Commons about it: https://www.daz3d.com/forums/discussion/704951/anime-toons-and-filatoon-shader-q-a#latest ;      https://www.daz3d.com/forums/discussion/704931/filatoon-cell-shaded-rendering-with-filament#latest
    And it does do black and white, just drop in a Tonemapper Options Node (Top menu: Create >> New Tonemapper Options Node). Select the Tonemapper Node in the scene tab then go to Parameters >> Tone Mapping >> Saturation (set it to zero).
    Post edited by 3Diva on
    Thank you very much! I'm going to give it a shot and see what I can do with it.
  • I've been messing around with comics too lately, on the side. There's not much of a story to the first chapter, just needed something simple to figure out everything... style, workflow, speed, online comic platforms...
    A few pages I have so far... style is still changing a bit from page to page and #3 is missing, want to redo it...
  • Xandyr78Xandyr78 Posts: 168
    Oh wow...those look fantastic!!
  • I agree. I think you're onto something.
  • David RDavid R Posts: 505
    The visual style is perfect for this subject matter.
    As an addendum...how much of that set of pages is postwork, and how much is original render?  And is there ANY chance you might be willing to do a tutorial?
  • StrangeFateStrangeFate Posts: 840
    edited November 2024
    Thanks all!.
    @Xandyr78 - It depends, on the first page only the character is Daz, the rest is Photo ref, Google street view usually, made to look like night with a replaced sky. Added the moon and painted some moonlight reflection on the building and ground...
    From there, any view of the sky and street is done the same way, the rest is Daz, and then of course lot's of grunge overlays and post in PS. After page 3 it occurred to me that I could use a cube with SSS to fade away / simplify the background in shapes and color, making it easier to focus on the characters. Still fighting a bit with the Iray lighting and shadows.
    I also found that removing the glossiness from all materials, including skin, making everything dull/matt worked a lot better for my style. The flatter and simpler the shading, the better it seems to look. I suppose the Filatoon shader does kinda the same in that aspect.
    Yellow glowy hand FX and such are just blood splatter decals added in PS.
    Post edited by StrangeFate on
    StrangeFate said:
    Thanks all!.
    Copy
    That's fascinating stuff @StrangeFate!  Also sounds like a metric ton of work.  I'm not opposed to work, LOL (I'm both a freelance and a corporately-employed graphic designer, and some of the things I'm asked to create are..."adventures" in request interpretation and software technique crash-coursing), but I'm always on the lookout for shortcuts, tweaks, and the like.  Playing with the glossiness levels isn't something I've done, and now I have to try it.  Thank you!
    Post edited by Xandyr78 on
    @StrangeFate Those are stunning pages! Well done! Are those Iray based? Have you worked with Filatoon?
  • BrashFinkBrashFink Posts: 105
    So I have recently started working a different way. Taking a figure drawing in college this semester, I have started just using Daz as a refernce tool... tracing and redrawing stuff. Which is very liberating, because what I render out does not need to look perfect. In fact... I render for only a couple minutes. Since I am redrawing everything, the quality does not matter.
    Here is my final project for this semester. This was completely redrawn from a couple of Daz renders, along with some Photoshop postwork (digital numbers and such).
    2550 x 3300 - 1M
    Post edited by BrashFink on
    That's fantastic, @BrashFink!  I wish I trusted myself that much...alas, while I am a decent artist, comic-style artwork has never been my forte, at least not hand-drawn.
    Thanks a bunch!
    It's been a journey. I am starting to feel I am getting back to where I was in the early 90s. I was attempting to use Daz to tell stories that in my head and not have to relearn drawing thinking I was so old it would take forever... However, somthing interesting started happening. Using Daz... and reworking like 50% or the lines from my filters output... started... I dunno. resparking something. Basically kickstarting my mind or something.
    My teacher (an actual working comic artist) was an incredible influence too. He was so intested with how I used Daz, he actually had me do a leture on Daz in class and how it could be used to help artists.
    BrashFink said:
    Thanks a bunch!
    hahah That's awesome! I'm glad you're sharing the joys of Daz Studio with others! And the image you created came out so cool! Excellent work!
    Thanks Diva!
    No, I haven't tried out the Filatoon shaders. I do kinda like what I can do lighting wise with Iray, and I guess I'm used to it and comfortable with it... it's just problematic sometimes because I can't turn shadows on or off per object or light source. I know 3Delight can do that, but I'm too invested in Iray I guess to want to change, so I just complain instead :)
  • csaacsaa Posts: 1,038
    StrangeFate,
    Those are well done! Thanks for sharing.
    Cheers!
    I'm getting some interesting shadows while doing some experimenting. Shadow Type PCSS coupled with a NEGATIVE "Shadow Polygon Offset Slope" value gives almost like a hatching-like effect. You have to render out pretty large and rescale it down though, otherwise it's a bit too messy. This was rendered at 2000x2600 and then scaled down to 800x1040. Thankfully Filament rendering takes like 2 seconds. lol
    I could see this look in like a dark comic or a mystery comic, I think.
    800 x 1040 - 932K
  • That cross-hatching effect looks interesting. And yes it does have an ominous tone.
    BrashFink,
    As a nod to Daz FilaToon, I think you can incorporate it into your workflow, perhaps overlaying a FilaToon render as an image layer, to help with the shading of a scene. I've been a big RPG hobbyist most of my life and the image you shared reminded me of the B&W illustrations that RPG books come with. Very pulpy, very moody. I see them often in noir, horror or gritty spy RPGs.
    Cheers!
  • ArtAngelArtAngel Posts: 2,092
    edited December 2024
    I seldom hang out here, or anywhere much but the vet's lately, but I thought I would share this page from my recently published picture book.
    Post edited by ArtAngel on
  • If you delete the attachment the embedded version will also go - you will still see it for a while since it is cached.
    So it's been three hours and I have not had a chance to post it back. Timing sucks looking for Sunday ER for Cat right now. Will address everything later.
  • Hmm, I am not sure how would be best to organise that. I suspect you'd get a fair number of ties at the top given how good some people (not me) are at spotting products.
  • RafaelRafael Posts: 166
    Guys. As many of you want a vintage look to your images, allow me to spam you a link for a post I made some years ago on another forum explaining some of the reasons comics looked like that some decades ago.
    https://graphicdesign.stackexchange.com/questions/104553/looking-to-replicate-a-comic-coloring-of-early-90snot-just-using-the-half-tone/104559#104559
    @Rafael Interesting stuff. Thanks for the link! :)
  • TesseractSpaceTesseractSpace Posts: 1,583
    Here's a couple of old attempts at comics, for some reason I keep getting two pages in and just lose all motivation. Still gonna give it a go again since Filatoon cuts the render time issues.
    676 x 1024 - 87K
    1243 x 1800 - 3M
    1243 x 1800 - 3M
  • Space VikingSpace Viking Posts: 33
    edited March 2025
    Been gone a while, and I see people are doing some amazing things. So cool.
    I just wanted to post a cover for my Amazon/ComiXology comic Edgeworld #11 announced a few days ago (I left off the tradedress as I was unsure about the promotion limits on the boards) to show that, yes, you can get published using these tools and techniques. And in fact, users like @strangefate are doing far better work than I am, so hopefuly we can move forward from here and let go of the idea that there's an insurmountable bias against the tools. It CAN work. It's really all about story, and storytelling. It helped that it was the contuinuation of a series they liked, but my co-creator was busy on another project, so we needed a new artist. That turned out to be me.
    This is all DAZ studio models, with post work. I'm using the outline script, Iray tones, and then layering files in Photoshop for post-work, finally importing it all into ClipStudio Paint to do some texturing, and linework, feathering, brush tones, and panel borders. Colors are by a separate artist, Lee Loughridge, a brilliant colorist who has worked on... well... everything, all the way back to the original Sandman.
    716 x 1100 - 362K
    Post edited by Space Viking on
